Why Aren’t Voicemails Coming Through on My iPhone?
312 viewsPhone
If you’re not getting voicemails on your iPhone, it can be really annoying. Let’s dig into why this might be happening and how you can fix it:
Common Reasons You Aren’t Receiving Voicemails on Your iPhone
  • Outdated iPhone Software: Running with an old operating system can mess with voicemail tech.
  • Busy or No Answer: If you’re ignoring or not answering calls, people might not be leaving you voicemails.
  • Do Not Disturb Mode: Have this on? It could be stopping voicemails from coming through.
  • Voicemail Box Full: If your voicemail is full, you won’t get new messages.
  • Carrier Issues: Your carrier might be facing network problems, affecting voicemail delivery.
  • Call Forwarding Enabled: Calls might forward to another number if you have this on, halting voicemails.
  • Phone App or Network Issues: Glitches in the Phone app or your cellular network could also be causing trouble.
  • Incorrect Voicemail Password: If your voicemail password is wrong, accessing it won’t be possible.
  • Outdated Carrier Settings: Carrier settings needing an update might cause hiccups.
  • No Voicemail Setup: If you haven’t set it up, no voicemails will come your way.
Solutions to Get Your Voicemail Working Again
  • Update Your iPhone Software: Head to Settings > General > Software Update to install any updates.
  • Answer or Ignore Calls Properly: Either answer calls or let them go to voicemail instead of ignoring them.
  • Disable Do Not Disturb Mode: Go to Settings > Do Not Disturb and switch it off.
  • Delete Old Voicemails: Open the Phone app, hit the “Voicemail” tab, and swipe left on messages to delete them.
  • Contact Your Carrier: Get in touch with your carrier to handle any network issues.
  • Check and Disable Call Forwarding: Go to Settings > Phone > Call Forwarding and toggle it off.
  • Restart the Phone App: Force close the Phone app and relaunch it. Swipe up from the bottom to find the app and swipe up on it to close, then reopen it.
  • Refresh the Mobile Network Connection: Toggle Airplane Mode on and off, or turn Cellular Data off and back on.
  • Reset Network Settings: Go to Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings. This will wipe out network settings like Wi-Fi passwords.
  • Re-provision Visual Voicemail: Dial ##004# and hit call to deactivate all call forwarding settings. Then, dial *#5005*7672# and call to check your voicemail number and correct it if needed.
  • Manually Set Up Voicemail: Go to the Phone app, tap “Voicemail” and follow any “Set Up Now” instructions.
  • Create a Custom Greeting Message: In the Phone app, hit “Voicemail,” tap “Greeting” at the top left and follow on-screen prompts.
  • Check Voicemail Directly: Call your voicemail by tapping the Phone app, choosing the Keypad, and holding “1” until it dials.
  • Update Carrier Settings: Go to Settings > General > About to see if there’s an update for carrier settings.
  • Enable Wi-Fi Calling: Go to Settings, tap Cellular, select Wi-Fi Calling, and turn it on to improve voicemail over Wi-Fi.
By following these steps and checking each possibility, you should be able to get your voicemail working again on your iPhone.
Alright, so you’re not getting voicemails on your iPhone—isn’t that a pain? No worries, we’re here to tackle the problem with some handy tips and tricks. Let’s dive in.
Check Your Voicemail Setup
First thing’s first, have you properly set up your voicemail? If you switched carriers or plans recently, this could be the culprit. Here’s how to see if you’re good to go:
  • Pop open the Phone app.
  • Hit Voicemail down there on the bottom right.
  • If you see a Set Up Now option, just follow the steps to set that bad boy up!
Double-Check Call Forwarding
Ever heard of call forwarding? Sometimes your calls can be sent somewhere else, keeping them out of your voicemail’s reach. Here’s how to fix that:
  • Head to Settings > Phone > Call Forwarding.
  • Flip that switch to off (make sure it’s grey) if you want your voicemails to come right to you.
Tidy Up Your Network Settings
Your voicemail needs a steady network to work like magic. If your cellular or Wi-Fi calling isn’t cutting it, that might explain things.
  • Make sure Cellular Data is toggled on: Jump to Settings > Cellular.
  • If you’re in a signal desert, you might want Wi-Fi Calling on: Dive into Settings > Phone > Wi-Fi Calling and turn it up.
Give It the Ol’ Restart
Sometimes, switching it off and back on can sweep away those little pesky glitches standing between you and your voicemail.
  • Hold the power button until you see the slider.
  • Slide to power off, pause for a moment, then power it back up.
Get Hip with Carrier Updates
Every now and then, carrier settings updates can patch up network and voicemail snafus. Here’s how to see if one’s waiting for you:
  • Visit Settings > General > About, hang out there for a few seconds and see if you get prompted for an update.
Take it to the Extreme with a Network Reset
Alright, if you’re still having trouble, go ahead and reset your network settings. Who knows, this might just do the trick:
  • Find Settings > General > Transfer or Reset iPhone, then tap Reset Network Settings.
  • Heads up: It’ll wipe out saved Wi-Fi passwords and VPN setups, but your data’s safe.
If you’ve chipped away at all these steps and still no voicemails, maybe it’s time to ring your carrier’s customer support—they might have the magic wand for your issue.
Bottom line, if voicemails are playing hide and seek on your iPhone, it could be due to a mix-up in voicemail settings or call forwarding adventures.
You know what’s most likely? Either voicemail isn’t set up right or call forwarding is running wild.
You might not be seeing those voicemails because your voicemail settings need reviewing or call forwarding needs to chill.
Feeling Stuck With No Voicemails on Your iPhone?
Let’s Dig into the Problem!
Having voicemail issues with your iPhone can be a real headache. It usually boils down to carrier hiccups, a sprinkle of tech misfires, or just a bit of chaos in your setup. Don’t worry, though. Let’s check out what’s going on and see how we can sort it out.
What’s Going Wrong and How to Fix It
1. Carrier Trouble
Your carrier is basically the backbone of voicemail service. If they’re having a rough day, you might miss out on your voicemails.
  • How to Fix:
    • Give your carrier a buzz to see if something’s up with their voicemail services.
    • Ask for any updates on their end:
      Head over to Settings > General > About. If there’s an update, go ahead and follow the instructions.
    • Check if voicemail is part of your plan in the first place.
2. iOS Acting Up
Sometimes a pesky software update can throw voicemail delivery out of whack. It’s happened to folks after the 18.2.1 iOS update.
  • How to Fix:
    • See if there’s an iOS update you’ve missed:
      Hop into Settings > General > Software Update.
    • If it’s still being stubborn after updating, try restarting your phone or giving it a force restart.
3. Setup Snags
If your voicemail settings are off-kilter, messages might not be getting through.
  • How to Fix:
    • Set up your voicemail from scratch:
      Open the Phone app > Voicemail tab > Set Up Now and just follow the steps.
    • Double-check “Blocked Contacts” to make sure calls aren’t getting blocked:
      Head over to Settings > Phone > Blocked Contacts.
4. Weak Signal Blues
Poor network connectivity might be holding back those voicemails.
  • How to Fix:
    • Try toggling Airplane Mode to shake things up:
      Swipe into Control Center > Flip on Airplane Mode > Wait a bit > Turn it back off.
    • Test switching between Wi-Fi and cell data to see which works better.
5. Missing Alerts
If notifications for voicemail are turned off, you won’t even know they’ve arrived.
  • How to Fix:
    • Turn those notifications back on:
      Go to Settings > Notifications > Phone > Allow Notifications.
    • Check that “Badges” and “Sounds” are on so those alerts can pop up.
6. App Clash
Sometimes apps meant to manage calls can throw a wrench in your voicemail operations.
  • How to Fix:
    • If you sniff out any mischievous apps, disable or delete them:
      Navigate to Settings > General > iPhone Storage and check out your recent app tunnels.
Handy Tips
  • Mind the Space: Make sure your phone has enough room for voicemails (Settings > General > iPhone Storage).
  • Bear in Mind: Some carriers need you to subscribe to visual voicemail, so give your provider a shout.
If all else fails, why not ping Apple Support or swing by an Apple Store to get some professional help?
Alright folks, if you’re banging your head against the wall because your iPhone isn’t picking up voicemails, fear not! Here’s what you can do to sort things out once and for all:
  • Got Signal? First things first, check your phone’s connection to the network. Voicemails can’t work their magic without a solid cellular connection.
  • Carrier Settings on the Fritz? Head over to Settings > General > About. If you spot any updates, go ahead and hit ‘em up; this could be just the fix you need.
  • Have You Tried Turning It Off and On Again? Classic move, but it often works like a charm. Power your phone down and give it a restart after a few seconds. You might be surprised how many tech gremlins this can vanquish.
  • Voicemail Setup Check: Make sure that little voicemail icon isn’t giving you the runaround. Press and hold the number 1 key or check the Voicemail tab in your Phone app to see if everything’s in order.
  • Network Settings Reset: Another trick up your sleeve is heading over to Settings > General > Reset > Reset Network Settings. Heads up though, it’s going to wipe out those Wi-Fi networks and Bluetooth pairings, so remember your passwords!
  • Running the Latest iOS? Pop over to Settings > General > Software Update. Don’t be shy—keeping your software up-to-date could save you a headache or two.
  • Password Drama with Voicemail? If you’re asked for a voicemail password, make sure you’ve got it right. An incorrect password can throw a wrench in the works.
  • Carrier Chat Needed? After all that, if you’re still running into issues, give your carrier a shout. It might be on their end, and they may have just the trick to get you back on track.
  • Still Stuck? Apple’s Your Friend: When all else fails, head straight to Apple Support. They’re the real pros and might have the answer you’re looking for.
There you have it! These tips are pretty much the go-to for getting your iPhone voicemail back in business. Just dive in and tackle them one by one.
