What’s Up with My PC Crashing During Games if It’s Not Overheating?
456 viewsComputer
Alright, let’s dive into gaming crashes that aren’t about your PC overheating. It’s pretty aggravating when you’re trying to enjoy your favorite game and it keeps going belly up. Surprisingly, overheating is just one player on the field. So, let’s snoop around some other usual suspects and figure out how to fix them.
Driver Disaster: Your drivers might be calling it a day. If your graphics drivers are dusty old antiques or just plain corrupted, that can throw your game off balance. It’s like trying to drive a sports car with a tractor engine—doesn’t work great.
Power Supply Woes: Even with cool temperatures, your PSU (Power Supply Unit) might not be pulling its weight. If it’s not amping things up properly, you might end up nose-diving into a crash. It’s like trying to put a rocket on a tricycle.
Software Scuffles: Sometimes, background apps don’t play nice—your antivirus could be misidentifying game files as baddies and blocking them. It’s like getting your party crashed by an unwelcome guest.
Game File Gremlins: In some cases, the game itself has a few gremlins in the files. Platforms like Steam have nifty tools to hunt and squash these bugs, verifying the game’s integrity.
Mischievous Memory: RAM can be a slippery devil. Faulty sticks or screwy settings in BIOS could be the culprits behind sudden collapses during gameplay.
BIOS Blunders: Messing around with BIOS settings can lead to some unruly behavior from your PC. Dialing them back to default could smooth things out.
Virus Vexations: Sneaky malware can worm its way into your system, hogging resources or corrupting files. Like an unwelcome houseguest who eats all the snacks.
Now, let’s hit the troubleshooting trail:
  • Update Those Drivers: Keep them spruced up and snazzy. No excuses.
  • Check Your PSU: Investigate any suspicious noises or smells—this isn’t the place for mystery.
  • Kick Out Background Apps: Have a little elbow room by closing other apps and temporarily silencing antivirus.
  • Verify Game Files: Let Steam do the detective work—right-click, hit ‘Properties,’ and ‘Verify Integrity of Game Files.’
  • Memory Diagnostics: Tools like MemTest86 are your best friends here. Be sure to give your RAM a good once-over.
  • BIOS Resetting: Make friends with your BIOS and restore default settings—just don’t be shy.
  • Scan for Malware: Go on a malware hunt with antivirus software—extra tools like Malwarebytes can be a big help.
  • Dive into Event Viewer Logs: Poke around those logs for clippings from the crime scene—driver issues might be the culprit.
When the dust settles on these fixes, you should have your game back to performing like a star without overheating in the mix. Truth is, solving PC crashes is a bit of detective work—these tips are like your magnifying glass. Happy gaming!
If your computer decides to crash during gaming but isn’t overheating, you could have a handful of culprits. Let’s see if we can sort things out:
Power Supply Unit (PSU) Woes:
Yep, sometimes a shaky PSU can mess things up. You’ll want to make sure it’s beefy enough to power your setup.
What to do: Take a peek at your PSU’s wattage and match it up with what your system demands. If it’s lacking, switch it out for one with more oomph.
Driver Drama:
Drivers, especially for your graphics card, can go haywire if they’re outdated or have gone rogue.
Fix it: Hit up the NVIDIA or AMD websites for the freshest driver updates, and give all your system drivers a refresh too.
Hardware Havoc:
Sometimes, it’s a piece of dodgy hardware like the RAM or GPU causing the headaches.
Try this: Use something like MemTest86 to check RAM and FurMark to give your GPU a good shake-up. Swap out anything that doesn’t pass muster.
Software Shenanigans:
Games or software can throw tantrums if they conflict or are corrupted.
Here’s a thought: Do a clean boot to single out any culprits. On Steam or similar platforms, verify the integrity of your game files or even try a complete reinstall.
BIOS/UEFI Jigsaw:
Sometimes, the settings in BIOS can be more trouble than they’re worth if they’re outdated or incompatible.
How to handle: Update your BIOS carefully; stick to the manufacturer’s step-by-step guide. Reset everything to default before you start the update.
Storage Sagas:
A dodgy drive can be the bad guy here, causing all sorts of crash chaos.
Check this out: Use tools like CrystalDiskInfo to see if your storage is on its last legs. Consider popping in a new drive or moving the game elsewhere if your current one’s shot.
Background Hustles:
Sneaky background apps using up all your resources can be a big problem.
Keep it simple: Ruthlessly close any non-essential applications through Task Manager while gaming and make sure your computer isn’t running anything heavy-duty in the background.
Giving these solutions a whirl could be your ticket to resolving those frustrating crashes while gaming. If nothing shakes loose, calling in a pro might be your best bet.
