How Can I Stop My PS5 from Turning On with My TV?
408 viewsTelevisions
So, you’re dealing with the PS5 doing its own thing every time you flick on the TV, huh? That\’s HDMI-CEC for you! It’s this sneaky little feature that lets devices chat over HDMI cables. Sometimes, too much chit-chat. But don’t worry, we can tone it down.
Let’s dive into tweaking your PS5:
First off, fire up your PS5 and get yourself onto that main menu. Spot the Settings icon—you know, the little cog wheel hanging out in the corner. Click on that and head into System > HDMI.
Now, here it comes: the HDMI Device Link option. Turn that off if you’re tired of the PS5 waking up with the TV. But hey, if you just want to fine-tune what wakes what, check out “Enable One-Touch Play” and “Enable Power Off Link.” You can decide which of these guys you can live without.
Here’s the thing, some TVs come with their own version of HDMI-CEC. It\’s got different names like “SimpLink” for LG or “BRAVIA Sync” for Sony. If messing around on the PS5 doesn’t do the trick, maybe hit up your TV settings and see if turning it off there helps.
Now, if you\’re juggling a ton of gadgets and still want some of that auto-switch magic, consider juggling or tweaking those settings instead of flat-out killing them.
By working through these steps, you\’ll get your peace back and keep your PS5 from getting all enthusiastic every time you watch TV.
So you\’re tired of your PS5 booting up every time you turn on your TV? Yeah, that can be pretty annoying. It\’s usually down to this thing called HDMI-CEC, which makes your devices all buddy-buddy so they turn on and off together. It\’s nifty unless it starts doing stuff you didn\’t ask for! Let\’s figure out how to stop that from happening.
What\’s Going On?
Most of the time, your PS5 is just trying to be a good pal by mimicking your TV\’s power moves. HDMI-CEC is behind this secret handshake. While this feature can be handy, it can also cause your console to power up when you\’re not in gaming mode.
Solutions on the Table
1. HDMI-CEC/Device Link Shenanigans
Why? Your PS5 is set to link up its power status with the TV via HDMI-CEC.
Fix It:
  • Dive into Settings > System > HDMI on your PS5.
  • Turn off \”Enable HDMI Device Link.\”
  • For good measure, unplug both the TV and PS5 for about 30 seconds and then plug them back in. Resetting now and then is good.
2. Outdated Software
Why? Sometimes outdated firmware or software acts weird and messes up HDMI behavior.
Fix It:
  • Update your TV’s firmware by checking the manufacturer\’s website for specifics.
  • Make sure your PS5 is up-to-date by heading to Settings > System > System Software > Update System Software.
3. Power Settings Mess Up
Why? Confusing power modes can send mixed signals to the PS5.
Fix It:
  • Revisit your PS5’s sleep settings: Settings > System > Power Saving > Set Features Available in Rest Mode.
  • Turn off things like \”Stay Connected to the Internet\” and \”Enable Turning On PS5 from Network\” to keep the console chilled out.
4. Cables and Ports Troubles
Why? Faulty cables or bad ports can send scrambled signals.
Fix It:
  • Use a certified HDMI 2.1 cable for a more stable connection.
  • Try using a different HDMI port on your TV to check if the port isn’t the root of the problem.
Other Tricks to Try
If you\’re still stuck, here are a few more tricks to consider:
  • Reset Your TV\’s CEC: Some TVs (like the ones from Samsung or LG) let you reset CEC settings. If you have manual handy, look up how to disable things like Anynet+ or SIMPLINK.
  • Physically Disconnect HDMI: You could use a CEC blocker adapter or unplug the HDMI cable when you’re not gaming to keep unwanted signals at bay.
  • Check Other Devices: Sometimes peripherals like soundbars or other gadgets connected via HDMI-ARC might be the culprits. Try disconnecting these to see if that helps.
Some Final Tidbits
  • HDMI 2.1: If your TV has this, it often comes with better CEC stability. Double-check that your TV’s CEC can play nice with the PS5’s settings.
  • Power Supply Issues: Rarely, weird power supply issues can mess with device behavior. A surge protector or a UPS might help smooth things out.
Hopefully, sorting out these issues can stop your PS5 from hopping on uninvited. If you’re still having trouble, a call to Sony Support or your TV’s manufacturer might be in order.
If you’re tired of your PS5 coming to life every time you switch on the TV, don’t worry, there’s a fix for that! Here’s what you can do:
  1. Fiddle with the HDMI Device Link on Your PS5:
    • Turn on your PS5 and dive into Settings.
    • Head over to System and then click on HDMI.
    • Find Enable HDMI Device Link and just switch it off.
    • With this, your PS5 won’t get that automatic wake-up call from your TV anymore.
  2. Tweak Your TV’s Settings:
    • Jump into your TV’s settings menu.
    • Keep an eye out for the HDMI-CEC settings; these might be labeled differently based on your TV brand, like Anynet+ for Samsung or Bravia Sync for Sony, crazy right?
    • Just turn off the HDMI-CEC feature, and that should do the trick.
  3. Try a Non-CEC Port:
    • If your TV’s got a couple of HDMI ports and not all of them are CEC-enabled, plug your PS5 into one that isn’t CEC-enabled.
With these tweaks, your PS5 should mind its own business and not fire up when you don’t want it to. If things still seem a bit off, it might be a good idea to grab your TV’s manual and poke around in there for more guidance.
