How Can I Keep My Laptop On When It’s Closed?
267 viewsLaptops
Wanna keep your laptop running when you shut the lid? Let’s dive into how you can manage that. Most laptops nod off when you close them—asleep or in hibernation mode—to save power and avoid overheating. But, maybe that’s not your jam. Maybe you wanna use an external display, or keep stuff downloading. Let’s break it down by system.
Background Scoop
Laptops are set to give you a breather when you close them. Common reasons people mess with this?
  • They’re living that dual-screen lifestyle.
  • They want their downloads to keep ticking.
  • Remote access like a nerdy ninja.
Getting to the Root of It
1. Tinkering with Power Settings
  • Windows:
    • Hop into the Control Panel, find your way to Power Options, and hit “Choose what closing the lid does.” Change both “On Battery” and “Plugged In” settings to “Do Nothing.” Save those babies!
    • If it treats you like a guest and keeps things locked, click on “Change settings that are currently unavailable” to make your changes.
  • macOS:
    • Grab that free app, Amphetamine, from the App Store. If you’re more of a command-line cowboy, try this:
    • sudo pmset -b sleep 0; sudo pmset -b disablesleep 1
    • Don’t say I didn’t warn you: This keeps it awake for good. To play it safe, use:
    • sudo pmset -a hibernatemode 0
    • Want your sleep back? Just reset with:
    • sudo pmset -a hibernatemode 3
  • Linux (Ubuntu):
    • Whip out Terminal:
    • sudo nano /etc/systemd/logind.conf
    • Start editing:
    • HandleLidSwitch=ignore
      HandleLidSwitchExternalPower=ignore
    • Then restart the service:
    • sudo systemctl restart systemd-logind
2. Dealing with Hardware and Drivers
  • Keep an eye out for dusty old drivers. Update your BIOS/UEFI from your laptop brand’s website. Also, check and refresh your power management drivers to keep everything smooth.
3. Dodging Third-Party Software Shenanigans
  • Sometimes apps think they’re the boss of you. If your antivirus or any other utility is harshing your vibe, disable or whitelist your settings. Go rogue with tools like InsomniaX for macOS or Caffeine for Windows.
Things to Keep in Mind
  • Overheating: Watch out! Closed laptops can get toasty, so let ‘em breathe. Don’t suffocate them on a couch cushion.
  • Battery Life: Keeping it plugged could wear down your battery. If your laptop plays nice, turn on any charge-limiting features.
  • Security Stuff: Always lock your laptop if you’re gonna keep it awake—it’s an open invitation otherwise.
Bringing It Together
To keep your laptop awake, you gotta fiddle with settings, update stuff, and sometimes deal with troublesome software. Just weigh the perks against stuff like overheating and battering your battery. Third-party apps can give you a quick workaround—system changes are more solid.
Hoping this does the trick for ya!
Hey there! Want to keep your laptop running even when it\’s closed? You can totally do that by tweaking your power management settings. This is a lifesaver if you\’re using an external monitor, keyboard, and mouse, effectively turning your laptop into a desktop. You can pull this off whether you\’re on Windows or macOS. But remember, keep an eye on ventilation and power setup while you\’re at it.
For Windows Folks
To get this going on a Windows laptop:
  1. Crack open your Start menu and type “lid” – it’ll steer you right to the “Choose what closing the lid does” settings in Control Panel, laser-focused on power options.
  2. Check out the “When I close the lid” bit. There are two things here: what happens when you’re running on battery and what happens when you’re plugged in.
    • When your laptop’s plugged in, choose “Do Nothing.” This keeps it awake when the lid\’s shut, which is perfect when you’re all set with peripherals.
    • For battery mode, it’s smart to pick “Sleep” to save some juice when you’re out and about and accidentally close the lid.
  3. Save those settings, and you\’re golden! Your laptop won’t conk out while charging with the lid down.
MacBook Users, Listen Up
For all you using macOS:
  1. On newer versions (think macOS Ventura and later):
    • Head to System Settings and mosey over to the Battery section.
    • Scroll way down to Options. Flip the switch on “Prevent automatic sleeping on power adapter when the display is off.” Easy peasy, your MacBook will stay active even with the lid shut.
  2. If your macOS is a bit older:
    • Go to System Preferences, then hit Battery.
    • Click the Power Adapter tab, and make sure “Prevent computer from sleeping automatically when the display is off” is ticked.
  3. Once you\’ve got your external display, keyboard, and mouse all hooked up, your MacBook should seamlessly switch to clamshell mode.
Heads Up on Staying Safe
Here’s where you gotta be careful:
  • Make sure your laptop has good airflow when it’s shut—these babies can heat up more than you think. Maybe grab a cooling pad or make sure there\’s some breathing space in your docking setup.
  • Especially if you’re in a tight spot, remember that keeping it on might build some extra heat. It’s no sweat if you just keep tabs on the temperature.
  • Keep it plugged in when you’re doing this to dodge any surprise battery drains and keep things running smoothly.
Take a look online; guides from places like PCMag and official tips from Microsoft and Apple are great to ensure you’re doing it right without any hiccups. Welcome to the world of laptops that double up as desktops without missing a beat!
Looking to keep your laptop running even when it’s closed? Let’s dive into some simple steps for both Windows 11 and Mac. This way, you can carry on without missing a beat.
Windows 11 Tips:
  1. Start with Power Options:
    • Give a right-click on the Start button and pick Power Options.
  2. Change What Happens When You Shut the Lid:
    • Hit Additional power settings under Related settings.
    • In Power Options, go for Choose what closing the lid does on the left.
    • Where it says When I close the lid, select Do nothing for both On battery and Plugged in.
  3. Wrap It Up:
    • Smash that Save changes button to keep it all set.
Mac Tricks:
  1. Set Up Your External Gear:
    • Make sure you’re hooked up to an external monitor, mouse, and keyboard.
    • Your Mac needs to be plugged in for clamshell mode (fancy talk for closed-display mode) to work.
  2. Close That Lid:
    • Once everything’s connected, shut the lid. Your monitor should take over as the main screen.
If you’re the type who likes to double-check, you can always peek at Microsoft’s or Apple’s official guides for more deets.
