How does Guided Access work on my iPhone, and when would I use it?
660 viewsPhone
1 Answer
What is Guided Access on iPhone and how do I use it?
Alright, here’s the scoop on Guided Access for your iPhone—it’s this nifty feature that locks your device to a single app, perfect for keeping distractions at bay or controlling what parts of an app can be used. Parents and teachers love it because it makes sure kiddos stay focused on the task at hand, whether it’s learning or just playing one game instead of bouncing between apps.
So, how do you turn it on and use it?
Setting Up Guided Access:
  • First off, head to the Settings app.
  • Go to Accessibility and find Guided Access.
  • Flip the switch to turn it on, and then dive into Passcode Settings to set a passcode. If you’re into the fancy stuff, you can set up Face ID or Touch ID for entry.
Kicking Off a Guided Access Session:
  • Open up the app you want to lock in.
  • Tap the Side or Home button three times—depending on your iPhone model, of course.
  • Now, customize the session:
    • Hit Options to pick which gadgets work—like the volume buttons or whether the screen should respond to touch.
    • Draw circles on parts of the screen to stop touch in those spots. It’s like squaring out areas you don’t want interrupted.
  • Ready to roll? Tap Start up top.
Wrapping Up the Session:
  • Yup, you guessed it. Triple-click the Side or Home button again.
  • Punch in your passcode, or go for the slick Face ID/Touch ID way to end things.
Extra Cool Stuff:
  • Use the Time Limits within Guided Access settings to decide how long the session runs—like setting snooze for app use.
  • Enable the Accessibility Shortcut to jump to Guided Access using a quick shortcut maneuver.
This feature is such a lifesaver for keeping the focus and ensuring control over app usage. Whether you’re teaching, parenting, or just looking to limit yourself using tech, Guided Access is where it’s at. For the full lowdown, check out Apple’s official support page.
