Why Are My iPhone Calls Always Dropping?
265 viewsPhone
Today, iPhones are practically lifelines. So, it’s incredibly annoying when calls keep dropping. But don’t stress. Here’s a look at what might be causing those dropped calls and some tips to fix them.
Possible Causes
  • Network Signal Issues: Weak or unstable network signals are a biggie. If you’re in places with poor signal coverage like basements, elevators, or out in the sticks, your phone might struggle to keep a connection, leading to dropped calls. Crowded places like malls or stadiums can also overburden the network and cause issues.
  • Software Problems: Sometimes, outdated or buggy iOS updates throw a wrench in the works. New updates might come with unexpected glitches, and sometimes third-party apps clash with the system, messing up the calls.
  • Carrier Settings: If your carrier settings are outdated or wrong, your iPhone might not connect properly with the network, ruining call quality and stability. When carriers update their networks, not updating your settings can cause troubles.
  • SIM Card Issues: A damaged, poorly inserted, or faulty SIM card can mess up your connection to the network. Dirty or corroded metal contacts on the SIM card can also affect signal transmission.
  • Hardware Malfunctions: Things like busted antennas or speakers can directly affect call quality. A damaged antenna for instance can weaken the signal, and if your speaker is faulty, calls might be unclear or cut off.
  • Environmental Interference: High electromagnetic interference areas like near high-voltage lines or big electronic devices can disrupt your iPhone’s signal. Also, extreme temperatures and high humidity can affect the phone’s performance.
  • Battery Issues: Low battery levels can make your iPhone act up. Using old or cheap batteries can also hurt performance.
Solutions
  • Check Network Signals:
    • Move to areas with stronger signals. Open spaces or near windows usually work better.
    • Call your carrier to see if there’s a network issue in your area. If your carrier has poor coverage, maybe switching could help.
  • Update Software:
    • Go to “Settings” > “General” > “Software Update” and install any available updates.
    • Regularly check for app updates to keep everything running smoothly.
  • Update Carrier Settings:
    • Visit your carrier’s website or contact customer service to get the latest settings. This can help a lot with compatibility and stability.
  • Inspect and Replace SIM Card:
    • Take out the SIM card, clean the contacts gently, and put it back securely.
    • If it looks damaged, get a new one from your carrier.
  • Address Hardware Issues:
    • Suspect a hardware problem? Hit up an Apple Authorized Service Provider or an Apple Store for a check-up.
    • Keep your phone safe from drops or water damage, which can ruin hardware.
  • Reduce Environmental Interference:
    • Avoid areas with lots of electronic interference when on a call.
    • Protect your iPhone from extreme environmental conditions.
  • Maintain Battery Health:
    • Keep your battery above 20% for stable performance.
    • If your battery is old or cheap, consider getting a new one from a reputable brand.
  • Other Solutions:
    • Toggle Airplane Mode: Quick fix—turn on, then off.
    • Restart Your iPhone: Sometimes a reboot clears out the glitches.
    • Disable Wi-Fi Calling: Sometimes Wi-Fi calling screws with your calls. Try turning it off in Settings > Phone.
    • Reset Network Settings: Go to “Settings” > “General” > “Transfer or Reset iPhone” > “Reset” > “Reset Network Settings.” You’ll lose saved Wi-Fi passwords so be ready for that.
If nothing works, it might be time for a trip to an Apple Store for some professional help.
So, you’re dealing with those annoying dropped calls on your iPhone, huh? Let’s break down what might be going on. Call drops can drive anyone up the wall, and they can actually result from a mix of things—software hiccups, hardware quirks, or even just lousy network conditions. Let’s dive into the usual suspects that might be causing you grief.
What’s Behind Those Dropped Calls?
  1. Network Flubs: Weak signal? Yeah, that’s definitely a prime suspect. Whether you’re stuck in a dead zone or trapped inside some concrete building that’s blocking the signal, these situations can mess with your calls big time.
  1. Software Slip-Ups: This might throw you for a loop, but software bugs are real troublemakers. Every now and then, an iOS update might do more harm than good, screwing up call stability. It’s always worth checking if your iOS is on the latest version.
  1. SIM Card Shenanigans: Look at that SIM card of yours. If it’s damaged or sitting funny in the tray, you’re bound to hit call problems.
  1. Settings Mix-Ups: Your phone settings might be messing with you without you realizing it. Features like “Silence Unknown Callers” can accidentally block legit calls. And sometimes, Siri settings cause hang-ups, too.
  1. Old Carrier Settings: Missed a carrier update? Yeah, that can mess with your connection. These updates help keep everything running smoothly with your network provider.
  1. Apps Partying in the Background: Having tons of apps running in the background can hog resources and throw your phone off its game, including calls.
  1. Hardware Hurts: Antenna or other inside bits acting up? It could be why your calls keep slipping away. If you’re thinking this might be the case, Apple Support or a visit to a service center could be your best bet.
How to Tackle Dropped Calls
Alright, let’s talk about what you can do to get a handle on this annoying problem:
  1. Check Your Signal: Find a spot with better reception and see if your calls hang in there.
  2. Give Your Phone a Restart: Sometimes, a simple restart clears up those temporary glitches causing trouble.
  1. Update Your iOS: Make sure you’re running the latest iOS version. Peek into Settings > Software Update to be sure.
  1. Check That SIM Card: Pop it out and back in after making sure it’s chipper—not damaged or anything.
  1. Reset Network Settings: Head to Settings > General > Reset > Reset Network Settings. Just a heads-up, though—it erases your saved Wi-Fi passwords.
  1. Switch Off Call Blocking Features: Turn off things like “Silence Unknown Callers” for a bit and see if it makes a difference.
  1. Ring Up Your Carrier: If you’re still up a creek without a paddle, your carrier may have some answers or updates on network hiccups in your area.
  1. Consider a Factory Reset (Last Ditch Effort): If nothing else works, back up your stuff and think about a factory reset.
By picking off each of these possible culprits, hopefully, you’ll unearth why your calls keep dropping and set things right!
Quick Recap:
  • Bad network, pesky software glitches, damaged SIM cards, dodgy settings, old carrier settings, resource-munching apps, and hardware issues could all be playing a part in your dropped calls.
  • You can try improving signal strength, rebooting your phone, updating iOS and carrier settings, checking your SIM card, resetting the network, temporarily turning off some call features, chatting with your carrier, and as a last resort, going for a factory reset.
Why Do My iPhone Calls Keep Dropping? (Causes & Fixes)
Ugh, nothing’s more annoying than having your iPhone drop calls all the time. Whether you’re in the middle of an important conversation or catching up with an old friend, it’s a real buzzkill. Let’s dive into what’s causing this mess and how you can fix it.
Weak or Unstable Cellular Signal
First off, let’s talk signal strength. If your reception isn’t up to par, your call is gonna drop, no doubt about it.
How Do You Check?
  • Check out those signal bars at the top right of your iPhone. Less than two and you’re in trouble.
  • For the tech-savvy folks, dial *3001#12345#* and hit Call for the detailed signal strength in decibels (dBm). Anything worse than -100 dBm means you’re in the danger zone.
Fixes Coming Your Way:
  • Get to a better spot: Ditch places like basements or thick-walled buildings.
  • Enable Wi-Fi Calling: Go to Settings > Cellular > Wi-Fi Calling and switch it on. This will route calls through Wi-Fi when your cellular signal says goodbye.
  • Consider getting a cellular signal booster like weBoost. It’s like an amplifier for weak indoor signals.
Carrier/Network Issues
Sometimes the network gods aren’t on your side. Your carrier might be having a rough day or there might be something up with your account.
How Do You Check?
  • Google your carrier’s outage page or chat with pals using the same provider to see if they’re grappling with any issues.
Let’s Fix This:
    • Head over to Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings.
    • Heads up: This will wipe your saved Wi-Fi passwords and Bluetooth pairings.
  • Get in Touch with Your Carrier:
    • Make sure there’s no outage or account suspension.
    • Need a new SIM? Ask for a replacement if yours feels ancient.
Software Bugs or Outdated iOS
When was the last time you updated your iPhone? Outdated software might be the culprit here.
Let’s Sort This Out:
  • Update iOS:
    • Hop into Settings > General > Software Update and grab the latest version.
    • If prompted post an iOS update, tap Update under Settings > General > About.
  • Force Restart Your iPhone:
    • iPhone 8 or later: Quick press of Volume Up, quick press the Volume Down, and then hold the Side Button until you see the Apple logo.
    • iPhone 7/7 Plus: Hold down Volume Down and Side Button until it restarts.
Hardware Damage
Now, maybe the issue lies within hardware damage. Sometimes, it’s drop or water damage messing things up.
How Do You Check?
  • Inspect the SIM tray for damage or corrosion with a flashlight.
  • Try making calls using headphones or speakerphone. If they work, your internal microphone or speaker could be suspect.
What Can You Do?
  • Visit an Apple Store or Authorized Service Provider:
    • Run diagnostics from Settings > Privacy & Security > Diagnostics & Usage > Diagnostics Data.
    • If a hardware problem shows up, it might be time for a repair or replacement.
Overheating
Too hot to handle? Your iPhone might end up shutting down functions if it overheats.
Quick Fixes:
  • Keep it out of direct sunlight or hot places.
  • If your phone is sporting a thick case, take it off for a bit.
Conflicting Apps or Settings
Got some third-party apps like VPNs or ad blockers causing a ruckus? They might be messing with your calls.
What You Can Do:
  • Disable VPNs/Ad Blockers: Pop into Settings > General > VPN & Device Management and turn them off.
  • Test in Safe Mode:
    • After restarting your iPhone, avoid opening any third-party apps before making a call.
Sometimes calls drop due to radio interference from power lines, airports, or hospitals, believe it or not.
Here’s What You Can Do:
  • Step away from metal structures or electromagnetic sources.
  • Give Airplane Mode a toggle:
    • Swipe down from the top-right to open Control Center and tap the airplane icon. Wait 10 seconds, then toggle off.
Misconfigured Call Forwarding/Blocking
Sometimes call forwarding or blocking settings are accidentally turned on and mess things up.
Quick Check:
  • Ensure Call Forwarding’s off in Settings > Phone > Call Forwarding.
  • Dig into blocked numbers via Settings > Phone > Blocked Contacts.
When to Call in the Experts
If all else fails, taking your iPhone to an Apple Store for some hands-on help could be your best bet.
Final Tip: Always back your iPhone up with iCloud or on a computer before getting into heavy fixes like iOS updates or resets.
Why do my calls keep dropping on my iPhone and how can I fix it?
Let’s face it, dropped calls can drive anyone up the wall, especially when you’ve got something important to say. There could be a bunch of reasons why your iPhone is playing hard to get with your calls. Here are some down-to-earth fixes you might want to try:
  • Check Your Signal Strength: This might seem like a no-brainer, but honestly, if you’re in the middle of nowhere or stuck in a building with thick walls, you might not have the bars you need. See if moving around can help.
  • Restart Your iPhone: A quick way to give your phone a bit of a refresh. We’ve all been there—some weird glitch pops up, and powering your phone off and on does the trick.
  • Update iOS: Got the latest iOS? If not, there might be some bug fixes waiting to smooth out your phone’s hiccups. Head over to Settings and see if you can snag the newest version.
  • Reset Network Settings: Sometimes, the network settings just go haywire. You can reset them without batting an eye, but remember, you’ll have to re-enter those Wi-Fi passwords afterward.
  • Inspect Your SIM Card: You’d be surprised how often a SIM card might be acting like it doesn’t want to play nice. So, just take it out, give it a little TLC, and pop it back in.
  • Contact Your Carrier: There’s always the chance your service provider is having a rough day. Give them a ring—you never know what you’ll find out.
  • Disable LTE: If your calls keep dropping, try turning off that LTE for a bit. Sometimes sticking to the basics helps.
  • Update Carrier Settings: Carriers keep things updated to connect better. Head to Settings, and you might find an update waiting for you.
  • Restore Your iPhone: When all else fails, restoring to factory settings can be a lifesaver. Just make sure to back up your stuff before going back to square one.
Give these a whirl, and hopefully, your iPhone stops pulling the plug on your calls. If you’re still struggling, might be worth dropping by the Apple Store or checking out Apple Support online.
