How Can I Use the Shortcut for Speaking on a Webpage on a Mac?
396 viewsLaptops
If you’re trying to make your Mac read text from a webpage, you’re in luck—macOS has a nifty feature built right in for this! Let me show you how to set it up.
First off, pop open ‘System Settings’ from the Apple menu. Head over to the ‘Accessibility’ section—it’s a treasure trove of options to make your Mac a bit more user-friendly.
Check out the ‘Spoken Content’ option. You’ll find a toggle labeled ‘Speak selection.’ Flip that switch, and boom, you’re set to have your Mac vocalize selected text anytime you want.
As for shortcuts, the default one is Option-Esc. But, if you’re like me and fancy customization, that’s easy to tweak. Just click next to ‘Speak selection’ and mash your preferred key combo, like Command-S for example.
And here’s something cool—your Mac can highlight words as it reads them aloud. Mess around with the settings to decide if that’s your style or not.
Now, let’s hit up a webpage. Cruise over there with Safari (since it plays best with VoiceOver). Highlight the text you want spoken, then tap your keyboard shortcut. Sit back and listen to your Mac do its thing.
For those who want even more control, VoiceOver might be your jam. Fire it up with Command-F5 and use its shortcuts to glide through webpage elements like a pro.
Having trouble? Make sure the text is highlighted and double-check any pesky apps that might be meddling with your shortcuts. Sometimes, tweaking what text section you highlight can do the trick—browsers like Safari are generally more cooperative with macOS features.
If you’re using Chrome or Brave and things are acting wonky, switching over to Safari might sort things out.
Give these steps a go, and your Mac will be reading webpages like a champ in no time!
Tackling Speech-to-Text Shortcuts on macOS for Webpages
First things first, macOS’s speech-to-text is a lifesaver for those of us who type as quickly as a snail on a lazy Sunday afternoon. It’s brilliant for folks needing accessibility support, or even just when you need an extra pair of hands. But, like all technology, it sometimes likes to misbehave, especially on webpages. Here’s a no-nonsense guide to getting it back on track.
Check Your System’s Compatibility & Settings
Alright, here’s the deal: if your macOS is older than Mojave (10.14), you might be missing out on the built-in dictation magic. So, before anything else, go to the Apple Menu, hit up “About This Mac,” and see what version you’re rocking. If you’ve got the right version, hit System Settings, go to Keyboard, and check Dictation is on, then set a handy shortcut. Give it a test run in a text app like Notes to see if it plays nice.
Browsers Can Be a Picky Crowd
Sometimes your browser decides it doesn’t feel like cooperating. Make sure it’s got mic access under System Settings, Privacy & Security, Microphone. Trust me, Safari’s your best buddy here – it syncs better with macOS. If your browser’s giving you the cold shoulder, maybe it’s time to switch to Safari. And do yourself a favor by keeping that browser updated.
Shortcut Tangles
Conflicting shortcuts are like trying to dance with two left feet – it’s not happening smoothly. Go tweak your shortcut settings under System Settings, picking something unique. If there’s an overlap, like with Chrome’s keyboard nav settings, flip it off.
Microphone Shenanigans
Hardware hiccups are annoying. If the mic’s not picking you up, check the input settings and maybe test another mic. Dust off any grime from the mic ports too; it can be a sneaky culprit.
Ducking Around Unsupported Websites
Some sites have the personality of a grumpy cat and just won’t let third-party tools do their thing. A workaround is dictating into TextEdit and pasting it over. And if that’s too much, there are apps like Dragon Anywhere or Braina for the heavy stuff, but they’ll ask for some subscription cash.
When All Else Fails
If you hit a wall, you’ve got a couple of extra cards to play. Try resetting NVRAM/PRAM, and if needed, create a new user profile to check if something’s bugged out in your current setup.
One last thing: make sure your spot is quiet when you’re talking to your Mac. It’ll make all the difference in the world for accuracy. And hey, if this dictation stuff is your jam, look into setting it to auto-activate for even smoother sailing. Now you’re all set to sort these hiccups, and hopefully, it’ll feel as natural as chatting with a friend.
Getting your Mac to read out text from a webpage is a cinch once you know how. Here are a few ways to make that happen:
First up, let’s set up ‘Speak Selection.’ Head over to ‘System Preferences’ via the Apple menu, hit ‘Accessibility,’ and find ‘Spoken Content’ on the left. Ticking the box for ‘Speak Selection’ gets things moving. Then, click on ‘Options’ next to it and slap on a keyboard shortcut—Option+Esc is a solid choice. To use it, just highlight the text you want to hear on the webpage and hit your shortcut keys.
For something more encompassing, try ‘VoiceOver.’ A quick press of Command+F5 switches it on. From here, you can mess around and get the text read out using VoiceOver commands. A handy one is Control+Option+A for reading from where you’re at, or Control+Option+Shift+Down Arrow for diving into the webpage elements.
If you’re more comfortable talking to your devices, why not give Siri a spin? You can open Siri by clicking the Dock icon or pressing Command+Space. Then just ask Siri to ‘Read the text on this webpage,’ and you’re good to go.
Another option is cruising in ‘Safari Reader.’ When you’re looking at a webpage in Safari, jump into Reader Mode by clicking the Reader button or pressing Shift+Command+R. Once you’re in, highlight the text and fire up your Speak Selection shortcut or VoiceOver commands to have it read to you.
There you have it—several ways to harness the text-to-speech feature on your Mac while you’re browsing away. These shortcuts make web surfing a lot easier and more accessible.Happy listening!
