Why Does My PS5 Keep Coming On When I Turn On My Samsung TV?
546 viewsTelevisions
Why Does Your PS5 Keep Turning On When You Turn On Your Samsung TV?
Ever switch on your Samsung TV, just to find your PS5 springing to life too? It can be pretty annoying if all you wanted was to watch some TV without diving into a game. Let’s see what’s causing this and how you can fix it.
The PS5, a top-notch gaming console, and Samsung TV, are a pretty common combo, thanks to the HDMI connection. But, sometimes, the PS5 seems to have a mind of its own, turning on when you power up the TV. Here’s what might be happening:
  • HDMI-CEC Shenanigans: HDMI-CEC, or Consumer Electronics Control, lets devices talk to each other via HDMI. If these settings on your TV and PS5 aren’t synced up, your PS5 might think it’s game time whenever the TV turns on.
  • HDMI Device Link: Your PS5 has something called HDMI Device Link. If this is on, the TV can signal the PS5 to turn on when the TV is powered up.
  • Rest Mode Mischief: The PS5’s rest mode keeps it semi-active, handling downloads and such. If rest mode settings are off, your PS5 might wake up with the TV.
  • Remote Play: Enabled Remote Play can mean your PS5 wakes up when the TV does, even if you didn’t plan on playing.
  • Glitches: Sometimes, firmware or software hiccups can cause unexpected power-ons.
  • Power Surges and Interference: Unstable power or interference from other gadgets can mix things up and trigger your PS5.
  • Remote Mix-Ups: TV remote signals can mistakenly wake up your PS5 if signals overlap or interfere.
  • Network Connections: Network issues or wake-on-LAN features can turn on the PS5 uninvited.
  • Hardware Flaws: Issues like a sticky power button or internal glitches can cause the PS5 to wake up.
  • System Settings: Misconfigured system settings, like power-saving modes or auto-updates, might cause this unexpected wake-up.
Alright, now, how do we sort this out?
Disabling HDMI Device Link:
  • Head to your PS5’s Home screen. Find Settings.
  • Select “System” then “HDMI.”
  • Turn off “Enable HDMI Device Link.”
  • Turn off and then restart your TV to see if it’s fixed.
Tweaking TV Settings:
  • On your Samsung TV, jump into the Settings menu. Look for “HDMI” or “External Device” settings.
  • Disable anything related to HDMI-CEC.
  • If needed, check out the TV’s manual for exact steps.
Turning Off Remote Play:
  • On the PS5, go to Settings > System > Remote Play and switch off “Enable Remote Play.”
  • Restart your TV and see if it did the trick.
Adjusting Rest Mode Settings:
  • Open Settings on your PS5, then “Power Settings.”
  • Under “Features Available in Rest Mode,” disable “Stay Connected to the Internet” and “Enable Turning on PS5 from Network.”
  • Power down your PS5 to see if it’s sorted.
Updating Firmware and Software:
  • Make sure both your PS5 and TV are up to date with the latest software.
  • For PS5, it’s Settings > System > System Software Update.
  • On the Samsung TV, go to Settings > Support or General > Software Update.
Checking Hardware Connections:
  • Ensure the HDMI cable is in good shape and securely connected.
  • Try a different HDMI cable if needed.
  • Check if the PS5 is connected to the right HDMI port that supports new standards.
Using a Power Strip:
  • Use a surge protector or a smart power strip to manage the power supply. It helps with consistent power flow.
  • Some smart strips allow control over individual outlets, adding more layers of control.
Getting More Help:
  • If all else fails, don’t hesitate to contact PlayStation Support or Samsung Support for expert advice and help.
By following these steps, you should be able to keep your PS5 from hijacking your TV time. Happy gaming (and TV watching)!
Hey there! So, you’re probably wondering why your PS5 keeps popping on every time you switch on your Samsung TV, right? Well, here’s the scoop—it’s likely because of something called HDMI-CEC, or Consumer Electronics Control. It’s kind of like your devices having a little chit-chat over HDMI, allowing them to sort of boss each other around in certain ways even when you’re not looking. Let’s dig into why this is happening and how you can put a stop to it.
First off, this feature exists to make life easier by letting your gadgets play nicely together. Imagine flipping on your PS5 and boom, your TV lights up and switches over to the right input—neat, huh? But this mutual understanding can backfire sometimes, like when your PS5 springs to life unexpectedly just because you felt like watching some TV.
So, here’s why your PS5 is getting more action than you’d prefer:
  • When your Samsung TV powers up, it sends signals through the HDMI cable, waking up any connected devices. It’s an automatic thing thanks to HDMI-CEC.
  • The TV might automatically switch inputs based on what’s connected, spotting the PS5 and deciding it’s time to party.
  • If your PS5 is lounging in Rest Mode, it perks up when the TV is turned on due to those HDMI-CEC commands.
Fed up with the surprise wake-up calls? No sweat, you can either disable HDMI-CEC on your TV or tighten things up directly on your PS5. Here’s the lowdown:
To turn off HDMI-CEC on your Samsung TV (which goes by Anynet+, by the way):
  1. Grab the remote and mosey over to Settings.
  2. Hit up “All Settings.”
  3. Slide into Connection.
  4. Pop into “External Device Manager.”
  5. Find Anynet+ (HDMI-CEC) and flick it to OFF. Bingo! Your TV and PS5 will stop syncing up like they’re besties.
If keeping HDMI-CEC alive for other toys sounds better, yet you want your PS5 doing its own thing:
  1. Fire up your PS5 and head over to the home screen.
  2. Click that gear icon up top to reach System Settings.
  3. Venture into System > HDMI.
  4. Shut down “HDMI Device Link.” Now your PS5 won’t be easily excited by TV signals.
So there you have it—a couple of tricks to prevent your PS5 from being overly eager. Whether you fiddle with the settings on the TV or PS5 directly depends on how much you want your tech squad to stay interactive. Good luck, and happy gaming without the unexpected power-ups!
What’s the Deal with Your PS5 Turning on When You Power Up Your Samsung TV?
Alright, I get it. Every time you flick on your Samsung TV, your PS5 decides to join the party. This little mystery usually boils down to something called HDMI-CEC. It’s like a handshake between your TV and gaming console that makes them act in sync. Let’s dig into what’s going on and how you can sort it out:
HDMI-CEC: The Mastermind Behind the Scene
Here’s the scoop: Both devices have HDMI-CEC – Samsung likes to call it Anynet+, while the PS5’s got HDMI Device Link. When this feature is on, they’re best buddies, starting up together. It’s cool for some, but kind of annoying if you’re not into it.
So, what can you do?
  • Turn Off Anynet+ on Your Samsung TV:
    1. Hit the Home button on your remote.
    2. Track down SettingsGeneral & PrivacyExternal Device Manager.
    3. Find Anynet+ (HDMI-CEC) and flip it off.
  • Disable HDMI Device Link on Your PS5:
    1. Head to SettingsSystemHDMI.
    2. Switch off Enable HDMI Device Link.
Port Drama or Messy Signals
Let’s break it down: Samsung TVs sometimes play favorites with HDMI ports, especially for gaming. If your PS5 is in the VIP lane, it might be acting up because of those fancy settings.
Here’s how you can fix it:
  • Tweak HDMI Input Settings:
    1. On your TV, dive into SettingsConnectionExternal Device Manager.
    2. Hit up Input Signal Plus for the PS5’s port to smooth things out.
  • Try a Different Port or Cable:
    Swap out the cable or pick a new port to see what’s what.
Gremlins in Firmware or Software
Old software could be messing with HDMI-CEC, causing quirky behavior. You might want to get your tech up to speed.
What’s on the table:
  • Update Your Samsung TV Software:
    1. Find SettingsSupportSoftware Update.
    2. Choose Update Now.
  • Give Your PS5’s Software a Fresh Coat:
    1. On the PS5, navigate to SettingsSystem SoftwareUpdate Software.
Leftover Power or Lingering Cache Gremlins
Sometimes, weird glitches or old commands stick around and make your PS5 power on unexpectedly.
Fix it by:
  • Doing a Power Cycle:
    1. Pull the plug on both gadgets for a couple of minutes.
    2. Plug them back in and cross your fingers.
  • Resetting HDMI-CEC Back to Basics:
    Toggle HDMI-CEC off, then back on again to clear things up.
When Push Comes to Shove: Factory Reset
If none of this works, a factory reset might just do the trick:
  1. Find SettingsGeneral & PrivacyResetReset Smart Hub.
  2. Reset your HDMI settings afterward.
The Bottom Line:
  • HDMI-CEC/Anynet+ is usually to blame for these troubles. Switching it off usually puts an end to the madness.
  • Keeping up with firmware updates and having a solid HDMI connection can work wonders.
  • If all else fails, shout out to Samsung Support or PlayStation Support for a deeper dive into the issue.
Alright, let’s tackle why your PS5 is firing up whenever you switch on your Samsung TV. The culprit here is a feature called HDMI-CEC that’s designed to make your devices all buddy-buddy, but sometimes it gets a little too friendly. You’ll want to disable it on both your PS5 and Samsung TV and here’s the scoop on how to do it:
First, let’s get to your PS5 settings:
  • Slide over to Settings.
  • Pick System.
  • Head to HDMI.
  • Switch off Enable HDMI Device Link.
Now, on your Samsung TV:
  • Pull up Settings.
  • Dive into General.
  • Wander to External Device Manager.
  • Flick off Anynet+ (HDMI-CEC).
Boom! Once you’ve disabled these settings, your PS5 should chill out and stop turning on every time you fire up your Samsung TV. Easy peasy, right?
