Why Is My PlayStation Taking So Long to Download?
530 viewsGame Console
Pretty much every gamer has faced the agony of slow PlayStation downloads at some point. There could be a bunch of reasons why this is happening, so let’s dive into them and figure out how to fix it.
Network Connection Issues
  • Unstable or Weak Wi-Fi Signal: Wi-Fi signals can get disrupted by walls, other electronic devices, you name it. This can slow your download speed to a crawl. Try moving your router closer to your PlayStation, or download your games in a spot where the signal is stronger.
  • Insufficient Bandwidth: If your household has multiple devices hogging the internet (like phones, computers, smart TVs, etc.), your PlayStation will get the short end of the stick. Cut off downloads or streaming on other devices, or prioritize your PlayStation on the network.
  • Poor Router Performance: An old, underperforming router can choke your download speeds. It might be time to upgrade to a more powerful one, especially one that’s up-to-date with the latest wireless standards.
Network Settings Issues
  • Poor DNS Server Setting: Sometimes, the default DNS server isn’t the quickest. Switching to a faster public DNS server like Google DNS (8.8.8.8 and 8.8.4.4) or Cloudflare DNS (1.1.1.1) might make a world of difference.
  • Suboptimal MTU Setting: If the MTU value is too high, it forces data packets to fragment during transmission, slowing down the download. Try setting the MTU to automatic, or adjust it manually based on your network environment, but generally, you should avoid messing with this setting unless you really know what you’re doing.
  • Not Using a Wired Connection: Ethernet connections are usually faster and more stable than Wi-Fi. If you can, connect your PlayStation directly to the router with an Ethernet cable to boost your download speeds.
PlayStation Console Issues
  • Background Applications Hogging Resources: Apps running in the background can sap system resources, slowing down downloads. Hit the PS button on your controller, choose “Close Application,” and shut down anything you don’t need running.
  • Console Hardware Limitations: Older PlayStation hardware might not fully utilize high-speed internet connections. Keeping your system software and firmware updated can help optimize performance.
  • Overloaded Download Queue: Downloading multiple items at once spreads your bandwidth thin, slowing everything down. Focus on downloading what you need immediately to maximize speed.
Issues with Your Internet Service Provider (ISP)
  • Limited Network Plan: Your internet plan could simply be too slow for downloading large games efficiently. Contact your ISP to see if there are options to upgrade to a faster plan.
  • ISP Server Issues: Sometimes, your ISP’s servers might be experiencing issues, causing slow speeds. Reach out to your ISP’s tech support to check for network maintenance or other problems.
Game Server and Other Issues
  • PSN Server Problems: The load on the PlayStation Network servers or their distance from your location can impact download speeds. Different regions have varying server performance, so switching to a different server might help.
  • Slow External Hard Drive: If you’re downloading to an external hard drive and it’s slow, the whole process drags. Upgrading to a faster external drive, like an SSD, can significantly speed things up.
If your PlayStation seems to be dragging its feet with downloads, there could be a handful of reasons why. Let’s break it down with some typical culprits and what you can do to kick things into gear.
First up, it’s those pesky background applications. These little guys can hog bandwidth like there’s no tomorrow if left running. The PS4 tends to favor whatever app is active, leaving your downloads gasping for resources. I once had a game running while downloading a new title, and my speeds were abysmal compared to when apps were shut down.
Tip: Give your download a fighting chance by shutting down unnecessary apps. Just grab that PS button, pick “Close Application(s),” and confirm—you’re good to go.
Wi-Fi can be hit or miss, especially with those older PS4 units that cling to the 2.4GHz networks like a barnacle. With walls and other electronic gremlins in the mix, your connection might take a hit.
Tip: Ditch the Wi-Fi drama if possible and go for a wired Ethernet setup. This move can seriously amp up your internet speed.
Your entire network’s bandwidth often plays tug-of-war with multiple devices. If everyone in the house is streaming or downloading at the same time, it can slow your PlayStation right down. I had a moment where my download speeds improved just by halting my roommate’s constant Netflix binges at peak times.
Tip: Try managing who uses what and when on your network. If slow speeds are a regular headache, maybe it’s time to chat with your ISP about a plan upgrade.
Digging into your router settings can sometimes reveal a goldmine—Quality of Service (QoS) settings can prioritize designated traffic types, and if misconfigured, they might throttle your PlayStation speeds without you knowing.
Tip: Do a spot check on those QoS settings. Adjust as needed or revert them to standard for a smoother experience.
Your ISP’s given DNS settings might not deliver the goods for gaming or hefty downloads. I’ve personally switched DNS settings and noticed a decent speed bump.
Tip: Head over to your PS4’s Settings > Network > Set Up Internet Connection and plug in some alternative DNS—Google’s public DNS is often a good choice:
  • Primary DNS: 8.8.8.8
  • Secondary DNS: 8.8.4.4
Slow downloads could also erupt from outdated system software or random console hiccups.
Tip: Regular updates can smooth out these snags—just hop to Settings > System Software Update and keep your console primed.
Overall, if your PlayStation download speeds are crawling, it’s often associated with background apps, network hiccups, bandwidth battles, router tweaks, mismatched DNS, or your PS4’s software state. Tackling these aspects methodically—whether it’s shutting background apps, opting for Ethernet, managing other devices’ internet demands, adjusting QoS, testing DNS changes, or keeping firmware updated—you’re likely to notice a boost. Happy downloading!
Why Is My PlayStation Downloading So Slow? Causes & Solutions
Waiting around for your PlayStation to download something at a snail’s pace? Yeah, super annoying! Let’s dive into some of the usual suspects behind this problem and how to fix ’em so you can get back to your game faster.
Network Connection Woes
Blame this one on a shaky or weak connection most of the time.
  • Wi-Fi vs. Wired Connection:
    Wi-Fi’s notorious for being flaky—so, if you can, plug in with an Ethernet cable to kick your download speed into high gear. Can’t ditch Wi-Fi? Make sure you’ve got your PlayStation hooked to that nifty 5GHz band (if it’s available) and clear the path between your console and the router.
    • FYI for Japanese PS5 fans: Some 5GHz channels, like 36-48, might be moody. Tweak it to 38-48 to smooth things out.
  • Meddling Router Settings:
    • IPv4/IPv6 Mix-Up: Your PS5 might throw a fit with IPv6-only networks. Flip on IPv4 in your router settings.
    • QoS Magic: Got bandwidth? Use the router’s Quality of Service (QoS) trick to give your PS5 first dibs on game downloads.
    • Give the Router a Nap: Just reboot it—simple but often does the trick.
DNS Configuration Drama
Cramming traffic through lame default DNS servers can slow things down.
  • Tweak DNS Settings:
    1. Head to Settings > Network > Settings > Set Up Internet Connection.
    2. Select your network, hit Advanced Settings, and drop in DNS addresses like Google DNS (8.8.8.8 and 8.8.4.4) or Cloudflare DNS (1.1.1.1).
PSN Server Overload or Outages
Sometimes, Sony’s servers can’t keep up during peak hours or when doing some maintenance.
  • PSN Status Check:
    Swing by their page to see what’s up. Got issues? Take a breather until they sort things out.
Background Choas & Storage Crunch
  • Pause Those Bandwidth Monsters:
    If other games, apps, or downloads are hogging the network, hit pause in your notifications menu under Downloads/Uploads.
  • Clear Out the Junk:
    Low storage space can slow down downloads. Clear out the unloved games/apps from Settings > Storage or boost it with a shiny new NVMe SSD.
NAT Type Headache
A strict NAT (Type 3) means slower peer-to-peer connections, which can throttle your downloads.
  • NAT Type Hack:
    Using a gaming VPN or network accelerator like UU Booster could level up your connection to NAT Type 2.
    • Accelerator Setup Walkthrough:
      1. Pop the accelerator on your PC/phone.
      2. Get your PS5 on the same network boat.
      3. Show it some love by following the tool’s setup tips, like manual IP/DNS tweaks.
Old Gear, New Problems
Your old router might be dragging its feet without those new bandwidth tricks.
  • Upgrade to Wi-Fi 6/6E Routers:
    Treat yourself to one of those modern routers with the snazzy 2.5G ports and Wi-Fi 6, and watch your speeds—and your gaming life—improve.
Bonus Tips
  • Download During the Sleepy Hours: Queue up those downloads overnight when everyone else is catching Zs.
  • Speed Test Adventure: Pop into Settings > Network > Connection Status > Test Internet Connection to check your basics.
Piece by piece, these tweaks should have you downloading games faster. If things are still dragging, maybe call up your ISP or chat with PlayStation Support for a little extra help.
Having a slow download on your PlayStation can be a real pain. First up, you’ve got to make sure your internet connection is solid. If you’re not sure, do yourself a favor and run a speed test on a different gadget just to see where you’re at.
Here’s the kicker: if you’re using Wi-Fi, try switching to an Ethernet cable. Those things can really speed up your downloads since they’re way more reliable than the mess of signals flying around your home.
Now, let’s move on to your PlayStation itself. Make sure you’ve got the latest system updates. Just head over to Settings > System Software Update and check if everything’s up to date.
Feeling adventurous? Try tweaking your DNS settings. Public DNS services like Google’s (8.8.8.8 and 8.8.4.4) or Cloudflare’s (1.1.1.1) might give your speeds a bit of a boost. You can do this by diving into Settings > Network > Set Up Internet Connection > Custom > DNS Settings.
If your download is dragging its feet, try hitting pause and then resuming it. You never know, it might just kick things into gear. Just go to Notifications > Downloads, pick your download, press OPTIONS, and select Pause followed by Resume.
Something else you might wanna do is shut down any apps or extra downloads running on your PlayStation. Without all that noise in the background, your download speeds might just perk up.
Think about where your router is sitting. If it’s buried behind a bunch of stuff or miles away from the PlayStation, your signal could be taking a hit. Finding a home for your router closer to your console could make a difference.
What really matters is the time you choose to download. Trying getting your downloads going when the internet’s less crowded, like late at night or early morning. It might help dodge network congestion.
So, try a few of these tips and hopefully, your downloads will speed up. If you’re still pulling your hair out, it might be time for a chat with your internet provider to see what’s up.
