How Can I Set Up a Sleep Keyboard Shortcut on My Computer?
385 viewsKeyboards
1 Answer
Hey there! If you’re looking to speed things up a bit, setting up a sleep shortcut on your computer is a handy trick to have up your sleeve. Let’s get right into it!
Windows:
1. Instant Sleep Shortcut: You can easily send your PC to dreamland by hitting Win + X, then U, followed by S.
2. DIY Custom Shortcut:
  • Right-click on your desktop, pick “New” and then “Shortcut”.
  • Type in: rundll32.exe powrprof.dll,SetSuspendState 0,1,0 and hit “Next”.
  • Give your shortcut a name like “Snooze Button” and click “Finish”.
  • Now, right-click your shiny new shortcut and choose “Properties”.
  • Under the “Shortcut” tab, toss in your chosen key combo (like Ctrl + Alt + S).
  • Hit “Apply” and then “OK”. That’s it!
Mac:
1. Quick Sleep Shortcut: For newer Macs, it’s as simple as pressing Control + Shift + Power. If you’ve got an older model, go with Control + Shift + Eject.
2. Roll Your Own Shortcut:
  • Hop into “System Preferences” and click on “Keyboard”.
  • Head over to the “Shortcuts” tab and look for “App Shortcuts”.
  • Time to add your shortcut by clicking the “+” button.
  • Select “All Applications” from the drop-down menu.
  • Pop “Sleep” into the “Menu Title” box.
  • Pick your key combo—something like Command + Option + S—and click “Add”.
There you go! Now you’ve got a nifty way to send your computer off to sleep in style. I hope your fingers enjoy the extra time off!
References:
  • Feel free to check out Microsoft Support
  • Apple Support has some good stuff too
