Why is My Surface Touchscreen Not Working and How Can I Fix It?
268 viewsLaptops
re_answer:
So, your Surface touchscreen decided to take a coffee break? No worries, let’s dive into some fixes here.
  • First off, give it a good ol’ restart: Sounds simple, but you’d be surprised how often a reboot can kick things back into gear. Just hold down the power button for about 30 seconds, let go, and then press it again.
  • Updates are your friend: Make sure your Surface is running the latest Windows updates. These updates often patch up issues. Head over to Settings > Update & Security > Check for updates.
  • Touchscreen feeling off? Time to recalibrate. Jump into Control Panel > Hardware and Sound > Tablet PC Settings and click Calibrate under the Display tab.
  • Troubleshoot it, Sherlock-style: Use the built-in troubleshooter. Go to Settings > Update & Security > Troubleshoot > Additional troubleshooters > Hardware and Devices.
  • Drivers might need a refresh: Sometimes they decide to take a nap. Check them out in the Device Manager under Human Interface Devices. Find the HID-compliant touch screen, right-click for Update driver or try uninstalling and rebooting.
  • Don’t forget the firmware: Some Surface models need love in the form of firmware updates. Hop over to the Microsoft Support page to see what’s up with your model.
  • Roll it back with a system restore: If the trouble kicked in after a change you recently made, this could save your day. Head to Control Panel > Recovery > Open System Restore.
  • Still no dice? Might be time to chat with the experts at Microsoft. Pop by their Support website and explore repair options.
With a little luck, one of these fixes will sort things out! If it’s a hardware hiccup, though, an expert’s eye might be needed.
If your Surface\’s touchscreen is being stubborn and not responding, don’t throw it out the window just yet—there are a few things you can try to fix it!
First off, let’s start with the easy stuff. It might sound silly, but sometimes dirt, dust, or smudges can make your touchscreen act up. Grab a clean, soft cloth and gently wipe down the screen. Dampening it slightly with water helps but skip the harsh chemicals.
Now, if that doesn’t do the trick, it might be a software thing. Sometimes, the drivers just aren\’t playing nice. You can try running the hardware troubleshooter by poking around in the Control Panel—just look for “Troubleshooting” and let the system do its thing. And, of course, make sure your device is up-to-date because Windows updates might have the magical fix tucked away in there.
Popped into Device Manager yet? You should. Find your touchscreen under “Human Interface Devices,” right-click it, and see if an update or a quick disable/re-enable might rekindle the spark.
Calibration could be another headache. If touches aren\’t landing where they should or are completely ignored, hop into the calibration settings through the search bar and follow the steps for recalibration.
Don’t underestimate a classic restart, either. Hold down that power button for about 30 seconds and then fire it back up—sometimes a fresh start is all it needs.
Now, it could be something a bit scarier, like the hardware itself acting up. If you see any flickering or odd visuals, testing the device with a keyboard or mouse can help rule out other issues. And if you’re facing a truly stubborn problem that refuses to go away, getting in touch with Microsoft Support might be your best bet—they know their devices inside and out.
A couple of parting tips: temporarily disable the touch driver if you’re fed up with ghost touches, and skip any third-party screen protectors that might not get along with your Surface.
It might take a bit of trial and error here, but with some patience, most of these touch troubles can be sorted out. And hey, if it’s a hardware bug, a pro intervention might just be the ticket!
Why Isn\’t My Surface Touchscreen Working?
If your Surface touchscreen has decided to go on strike, don’t panic just yet. There could be a bunch of reasons why it\’s playing hard to get—anything from a random software hiccup to drivers that haven\’t seen updates in ages, or even something as annoying as hardware giving up. Let\’s walk through some straightforward steps that just might save the day, or at least help you figure out what\’s going wrong.
Step 1: Is It Software or Hardware?
Alright, first things first, let\’s see if it\’s the software or the hardware\’s fault. You can do a quick test in the UEFI firmware menu. This step might sound like tech jargon, but stick with me—it\’s easy peasy. Turn off your Surface, hold the volume up button, push the power button, and keep holding until you see that familiar Surface logo. If the touchscreen plays nice here, but not in Windows, it’s probably a driver or software issue. No go in the UEFI? We might be looking at hardware trouble here.
Step 2: Give It a Restart
When in doubt, restart! Seriously, it’s like a catch-all solution for tech woes. Try the usual restart through the Start menu, or go for the hardcore version by holding down the power button for a good 30 seconds. This little trick works more often than you\’d think.
Step 3: Update Those Drivers
Updates are really important, not just because they fix bugs but because they could breathe new life into your device. First off, make sure your Windows and Surface updates are the latest and greatest. Then, jump into Device Manager (just type it in the taskbar search) and check those \”Human Interface Devices.\” Give ‘em a right-click and uninstall, then let Windows do its thing and reinstall them. Fresh drivers, who dis?
Step 4: Calibrate for Accuracy
If your taps are acting wonky, a miscalibrated screen could be to blame. Type “calibrate” into the search and follow the instructions in Tablet PC Settings. A little calibration magic might just get those taps to behave.
Step 5: If All Else Fails, Dive Deeper
Still no joy? Time to put on the detective hat. Examine the drivers again for conflicts, and take a peek in the Event Viewer (find it under Windows Logs > System) for any warning signs. If you\’re still banging your head against the wall, maybe a device reset will clear things up. Just remember to back up your stuff first—don’t learn that the hard way like I did!
When it’s all said and done, if none of these steps work, tiptoe towards the possibility of a hardware mishap. Maybe it\’s time to call in the professionals or get a service order from Microsoft. Fingers crossed it doesn\’t come to that!
