Why Does My New CPU Installation Show fTPM/PSP NV Corrupted On First Boot?
300 viewsComputer
1 Answer
Alright, so you’ve just popped in a new CPU, and boom—you’re hit with the dreaded ‘fTPM/PSP NV corrupted’ error. No worries, let’s tackle this step-by-step.
First up, let’s hit the reset button on those BIOS settings. Here’s the scoop: shut down your computer, yank out the power plug, and pull out that CMOS battery from the motherboard. Give it a breather for about 5 to 10 minutes before popping it back in. Once that’s done, plug everything back, fire up your system, and keep your fingers crossed.
Now, it’s all about keeping things up to date. If your BIOS/UEFI is feeling a bit dated, hop onto your motherboard manufacturer’s website and grab that latest update. Just follow their instructions and reboot once you’re done. Easy peasy with a little patience!
Here comes the fun part—clearing out the TPM. When you’re booting up, tap that Del, F2, or F10 key like your life depends on it to dive into the BIOS settings. Go on a treasure hunt for the Security section and find the TPM or fTPM option. Clear that bad baby out, save those changes, and exit BIOS/UEFI with a newfound hope.
If things still aren’t peachy, let’s tame those BIOS settings. Get back in there and load up those default or optimized settings. Save again and give your system another whirl.
Now, make sure your CPU is fully in cahoots with your motherboard. Double-check the manual for compatibility—just in case. And hey, make sure those power and data cables aren’t going rogue!
For some backup options, grab the manual for some more in-depth pointers. You might also want to update those chipset and system drivers via the manufacturer’s website. If all else fails, it might be time to call in the pros.
Tackling these steps should help you shake off that error and get your system humming like a tune. Let’s hope it’s smooth sailing from here on out!
