Why Isn’t My TV Showing Up as a Sound Device in Windows 10?
359 viewsTelevisions
If you’re dealing with the hassle of a TV not showing up as a sound device in Windows 10, it’s kind of a pain, right? Maybe it’s due to driver quirks or settings that have gone haywire. Anyway, let’s roll up our sleeves and dive into how you can fix this.
First things first, take a look at those HDMI connections. Give them a nudge. Could be something as goofy as a loose cable messing with you. Can you switch ports on the TV or try out another cable? It’s worth a shot.
Hit up the speaker icon chilling in your system tray.
  1. Select “Sounds” from the menu popping out.
  2. Head to the “Playback” tab.
  3. If your TV’s there but not the chosen one, right-click on it and pick “Set as Default Device.”
  4. Smack “OK” to lock it in.
If your TV’s playing hide-and-seek, keep on reading.
Could be those drivers need some love. Here’s how you tackle it:
  1. Press Windows + X and choose “Device Manager.”
  2. Expand the “Sound, video and game controllers” menu.
  3. Right-click your audio gizmo (including HDMI Audio) and hit “Update driver.”
  4. Go for “Search automatically for updated driver software.” Follow the breadcrumbs.
No luck yet? Time to uninstall and reinstall those drivers:
  1. In Device Manager, right-click your audio device and choose “Uninstall device.”
  2. Restart your computer; it’ll do the reinstall dance for you.
Now here’s a curveball; your display settings might be the culprit:
  1. Right-click your desktop and select “Display settings.”
  2. Scroll to where the multiple displays settings hang out.
  3. Make sure your TV is showing up as an extra screen.
  4. Activate it if it’s playing possum.
Why not let Windows work its magic with its built-in fixer-upper tools?
  1. Open up Settings (Windows + I).
  2. Tap “Update & Security,” then hit “Troubleshoot.”
  3. Go for “Additional troubleshooters” and find “Playing Audio.”
  4. Run this puppy and go with whatever tips it spits out.
If you’re still stuck, maybe resetting sound settings is the ticket:
  1. Head back to the Sound window (right-click the speaker icon > Sounds).
  2. In the Playback tab, right-click each device (including your TV) and pick “Properties.”
  3. Skedaddle to the “Advanced” tab.
  4. Tap “Restore Defaults,” and apply those changes.
Find out if it’s your PC or TV at fault:
  • Hook up another device, say a laptop or console, via HDMI and check if it sends sound to the TV without issues.
  • If the other device works but your PC refuses to play ball, dive deeper into the software settings.
So, by systematically working your way through these steps, starting with easy fixes like checking cables and updating drivers, you’ll crack this nut eventually. It’s all about getting that TV recognized as an audio output on your Windows 10.
Trying to get your TV to show up as a sound device in Windows 10 can be a bit of a headache, but don’t sweat it; I’ve got some handy tips that should help you out:
1. HDMI Cable and Ports:
Alright, this one’s simple. Make sure the HDMI cable is snugly plugged into both the TV and your PC. If you’re still having issues, grab another cable or try a different port just to check if the hardware is acting up.
2. Making Your TV the Default Playback Device:
Right-click the sound icon down by the clock and pick “Sounds.”
Jump to the “Playback” tab and right-click in the blank area to ensure “Show Disabled Devices” is ticked.
If your TV pops up, right-click to enable it and make it your default sound device. Easy peasy!
3. Update Audio and Display Drivers:
Hit Win+X and choose “Device Manager”—it’s the secret backdoor of troubleshooting.
Expand “Sound, video and game controllers” and “Display adapters.”
Give your audio and display devices a right-click and check for updates.
4. Tinkering with Sound Settings:
Navigate to Settings > System > Sound.
Under “Choose your output device,” pick your TV if you see it.
5. Restart Audio Services:
Press Win+R, type “services.msc,” and hit Enter.
Find “Windows Audio” and “Windows Audio Endpoint Builder.”
Right-click on each and choose “Restart.” Sometimes, they just need a little nudge.
6. Reinstall Audio Drivers:
Open up Device Manager again, right-click on your audio device, and select “Uninstall device.”
Reboot your computer, and let Windows do its auto-reinstall thing.
7. Check for Windows Updates:
Head over to Settings > Update & Security > Windows Update.
Check for updates and install whatever’s waiting for you. You never know when a hidden update solves the mystery.
8. BIOS and Hardware Checks:
Mosey on over to your PC manufacturer’s website to grab the latest BIOS update.
Double-check your HDMI settings in BIOS, if that’s an option. Sometimes, it’s just a hidden switch waiting to be flipped.
That should cover the bases to get your TV listed as a sound device in Windows 10. If you’ve been through all this and it’s still not working, the official Microsoft support or your device manufacturer’s support might have the magic answer. Hang in there!
