Why Does My PS4 Controller Keep Disconnecting from My PC?
457 viewsGame Console
Let’s be honest, there’s nothing more annoying than a PS4 controller deciding to disconnect every now and then while you’re in the middle of an intense gaming session on your PC. Yikes! But don’t worry, there are a bunch of ways to tackle this. Here’s how you can troubleshoot and hopefully fix the issue.
Start by giving your controller a quick check. Honestly, if it’s been through some rough times, it might be worth seeing if it works fine with a PlayStation 4 or another PC. Still stable? Cool, then your PC is the culprit.
Now, if you’re using Bluetooth, it might just be that your PS4 controller is playing hard to get. It likes a bit of space, but not too much! Keep it within 10 feet from your PC and make sure nothing’s blocking it. Got it? Great. If the connection still gives you grief, try this:
  1. Jump into your PC settings and head to Bluetooth & other devices.
  2. Kick the controller off your Bluetooth list (sorry, buddy).
  3. Stick it into pairing mode by pressing the Share and PS buttons until it starts flashing.
  4. Then, add it back via Windows by selecting “Add Bluetooth or other device,” and pick your controller from the options.
Still facing hiccups? Your PC might just need a driver update. It’s not the most exciting task, but it’s worth trying. Here’s how you can do it:
  1. Open up Device Manager (yawn, I know).
  2. Expand the Bluetooth section.
  3. Find your wireless controller driver, right-click, and go for Update driver.
  4. Let your PC work its magic by searching for updates automatically.
Another handy trick is using DS4Windows to manage your controller. It’s been a lifesaver for many gamers:
  1. Download and install DS4Windows.
  2. Follow the setup to get your controller working just right.
  3. Keep DS4Windows running when you try reconnecting your controller.
If things are still not quite right, give your controller a hard reset. It’s like giving it a little nudge to wake up:
  1. Grab a paperclip and find the small reset button on the back near the L2 button.
  2. Press and hold it for about five seconds.
  3. Then, try connecting it to your PC again.
By the way, sometimes Windows power settings might mess things up. Head to Device Manager once more:
  1. Click on your Bluetooth adapter properties.
  2. In the Power Management tab, uncheck the box for “Allow the computer to turn off this device to save power.”
  3. Hit OK and give your computer a restart.
With a bit of patience and persistence, you can usually get things running smoothly again. Hopefully, one of these steps will do the trick for your PS4 controller disconnect woes!
You’re having trouble with your PS4 controller disconnecting from your PC, huh? That’s super frustrating, especially when you’re in the zone with your game. Let’s dig into a few things that might be causing this and figure out how you can fix it.
Hardware Issues
Sometimes it’s the simple stuff, like a dud cable or USB port. If your controller also acts wonky when you connect it to a PS4, the controller itself might be the problem. Try swapping out the USB cable or plugging it into a different port (remember, USB 2.0 can be more reliable than 3.0). Also, make sure your controller is charged or replace the battery if needed.
Bluetooth Connectivity Problems
We all love wireless freedom, but Bluetooth can sometimes be a bit flaky. If your PC’s Bluetooth drivers are outdated, that could be it. A quick visit to Device Manager to update your Bluetooth drivers could solve the problem. Also, try re-pairing the controller—hold down the Share and PS buttons until the light starts flashing, then re-add it to your PC’s Bluetooth devices. Oh, and if you keep having issues, investing in a dedicated Bluetooth adapter might make things easier.
Driver Conflicts
Old or funky drivers might be messing with your controller. Hop into Device Manager, uninstall the controller to clear out any bad data, and let the system reinstall it. Also, if you’re using something like DS4Windows, make sure it’s the latest version and that you’ve got the ‘Hide DS4 Controller’ option checked to avoid double inputs.
Power Management Settings
Sometimes Windows tries to save power by messing with USB devices. To prevent that, go to Control Panel, find your Power Options, and turn off USB selective suspend under USB settings. That way, your system won’t randomly cut off power to your ports.
Software/System Conflicts
Steam settings can be a sneaky culprit; make sure to disable PlayStation Configuration Support in Steam settings if it’s being a pain. And if your PC acts weird when starting, try a clean boot by disabling all those pesky startup apps you don’t need.
Firmware or OS Updates
Staying behind on updates can lead to weird bugs. Keep Windows and your controller firmware updated. Snag the latest Windows updates in Settings and use Sony tools or a PS4 to check the controller firmware.
In the end, if none of these tricks work, it might be time to try a different controller or plug the problematic one into another PC. Wireless can be nifty, but if the issues persist, a wired connection might be your best bet for a stable gaming session. If all else fails, professional repair or getting a new controller could be the way to go.
So your PS4 controller keeps popping off your PC, huh? That’s pretty frustrating, but don’t worry—we’ve got you covered with a few tricks to get that pesky problem sorted out.
Alright, first things first, make sure your device drivers are up-to-date. Old drivers can mess with connectivity. Just hit up Device Manager, find the ‘Human Interface Devices’ section, right-click on your PS4 controller, and get those drivers updated.
If you’re rolling with a wireless setup and using Bluetooth, check those settings. Just dive into ‘Settings’ > ‘Devices’ > ‘Bluetooth & other devices’ and make sure Bluetooth is turned on and working right. And hey, if your built-in Bluetooth isn’t cutting it, snag yourself a USB Bluetooth dongle—they usually do the trick.
Now, if you’re going wired, the problem might lie with your USB port or cable. Try switching to a different USB port on your PC or swap that cable out for a high-quality one.
Here’s a quirky one—sometimes your PC is a bit too power-conscious for its own good. Go into Device Manager, under ‘Universal Serial Bus controllers,’ and disable any power-saving settings. Just uncheck ‘Allow the computer to turn off this device to save power’ for good measure.
Feeling adventurous? Recalibrate your controller. Head over to ‘Devices and Printers’ in Control Panel, right-click on your controller, and go through the ‘Game controller settings’ to recalibrate it.
Here’s the kicker: maybe your controller’s firmware needs a refresh. Connect it back to a PS4 console and check for updates. If nothing else works, try resetting the controller. Grab a small tool, press that little reset button near the L2 shoulder, and then reconnect it to your PC.
After giving these a whirl, your controller should stay connected like a charm. But if it’s still acting up, it might be time to hit up PlayStation support or see what your PC manufacturer has to say.
There you go—hopefully, that’s enough to kick that disconnecting issue to the curb!
