What Can I Do If Notes Keep Popping Up on the Bottom Right of My Mac?
515 viewsLaptops
Alright, so you\’re getting these pesky pop-ups from Apple Notes in the corner of your Mac screen, right? It’s the Quick Note feature, designed for jotting stuff down in a flash. But let\’s be honest, it’s really annoying when you’re deep into a game or hammering out a masterpiece in Photoshop. No worries, I\’ve got some tricks to make those pop-ups a thing of the past.
Tweak Those Hot Corners
First off, let\’s handle that hot corner situation. If you’re on macOS Monterey or later, this is how you dodge the quick notes:
  • Head over to the Apple menu and dive into System Settings.
  • Find Desktop & Dock, scroll down, and hit the Hot Corners button.
  • Spot the corner causing chaos and switch it from “Quick Note” to “Blank” or anything else that’s not going to spring up and surprise you.
  • Don’t forget to hit Done to lock in those changes.
For those on an older macOS, scoop into System Preferences and poke around Desktop & Screen Saver or Mission Control to fiddle with the hot corners in a similar fashion.
Dodge Those Annoying Notifications
Now, if it’s shared notes popping up more than uninvited guests at a barbecue, here’s the game plan:
  • Crack open Notes and give the shared troublemaker a right-click. Select “Manage Shared Note” and turn off those alerts.
  • If you want to keep all shared notes on mute, go into Notes > Settings and kill the “Allow mention notifications” option.
  • For absolute silence, swing by the Apple menu > System Settings > Notifications, select Notes, and yank the plug on those alerts altogether.
Stop Accidental Activations
If you\’re still keen on hanging on to Quick Note but want control, just add a modifier key. Here’s how:
  • Go back to tweaking the Hot Corners settings.
  • When you’re picking the corner for Quick Note, hold down a key like Command or Shift. This way, Quick Note only pops up if you’ve got the key pressed while nudging your cursor to the corner.
By custom-tuning the hot corners and notifications, you’re geared up to bypass those irritating interruptions and keep your Mac groove going smooth as silk.
So, those pesky notes and pop-ups keep showing up in the bottom-right corner of your Mac, huh? Let\’s dive into what\’s probably causing it and how you can sort it out without going nuts.
First off, you’ve got a couple of likely culprits: the Stickies app, Notification Center alerts, or maybe some mystery third-party app. Here’s the lowdown on each and what you can do.
Stickies App Hijinks
Ah, the Stickies app—it’s like the digital version of leaving Post-its scattered around. If these little notes keep popping back up every time you log in, you might need to give them a stern talking-to.
  • Troublemaker: Stickies notes might auto-open if you haven’t cleared them out or if they’re set to show up when you start your Mac.
  • What to Do:
    • Shut Them Down: Open Stickies, right-click each note, and send it packing by selecting Close or hitting Command + W. Don’t forget to save or delete them if they’re important.
    • Change the Rules: Jump into your System Settings > General > Login Items and evict Stickies from showing up at login.
    • No More Auto-Save: If you can, head into Stickies preferences and uncheck \”Save Contents When Closing Notes.\”
Notification Center Shenanigans
Here’s where your Mac gets a little clingy with those alerts from apps like Calendar or Reminders. The bottom-right of your screen is HQ for all their attention-grabbing antics.
  • Usual Suspects: These apps love to let you know what\’s going on.
  • How to Tame:
    • Dial Back the Alerts: Head into System Settings > Notifications, click on the app blowing up your spot, and tweak the style. Change it to None or Alerts if banners are too intrusive.
    • Silence is Golden: If you can live without notifications from a particular app, flip the switch to turn them off altogether.
    • Time-Out for Notifications: Use \”Do Not Disturb\” from the Control Center to hush everything when you need peace.
Hot Corners Drama
Hate it when a stroll to the bottom-right corner suddenly opens the Notification Center? You might have triggered a Hot Corner by mistake.
  • Who’s to Blame: Accidentally setting up a Hot Corner action.
  • Fix That Fast:
    • Cool Down Those Corners: Dive into System Settings > Desktop & Dock > Hot Corners. Pick the bottom-right corner and set it to do absolutely nothing (\”-\”).
    • Add a Delay: For extra protection, third-party tools like Rectangle Pro can add a little buffer before Hot Corners activate.
Random App Pop-Ups
Sometimes, it’s an app you didn’t expect causing all the ruckus. Could be anything from a password manager to a clipboard tool.
  • Finding the Culprit: Take a good look at the popup—does the title or icon ring a bell? That’s your lead.
  • Quick Fixes:
    • Dig into App Settings: Sniff around the app’s settings and turn off any notification or auto-launch options you don’t need.
    • Repeat Offender? Uninstall: If some app sneaked in when you weren’t looking, consider tossing it in the trash via Applications > Trash.
Extra Tricks Up Your Sleeve
If you’re still getting the annoying pop-ups, try these more advanced moves:
  • Reboot the Notification System: Open Terminal and run this voodoo: ~/Library/Application\\ Support/NotificationCenter/ -rf *.db. Then restart your Mac. Just remember, this will reset all your notification settings.
  • Safe Conclusion: Boot your Mac in Safe Mode by holding Shift during startup. If the nuisance is gone, some third-party app or login item is likely guilty.
Keeping Things in Line
And lastly, here are some preventive hacks:
  • Regularly scout your Login Items and Background Apps in System Settings.
  • Use Activity Monitor (Applications > Utilities) to catch suspicious processes or resource-hogs.
  • Keep your macOS updated to squash potential bugs in the system.
If you’re still haunted by random notes and alerts, jot down what the pop-up says or when it tends to appear—that\’ll help in pinning down the perp. Good luck!
Hey there! If those pesky notes keep popping up on your Mac’s bottom right corner, you’re not alone. This glitch is usually thanks to the Quick Note feature. No worries though, you can definitely tackle this.
First off, disable the Hot Corner:
  • Open up your Apple menu and hit up System Preferences.
  • Click on Desktop & Screen Saver – sounds fancy, right?
  • Jump over to the Screen Saver tab and check out the Hot Corners button lurking in the corner.
  • Spot the corner with Quick Note action? Yep, likely the bottom right.
  • Nix it by setting it to (None) or swap it for something that doesn’t annoy you every time.
  • Don’t forget to hit OK and lock in those changes.
Another trick: Tweak Quick Note shortcuts.
  • Pop open the Notes app, and peek at Notes up in the menu bar.
  • Sneak into Preferences.
  • Hunt down anything Quick Notes and change it up so it doesn’t go wild on you.
And hey, don’t skip updates:
  • Make sure your macOS isn’t old-school. Updates might just have the fix you’re looking for.
  • Slide into System Preferences and choose Software Update.
  • Got an update? Grab it. Sometimes it’s all you need to squash those bugs and keep things running smooth.
Give these a shot, and you’ll hopefully kick those unexpected notes to the curb. If you’re still stumped, checking out Apple Support or hitting up their discussion forums might just do the trick.
