What’s the Best Sound to Get Water Out of My Phone?
280 viewsPhone
Here’s the Lowdown: Can Sound Really Get Water Out of Your Phone?
If you’ve ever panicked over dropping your phone in the drink, you’re not alone. Water and phones are sworn enemies, mainly because moisture can short-circuit your tech or cause corrosion over time. There’s this buzz around using sound—yes, sound waves—to push water out, but does it actually work? Let’s dive into that and see what options you have.
Why Water is a Phone’s Worst Nightmare
When your phone takes a dip, here’s what can go wrong:
  • Short circuits: Water conducts electricity, which can wreak havoc on the circuits.
  • Corrosion: Minerals in the water can slowly eat away at metal parts.
  • Sound issues: Water in the speakers can make everything sound like it’s underwater.
Even if your device has an IP67 or IP68 rating, which means it can handle some wetness, don’t push your luck—those ratings aren’t foolproof.
The Deal with the Sound Method
The gist of this method is to use low-frequency sounds—about 165–175 Hz—to vibrate water out of your phone’s speaker or ports. There are apps and YouTube videos that produce these frequencies.
Does it actually work?
  • Sort of: It might help with superficial water in the speakers, but it’s no magic bullet for moisture deep inside your phone.
  • You’ll need more: Use sound alongside other drying techniques (we’ll get to those in a minute).
Steps to Take if Your Phone Gets Wet
Start Here
  1. Shut it down: Turn off your phone to dodge short circuits.
  2. Dry the outside: Use a microfiber cloth and keep the phone steady—no shaking!
  3. Open it up a bit: Remove any cases and pull out the SIM tray to help air circulation.
Trying Out the Sound Method
If you want to give this a shot:
  1. Find a reliable app (like \”Sonic Water Eject\”) or search for a 165 Hz video on YouTube.
  2. Face the speaker down on a dry surface.
  3. Play the sound at medium volume for 15–30 seconds.
  4. Repeat a couple of times, checking if the sound improves.
Watch out:
  • High volumes can blow out the speakers.
  • If the phone’s been underwater for ages, this probably won’t help.
Tried-and-True Drying Techniques
  1. Skip the rice: Instead, use silica gel packets—they’re way more effective.
  2. Let it breathe: Leave your phone out in the open to air dry for a day or two.
  3. Alcohol swabs for ports: A bit of isopropyl alcohol on a cotton swab can help clean and dry out the ports.
Time for the Experts
If your phone’s still acting up:
  • Take it to a repair shop: Let professionals handle disassembling and cleaning.
  • Heating it up (like with a hairdryer) isn’t advised—it could cause even more damage.
Some Tips to Keep Your Phone Dry
  • Steer clear of water, even if your phone says it’s water-resistant.
  • Use waterproof cases for activities like swimming or being caught in the rain.
  • Clean ports regularly using a dry toothbrush.
The Real Deal on Sound
Sound might budge some water out, but what if it’s tucked away inside your phone? Vibrations just can’t reach those tricky spots. Plus, water leaves behind mineral gunk, and no tone in the world will wipe that away. The clock is ticking—so don’t delay in taking action!
Bottom Line: If you think sound might help with your waterlogged speakers, go ahead and try it. But lean on good old-fashioned drying methods and professional help if necessary. Time is of the essence when dealing with water damage!
Alright, so let\’s talk about a nifty little trick for drying out your phone\’s speaker using sound. It\’s basically a way to shake things up, literally, with sound waves to push out the water that\’s sneaked in there. Imagine blaring music to jostle a stuck door open; that\’s the idea here, but with water droplets.
So, here\’s how this whole sound ejection thing goes down. You crank up a bass-heavy tone around 20 Hz to 200 Hz. Why bass? It\’s got enough oomph to vibrate the speaker without messing things up. When the speaker vibrates, those droplets trapped in there find their way out. It\’s like a gentle coaxing out of hiding. Apple Watches have a similar feature if you\’ve ever noticed it, and there are online gigs like Fix My Speakers that do the same thing.
Now, people say around 65 Hz, 100 Hz, or 150 Hz are sweet spots for frequencies, so play around with those and see what clicks with your specific phone. You can try online tools or grab apps like Sonic for iOS to make it happen. Easy peasy, just hit play and let it do its thing.
Here’s a quick rundown:
  • Max out your phone’s volume.
  • Head to a water ejection website or app, and have your phone chilling on a flat surface with the speaker facing down — gravity’s your partner here.
  • Hit that play button for 30 to 60 seconds, and watch out for tiny drops getting booted out. If it takes a couple of rounds, no worries, but don’t go overboard with playtime to keep your phone safe.
Honestly, these frequencies aren\’t a wild experiment; they match the typical audio energy your phone deals with regularly. Still, it\’s not a fix-all for when your phone takes a real dunk. If that ever happens, just switch it off and consider a pro repair. Better safe than sorry, you know?
Got water in your phone’s speaker? Here’s how you can tackle it:
  1. Hit the Right Note:
    • Try playing a sound frequency at about 165Hz. This particular tone can help shake the water loose. You’ll find apps and websites specifically made for this—just crank up your phone’s volume and let it do its thing.
    • Online sites like FixMySpeakers have these tools ready to use. Just queue it up and listen for improvement.
  2. Get an App:
    • There’re apps out there that pulse sounds to push the water out, like ‘Speaker Cleaner.’ Check your app store, download one, and follow its steps. It’s usually as simple as placing your phone flat, speaker side down.
    • These apps work by playing sound frequencies that help clear out water, so give it a try—you might be surprised at what app magic can do.
  3. Check Out YouTube:
    • Yep, YouTube’s got videos with the right frequencies for the job. Search for sound tones to remove water from speakers and let the video do its thing.
    • Secure your phone while it plays to avoid any unexpected dances across the table!
Honestly, if these sound tricks don’t cut it, and your phone’s still struggling, you might want to hand it over to the pros. Better to get it checked than to risk further damage down the road, right?
Source: People who’ve been there, done that, and some handy sound tech research.
