Why is My Printer Setup Incomplete Because of a Metered Connection?
348 viewsPrinters
Oh boy, running into a “setup incomplete because of a metered connection” error can be such a hassle when you’re just trying to get your printer going. This happens when your network connection is metered, and Windows decides to play hardball with your data. But no worries, I’ve got a few tricks up my sleeve to help you fix this.
Okay, first things first. You gotta fiddle with your network connection settings. Sounds techy, but it’s pretty straightforward. Do this:
  • Fire up Settings and hit Network & Internet.
  • Choose Wi-Fi or Ethernet—whichever you’re using.
  • Tap on your network and switch off the option that says Set as metered connection.
Next up, you might need to mess around with your printer settings.
  • Hit the Windows key and search for Devices and Printers.
  • Give your printer a right-click and pick Printer properties.
  • Dive into the General or Advanced tab and see if there’s anything there about metered connection you can nix.
After that, turn everything off—your computer and printer—wait for a bit, and then fire them up again. It helps to nudge those network settings into action.
Then, help your printer make friends with your setup again. Use either your printer’s setup software or go for the Add a Printer feature in Windows. Keep an eye on those onscreen prompts and you’ll be golden.
Oh, and don’t forget about your printer drivers. If you haven’t checked them in a minute, pop by your printer manufacturer’s site and grab those latest drivers for your model. Once they’re in, try setting up your printer again.
If all this feels like you’re reading a foreign language, have a glance at your printer manual or ring up the manufacturer’s customer support. From my experience, that’s usually a lifesaver.
Follow these steps and your printer should get back on the same page with your network, working like a charm. And hey, if any little gremlins pop up along the way, you’ve got the know-how to deal with them!
Getting Past the ‘Setup Incomplete Because of a Metered Connection Printer’ Hiccup
If you’ve ever scratched your head over that pesky “setup incomplete because of a metered connection” printer error, you’re not alone. This quirky issue pops up when Windows decides to conserve data usage during the printer setup process. Essentially, it gets stingy with downloads and connection protocols needed for the installation. But don’t worry, I’ve got your back with some handy tricks to get around this headache.
Why This Happens
  1. The Metered Connection Drama
    When Windows spots a metered connection, it starts rationing data. That means it might block those hefty printer drivers you need or pause critical background services.
  2. Driver Mayhem
    You might have outdated or screwed-up drivers, thanks to network restrictions or corrupted files.
  3. Print Spooler AWOL
    This little service, which juggles print jobs and installs drivers, can get thrown off by network hiccups or software clashes.
  4. Network Missteps
    You might have bum IP settings, shaky Wi-Fi, or a firewall acting like a bouncer at a party, stopping your printer and computer from chatting.
Let’s Fix It
1. Kick the Metered Connection Settings to the Curb
  • For Wi-Fi:
    • Jump into Settings > Network & Internet > Wi-Fi, then pick your network.
    • Switch off that “Set as metered connection” business.
  • For Ethernet:
    • Head over to Settings > Network & Internet > Ethernet and flick off “Set as metered connection.”
  • Give your computer a restart and take another swing at setting up your printer.
2. Freshen Up Those Printer Drivers
  • Download Drivers Manually:
    • Grab the latest driver right from your printer’s manufacturer website.
    • Run the installer while staying clear of the metered connection.
  • Via Device Manager:
    • Hit Win + X > Device Manager > Expand Printers.
    • Right-click your printer > Update driver > Pick “Browse my computer for drivers” to plug in the driver manually.
3. Resuscitate the Print Spooler Service
  • Press win + R > Punch in services.msc > Find Print Spooler.
  • Right-click > Restart it. If it doesn’t cooperate, give it a Break-up, wait for 10 seconds, then a fresh Start.
  • Try your luck with the printer setup again.
4. Straighten Out Your Network Settings
  • Make sure your printer and computer are strutting on the same network subnet.
  • For network printers:
    • Assign your printer a permanent residence by setting a static IP through its controls or web interface.
    • Check if it’s all good by pinging the printer’s IP from Command Prompt (Win + R > cmd > Type ping [printer IP]).
  • Temporarily turn off firewalls or antivirus software to sniff out any blocks.
5. Bust Out Windows Troubleshooting Tools
  • Give Windows Update Troubleshooter a whirl (Settings > Update & Security > Troubleshoot).
  • Try SetupDiag, it’s a cool little tool that plays detective by checking installation logs to spot upgrade/setup hiccups.
Tips from the Top Drawer
  • Go Wired: If your Wi-Fi is flakier than a cheap pastry, bring out the trusty USB cable for setup.
  • Firmware Fix: Swing by the printer manufacturer’s webpage for any firmware tweaks or updates to solve compatibility gripes.
  • Roll Back: If things went south after an update, consider going back to a previous system restore point.
So tackle those network bottlenecks, keep your drivers top-notch, and get that service running smoothly—pretty soon, you’ll have that printer purring along. If problems stick around, reach out to the printer’s support or dive into their hardware help goodies.
Alright, here’s the deal: when you see the error message “Setup incomplete because of a metered connection,” don’t panic. It usually pops up on Windows when you’re trying to set up devices like printers but your network is marked as metered. This whole metered thing is just a fancy way of saying that Windows is trying to save data, and it can sometimes be a bit overzealous, messing with how your stuff connects.
A metered connection is like a hall pass for data management on Windows. If you’re rocking a limited data plan, it’s super handy for keeping things in check. But when this setting is on, Windows gives automatic updates and downloads the cold shoulder—which can be a pain when you’re trying to get your printer to play nice.
What’s Causing the Fuss?
  1. Network Config Woes: If you’ve got your Wi-Fi or Ethernet set as metered, that’s gonna put a kink in downloading printer drivers and all sorts of techy necessities.
  2. Printer Drama: Those slick, modern printers, especially from giant names like HP, often need an internet connection and a few hoops to jump through, like activating web services. If your metered setup is holding things back, expect this error to appear.
  3. Windows Got It Wrong: Even if you think your network shouldn’t be metered because you’ve got a good data plan, Windows might still give it that label based on its quirky past configurations.
Getting Past the Glitch
Ready to ditch the error? Follow these tips to sort out your printer setup:
  1. Tweak Those Network Settings:
    • Head to the trusty Settings by giving the Start button a tap.
    • Go to Network & Internet.
    • Choose Wi-Fi (or Ethernet, if that’s your thing).
    • Browse to Manage known networks, hit up your current network, then jump into Properties.
    • Double-check that the Set as metered connection switch is flipped off.
  2. Give Downloads the Green Light:
    • Make a pit stop at the Settings app again.
    • Click on Devices, then navigate to Bluetooth & other devices.
    • Locate the setting for downloads over metered connections and make sure it’s ticked.
  3. Time for a Restart: To lock in those changes, give your computer a reboot.
  4. Try Printer Setup Again: After your computer’s back up, go ahead and set up the printer—whether you’re using the HP Smart App or are going old-school with USB or Wi-Fi direct.
  5. Get Acquainted with Printer’s Needs: Check if there’s anything missing like an HP account or similar, and make sure you’re logged in.
Stick to these steps and you should be home free from the metered setup headache.
Basically, when you hit the “Setup incomplete because of a metered connection” snag, it means your setup’s short on necessary download permissions thanks to your network’s metered status. By taking a moment to adjust those settings, you’ll be right back on track in no time.
