Why Can My Android Phone Text but Not Make Calls?
388 viewsPhone
Struggling with an Android phone that can text but won’t make calls? Yeah, that’s a real headache. Don’t worry, though—I’ve got a bunch of tricks to help you figure it out.
First off, peek at your phone’s signal bars. If they’re lacking, it might be time to hunt down a better spot for reception. We’ve all been there, stuck in that one dismal corner where nothing works!
Next up, let’s make sure your mobile plan is on track. If you goofed and switched to a data-only deal, or maybe forgot about a bill, that could be souring your call attempts. Been there, done that—a call to customer service should sort this out.
You won’t believe how often a simple restart does wonders. Power off, then on again, and your phone might just snap back to life. It’s like giving your device a tiny coffee break!
Here’s a little hidden gem for you: toggling airplane mode. Flick that switch on for a few seconds and back off—it’s so simple, yet it often works like magic to reset the connection.
A fiddly SIM card, you say? Just pop it out and back in, making sure it’s all snug. If you’ve got a spare phone laying around, test the SIM there—sometimes the card’s just being cranky.
Got gremlins in your network settings? Reset them! It doesn’t zap any saved stuff but can clear up pesky connectivity blips. It’s like sweeping away digital cobwebs.
Also, double-check that your Android software isn’t stuck in the past. Keeping it updated ensures you’re not left dealing with old bugs or outdated network compatibility.
By now, you’re scratching your head if calls still aren’t happening. It could be the VoLTE setting sneaking about unchecked, especially as carriers shift gears from older networks. There’s a quirky code to access a menu and enable it, but grab a buddy if you’re unsure about dialer codes—it’s a bit arcane!
If none of these hacks break the curse, it’s time to call in the big guns. Your carrier’s customer support will lend a hand and might offer insights into area network troubles or deeper account snags.
So here’s the gist: Check your network, your plan, your phone settings, and even your SIM card. The bits and pieces can add up, but with a stitch here and a tweak there, your phone should come around to making calls again. Good luck—I’m betting on you!
Why Your Android Phone Can’t Make Calls but Can Send Texts
Ever faced that frustrating moment when your Android phones decide they’re not cool with making calls but texting’s totally fine? Yeah, been there! Lots of reasons could be messing with your phone’s calling capabilities. Let’s peel back those layers and figure out what’s going on.
Stuck in a Dead Zone
Here’s the kicker: calls depend on voice channels, so a weak signal is like kryptonite to them. Texts have a bit more wiggle room, tapping into sneaky paths like Wi-Fi.
  • Scout Signal Strength
    • Check out those signal bars. If they’re lonely, try moving to higher ground or ditching that concrete jungle.
  • Switch Networks Manually
    • Hop into Settings > Network & Internet > Mobile Network > Advanced > Carrier. Turn off auto-select and pick your network like it’s a music playlist.
  • Hit Reset on Network Settings
    • Wander into Settings > System > Reset > Reset Wi-Fi, Mobile & Bluetooth. No worries, it’s just clearing out the cobwebs, not your pics.
SIM Card Shenanigans
Let’s talk about SIM cards. They can be sneaky, sometimes letting texts through but fussing over calls.
  • SIM Cardiologist Time
    • Power down your phone, slide out that SIM tray, and give it a check-up. Clean it gently and secure it back in.
  • Play Musical Chairs with SIMs
    • Grab a SIM from a buddy or your uncle Bob. Just to see if your card’s causing the drama.
  • Call Your Carrier
    • Verify there’s no ghost lurking in your account like unpaid bills or suspensions. Replace the SIM if needed.
Setting Mischief
Ah, those pesky settings! Features like call blocking or airplane mode can cause more trouble than unexpected family visits.
  • Banish Call Barring
    • Open the Phone app, head to Menu > Settings > Call Settings > Call Barring, and loosen any chains.
  • Do Not Disturb? More Like Do Not Listen!
    • Swipe down from the top, check if DND is playing spoilsport, and switch it off.
  • VoLTE Magic
    • Is Voice over LTE switched on? Hit Settings > Network & Internet > Mobile Network > VoLTE. This could save your call quality, trust me.
Software Gremlins
Sometimes, the system’s a bit under the weather, or apps are getting bossy and not letting you phone a friend.
  • Phone App Cache Detox
    • Venture to Settings > Apps > Phone > Storage > Clear Cache. Give your phone a reboot—it’s like a caffeine kick.
  • Safe Mode Adventure
    • Press and hold the power button, find Safe Mode, and give it a spin. If calls are hitch-free, an app might be up to no good.
  • Update System Groove
    • Seek out OS updates in Settings > System > System Update, and freshen up your phone’s wardrobe with any new patches.
Hardware Heartache
Broken antennas or mics might be the party poopers—think cracked speaker or water damage.
  • Check Speaker/Microphone
    • Record your soulful rendition on a voice recorder or go live with a video call.
  • Look for Physical Damage
    • If your phone’s had a rough night with a drop or a swim, a trip to the repair guru could be your go-to move.
Carrier Crosses
Maybe it’s your pesky carrier having an off day. Nugget of wisdom: account restrictions or mismatch in coverage could be working against you.
  • Dial Carrier Support
    • Quiz them about any network hiccups or if they’ve got your back with voice options.
  • APN Settings Refresh
    • Navigate to Settings > Network & Internet > Mobile Network > Access Point Names. Change to your carrier’s APN or set to default.
Quick Fix Guide
  1. Scope out signal bars.
  2. Give your phone a restart and give calls another chance.
  3. Play tag with the SIM card.
  4. Hunt down software updates.
  5. Ping your carrier.
If none of these tricks does the trick, maybe a factory reset (back up your awards first!) or a repair journey is the way forward. Sometimes, it’s just beyond a regular fix—a hardware glitch or carrier quarrel could be the sneaky culprit.
Why won’t my Android phone make calls, but texts still go through? It’s pretty annoying when you need to make a call, and your phone decides not to cooperate. Here’s the lowdown on what you can do to get your device back to normal.
First up, check if Airplane Mode is on. I know it sounds obvious, but sometimes the simplest thing evades us. Go into your Settings, find Network & internet, and if Airplane Mode is switched on, flick it off.
Next, take a peek at your signal bars. If they’re low or non-existent, it could be why calls aren’t happening. Try moving around until you spot a better signal.
Another thing to look into is your blocked numbers list. You might accidentally have blocked the number you’re trying to call. Just open the Phone app, hit Settings, and under Blocked numbers, make sure nothing important is being rejected.
Ever tweaked your network operator settings? It’s worth doing a quick check under Network & internet > Mobile network > Network operators to manually select your carrier if things look off.
If you’re still scratching your head, maybe it’s time to reset the network settings. Diving into Settings > System > Advanced and hitting Reset options > Reset Wi-Fi, mobile & Bluetooth can sometimes fix the glitch.
Speaking of connections, don’t ignore the good old SIM card. A wonky or misaligned SIM can mess with calls. Reinserting it or swapping with another one could clarify things.
Let’s not forget about software updates—they’re a lifesaver more often than not. Hit up Settings > System > Advanced > System update to see if any updates are waiting for you.
On the flip side, it could be some third-party app causing trouble. Booting in Safe Mode can help you figure that out. Hold down the Power and Volume Down buttons to reboot and see if calls go through. If they do, one of those apps is probably the villain.
If your patience is wearing thin, hitting up your carrier for a chat might reveal underlying account issues or widespread network problems.
Lastly, if all else fails, the dreaded factory reset is your last resort. It wipes everything clean, so back up your stuff first. Navigate through Settings > System > Advanced > Reset options > Erase all data (factory reset), and cross your fingers.
Hopefully, one of these tricks will lift your phone out of its funk. But hey, if after all this, you’re still stuck, it might be time to let a professional take the wheel—it could be hardware up to no good!
