How Can I Fix ‘MMC Has Detected an Error in a Snap-In’ on Windows?
411 viewsComputer
1 Answer
Dealing with the ‘MMC has detected an error in a snap-in’ headache?
This pesky error can pop up out of nowhere. But don’t worry, I’ve got you covered with some straightforward fixes:
1. Give Your Computer a Breather:
If you haven’t already, try rebooting your machine. It’s amazing how often a restart can sort out little problems.
2. Time for Some SFC Action:
– Fire up Command Prompt as the big boss, aka administrator.
– Punch in sfc /scannow and hit Enter.
– Let the magic happen—this’ll catch and fix potentially corrupted files.
3. Stay Updated, Stay Safe:
– Dive into Settings > Update & Security > Windows Update.
– Give “Check for updates” a click. Installing updates is like giving your system a health boost.
4. Snap-in Acting Up? Reinstall or Repair:
– Head over to Control Panel, land on “Programs and Features”.
– Spot the troublemaking program and uninstall it.
– Reinstall or repair might be just what you need to smooth things out.
5. Fix Those Permissions:
– Punch in mmc in the Run dialog (Win + R) to open up MMC.
– Navigate through File > Add/Remove Snap-in.
– Add the snap-in you need and double-check your permissions.
6. Get the DISM Tool Working:
– Open Command Prompt as admin again, we’re on a roll.
– Type these commands one-by-one, pressing Enter each time:
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /CheckHealth
– Take a sip of coffee while you wait—these can take a moment, but they’re great at fixing deeper issues.
7. Set Up a Fresh User Profile:
– Check out Settings > Accounts > Family & other users.
– Choose to “Add someone else to this PC” and follow the steps.
– Switch to the new profile and see if that error finally backs off.
Still stuck? Maybe it’s time to holler at Microsoft Support for a bit more help. Or ring up a tech-savvy buddy!
