Why Aren’t My PS4 Controllers Charging and How Can I Fix It?
392 viewsGame Console
So, your PS4 controller isn’t charging? That’s a bummer, but don’t worry, let’s try a few things to get it juiced up again.
  • Give the Cable a Health Check: First off, make sure the USB cable isn’t the culprit. You can test it with another device, or simply grab a different cable to see if that’s where the issue lies.
  • Peek into those USB Ports: Sometimes debris or slight damage can mess things up. Give the ports on both your controller and PS4 a gentle clean with some compressed air to clear any gunk.
  • Reset Game Time: There’s a tiny reset button on the back of your controller hiding next to the L2 button. Use something like a pin, press it, and hold for a few seconds. Then, reconnect it with your PS4.
  • Charge It in Safe Mode: Okay, here’s a trick: turn off your PS4, connect the controller, and hold the power button until you hear that second beep. This Safe Mode charging can sometimes do the trick.
  • Battery Gut Check: If the controller charges sometimes but not always, maybe the battery is headed south. In that case, getting it replaced might be the way to go. You might want to chat with PlayStation support for this.
  • Try Another Device: See if the controller will charge using a PC or another charger. This can tell you if maybe the PS4 is where the snag is.
Alright, if you worked through these tips and still no luck, it might be a bigger issue with the hardware. That’s when professional help or even a new controller should be on your radar. Feel free to hop into PlayStation forums or check out their official resources for more detailed advice.
Why isn\’t my PS4 controller getting any juice? Let\’s dive into it and solve this little mystery together.
The Cable and Port Conundrum
First things first, your charging cable might be the culprit here. Over time, cables wear out and ports get all dusty, just like our old jeans. Try a new, high-quality USB cable and see if that makes a difference. No luck? Give the charging port a good ol\’ clean using some compressed air or a soft brush—nothing too adventurous like tweezers that could damage things. If it still isn’t working, maybe try a different USB port on the PS4. If none of the ports work, the console’s USB hub might be pouting and refusing to play nice.
Power Supply Woes
Your PS4 could be messin\’ with the power settings, especially in Rest Mode when it thinks you’re not looking. It might have turned off the USB ports, thinking it’s saving energy. Here’s a trick: go to Settings, find Power Saving Settings, and make sure \”Supply Power to USB Ports\” is set to \”Always.\” Also, avoid using high-powered phone chargers for the controllers. They just don’t vibe well together long-term.
Battery Blues
Batteries have their good days and then they start throwing tantrums after about 2-3 years. If it’s been that long, you might need to swap out the old battery for a new one. You’ll need a tiny screwdriver and a bit of confidence to open things up, but once you replace it, it should be back to life.
Software Shenanigans
Sometimes, it’s not the hardware but glitches in the software that mess things up. You can try resetting your controller by finding the little reset button in the back and pushing it with something like a paperclip. Reconnecting the controller should help. In some cases, a system update may be the wake-up call the PS4 needs—so make sure your console is all up to date!
Physical Damage and Other Annoyances
If your controller experienced a hard fall and still refuses to charge, it might be dealing with internal damage. A temporary fix is to charge it upside-down to keep things connected. If that doesn’t cut it, it might be time to call in the pros—either Sony support or a trusted repair service.
A Few Tips to Keep Them Happy
  • Stick to charging through the PS4 ports or low-power adapters.
  • Keep those ports and cables clean now and then.
  • Store your controllers in a comfy spot—neither too hot nor too cold.
Try these suggestions, and hopefully, your controllers will be back in action without needing a trip to the repair shop. If nothing\’s changing, your controller might need some professional TLC.
re_answer
Having trouble with your PS4 controller not charging? You\’re not alone, and luckily, there are a few things you can try to get it back up and running. Let’s dive right in.
1. Cable Chaos
First off, check that cable connection. Make sure it\’s snug in the controller port. If it’s wiggly, that cable might have seen better days. Swap it out for another one and see what happens. And by the way, some USB cables only charge, they don’t do data, so make sure you’re using the right type.
2. Power Play
Maybe it’s not the cable, but the power source acting up. Try plugging your controller into a wall charger or a computer instead of the PS4 itself. Sometimes those PS4 USB ports just decide to take a day off without telling anyone.
3. Port Perils
Check out that port on your controller. Dust and dirt love setting up camp in there. Gently clear it out using a can of compressed air or a toothpick. If it looks or feels janky, you might have a more serious issue on your hands.
4. A Little Reset Never Hurt
Give your controller a quick reset. There’s a teeny button in a tiny hole on the back near the L2 button; a paperclip should do the trick. While you’re at it, do a power cycle on your PS4—unplug it for 20 minutes and then fire it back up.
5. The Internal Dilemma
If nothing\’s working so far, the battery might just need a swap. Honestly, if you\’re comfortable opening up the controller, it\’s worth a shot. Otherwise, it could be the charging port or even the circuitry, and you might need to get a pro involved.
Final Word
Stick to these steps, and you’ll probably nail down what\’s wrong with your PS4 controller. But if you’re banging your head against the wall and the controller’s still covered by warranty, let Sony handle the heavy lifting. Good luck!
