How Come I’m Not Getting Calls from One Person on My Android?
428 viewsPhone
Sometimes, missing calls from just one person on your Android can be super annoying. Here’s what might be going on and how to fix it:
Reasons:
  • Call Blocking Settings: You might’ve accidentally put their number on your block list. If that number is blocked, your phone will automatically reject their calls.
  • Do Not Disturb Mode: When Do Not Disturb is on, and your friend isn’t on the exception list, you probably won’t hear their calls. This mode is meant to keep distractions at bay, so double-check if they’re listed as an exception.
  • Call Forwarding Configuration: If you’ve got call forwarding enabled, calls might be bouncing to another number. It’s helpful for rerouting calls, but it can mess up your incoming calls if set up wrong.
  • Network Issues: A bad signal or network problems can affect call connectivity. If you’re in a place with poor reception or if your carrier is facing issues, calls from certain people might not come through.
  • SIM Card Problems: A damaged or poorly inserted SIM card can mess with call reception. If the SIM card is acting up, it might stop you from getting calls from specific numbers.
  • Caller’s Side Issues: Maybe they’ve blocked your number, have Do Not Disturb mode on, or have call forwarding set up on their end. This could also be causing your reception problems.
  • Third-Party Apps: Some apps you installed might be conflicting with call functionalities or overriding block settings, leading to missed calls.
  • Software Glitches: Minor bugs in your phone software could be making it act up, leading to missed calls.
Solutions:
  • Check Blocking Settings: Open the Phone app, tap the three-dot menu, go to “Settings,” and check “Call blocking” or “Blocked numbers.” If your friend’s number is there, unblock it.
  • Adjust Do Not Disturb Mode Settings: Head to “Settings” > “Sound & vibration” > “Do Not Disturb” and either turn off the mode or add your friend to the exceptions list to make sure you get their calls.
  • Verify Call Forwarding Settings: Dial *#21# to see if call forwarding is enabled. If yes, follow the prompts to disable it. Alternatively, go to “Settings” > “Network & internet” > “Call forwarding” to check and adjust these settings.
  • Improve Network Connectivity: Move to a spot with better reception or restart your phone/toggle Airplane Mode to refresh your connection. If it’s a more significant issue, contact your service provider.
  • Inspect and Repair the SIM Card: Power down your phone, take out the SIM card, inspect it for damage, clean it gently if needed, and reinsert it. If it’s still not working, try it in another device or get a replacement from your carrier.
  • Address Caller-Side Issues: Ask your friend to check if they’ve blocked your number, enabled Do Not Disturb, or set up call forwarding. Sometimes, the issue is on their end.
  • Uninstall Conflicting Third-Party Apps: Boot your phone in Safe Mode and see if you can get calls. If you can, start uninstalling recently added apps until the problem is fixed.
  • Update or Reset the Device: Go to “Settings” > “System” > “Advanced” > “System update” to install any updates, which might fix bugs. If the issue persists, reset network settings (but remember to back up your data first): “Settings” > “System” > “Reset options” > “Reset Wi-Fi, mobile & Bluetooth”.
  • Restart the Phone: Sometimes, a quick restart can fix those annoying glitches. Press and hold the power button, then select “Restart.”
If none of these fixes work, back up your data and consider contacting a professional repair service or the device manufacturer for help.
Hope this does the trick!
Got a situation where you can’t get calls from just one person on your Android? Well, join the club. It happens, and there are a few things you can try to sort it out. Let’s break this down so you can get back to chatting without hiccups.
Blocked Numbers
First things first, make sure you haven’t accidentally blocked their number. Android phones make it super easy with the block feature, which is awesome until it happens to the wrong person. Here’s how to check:
  1. Open up your Phone app.
  2. Click on the three dots (or “More”) in the top right corner.
  3. Hit “Settings” and then “Blocked numbers.”
  4. Give the list a look-see. If the person’s on there, simply unblock them.
Auto Reject List
On Samsung or similar phones, there’s something called the auto reject list. That might be the culprit:
  1. Jump over to Settings on your Home screen.
  2. Tap “Call” or “Phone.”
  3. Select “Call rejection” then “Auto reject list.”
  4. If you spot the number, delete it from this list pronto.
Do Not Disturb Mode
Next, check if Do Not Disturb (DND) is messing with your groove. When this is on, calls can be blocked altogether:
  1. Swipe down from the top of the screen to hit Quick Settings.
  2. If DND is lit up, just tap to turn it off now.
  3. Or head to Settings > Sound & vibration > Do Not Disturb, and make sure it’s off.
Network Issues
Sometimes, it’s not rocket science—just network gremlins doing their thing:
  • Check that your signal isn’t on vacation somewhere.
  • Toggle Airplane Mode on for about 30 seconds. Turn it back off and cross your fingers for a reset.
  • If you’re brave, power off your device, eject the SIM card, then stick it back in carefully.
Call Forwarding
While we’re troubleshooting, make sure those calls aren’t being forwarded somewhere unexpected:
  1. Open Phone app again.
  2. Hit that three-dot menu, and go to “Settings.”
  3. Dive into “Supplementary services”—or whatever call-related options you have.
  4. Double-check that forwarding options are off.
Third-Party Apps
These apps can be a blessing for call management, but also a nuisance when things aren’t right:
  • If you’ve installed call-blocking apps lately, maybe they’re getting in the way. Try disabling or uninstalling them.
  • Peek into the settings of these apps to ensure they’re not blocking your friend’s calls.
Software Updates
Even software updates can play a role in this, keeping calls from getting through:
  • Hop to Settings > System > Software update and see if there’s something fresh you haven’t downloaded yet.
Contact Your Carrier
If you’re still blocked, call up your mobile carrier. Sometimes the issue is with them and not your device.
All in all, if you’re pulling your hair out over not receiving calls from one person, start by checking if their number’s blocked or auto-rejected, flip DND off, verify network and call settings like Airplane Mode and call forwarding, look at third-party app messiness, grab any software updates, and give your carrier a call if needed. You’ve got this!
Why Am I Not Receiving Calls from One Person on Android?
You’d think that not receiving calls from just one person would be a quick fix, but sometimes these tech hiccups get unruly. Whether it’s a bug in your system, a network glitch, or a mistake in handling settings, there are several places this problem might be lurking. Let’s break it down and see how you can get things back to normal without pulling your hair out.
1. The Contact’s Blocked or Restricted
What’s up? Your phone might be treating this caller like an unwanted guest. Android lets you block numbers, which keeps them silent.
Quick Fix:
  • Pop open your Phone app, hit that three-dot menu (⋮), then dive into Settings and check out Blocked numbers. See if that pesky number’s in there and let it loose by tapping Unblock.
  • If you’ve got a carrier-specific block running (like Verizon’s Call Filter), log into your carrier account online or just call them up for a quick unblock.
2. Do Not Disturb Mode Is On
What’s going on? DND mode is like an emergency switch that blocks all the hoopla. But if you’ve set it to let through only certain calls, this could leave some folks hanging.
Fix it:
  • Check that notification panel—if you spot the Do Not Disturb icon (looks like a moon), tap it to cut DND off.
  • Want to tweak DND settings? Head over to Settings, scroll to Sound & vibration, then Do Not Disturb and check who’s allowed through―make sure your buddy’s there too.
3. Call Forwarding or Network Issues
What might be happening? Call forwarding settings or lousy network signals could be causing your calls to drop or divert unexpectedly.
Get it sorted:
  • Fire up your Phone app, tap that menu (⋮), meander over to Settings, and check Call forwarding. Set it to Do not forward.
  • Put your network to the test: Try making a call to or from another number. If it bombs, toggle Airplane mode on/off or hit reset on your network settings (Settings > System > Reset options > Reset Wi-Fi, mobile & Bluetooth).
4. SIM Card or Carrier Issues
What’s happening here? A rebellious SIM card or some tricky carrier restrictions might have decided to block this specific number.
To fix:
  • Pop out your SIM card and slide it back in. If you’ve got another device, see if it works there.
  • Reach out to your carrier just to double-check there are no number blocks or restrictions hanging around.
5. App-Specific Glitches
What’s the story? Your trusty Phone app—or a third-party dialer—might have developed a bug that’s messing with your call flow.
Try this:
  • Clear the cobwebs in your Phone app cache: Roll over to Settings, tap Apps, pick Phone app, and hit Storage then Clear Cache.
  • Hop into the Google Play Store and update your Phone app.
  • Switch off any call-blocking apps temporarily to see if that’s the culprit.
6. Software or OS Bugs
What’s the hiccup? Outdated software can turn into a party pooper, leaving you unable to receive calls.
For a solution:
  • Get any pending OS updates installed (Settings > System > Software update).
  • Try booting into Safe Mode (press Power + Volume Down until the logo flashes up) to sniff out any third-party app mischief.
7. Contact-Saving Errors
What’s the issue? Maybe the caller’s number got punched in wrong or listed as spam.
Fix it up:
  • Double-check the saved contact number—toss in that country code if it’s missing.
  • Take the contact off your list and then add it again.
8. Google Spam Filtering
What’s happening? Google’s Phone app might think your caller’s spam, and it’s throwing their calls into the nether.
How to sort it:
  • Pop open the Phone app, tap ⋮, sneak over to Settings > Spam and Call Screen, and switch off Filter spam calls.
  • Swing by the Spam history section to restore any calls that were flagged by mistake.
Final Touches
  • Tell the person trying to reach you to hit you up via another phone number or a messaging app like WhatsApp—just to rule out any funkiness on their end.
  • Factory resetting is your last resort if you’ve tried it all (head into Settings > System > Reset options). Seriously—back up your data first!
Try picking through these steps and you’re likely to find the problem. If your calls still aren’t coming through, maybe swing by a service center or chat up your carrier and see if they can lend a hand.
So, you’ve got a stubborn situation where calls from a particular contact just aren’t popping up on your Android? It’s a little frustrating, huh? Let’s dive into some fixes you can try:
First up, double-check if their number’s got thrown onto your blocked list by accident. Open your Phone app, hit those three little dots up top, and navigate over to Blocked numbers. Spot anything suspicious? Free them from phone jail!
Next, make sure you typed their digits right and that they haven’t changed without giving you the heads up. A simple typo could be all it takes to mess up your connection.
You might also want to verify if Do Not Disturb mode is inadvertently acting as a call wall. Head into Settings and get rid of any unwanted barriers there.
Could be a network hiccup, on your end or theirs. A quick restart often works wonders. If you’re feeling adventurous, take out your SIM card and pop it back in. Sometimes, it just needs a little jiggle to work fine.
Skim through your app permissions to ensure the Phone app has everything it needs to function smoothly.
Software outdated? Get yourself to System updates and grab any new releases—it keeps things running snug.
And if it still doesn’t budge, clear the cobwebs from the Phone app’s cache and data. It’s like giving your phone a tiny espresso shot to freshen things up!
Resetting network settings can also wipe away stubborn configurations—don’t worry, it’s not as drastic as it sounds.
Lastly, if you’re still stuck, reaching out to your carrier might shed some light on hidden restrictions or weird technical glitches.
By sorting through these steps, you should figure out why calls from that one specific contact are MIA on your Android. Fingers crossed!
