How Can I Stop My Internet From Cutting Out and Fix DNS Connection Issues?
314 viewsComputer
If your internet connection keeps dropping, and you can’t seem to connect to a DNS, you’re not alone. But don’t worry; we’ve got some tricks up our sleeve to get you back online. Let’s dive into a simple guide that’ll help you troubleshoot this pesky problem.
So here’s the scoop. The DNS is like the internet’s phonebook, turning website names we type in (like www.example.com) into something computers understand: IP addresses. When this service hiccups, you’ll get those annoying “DNS server is not responding” errors, and it’ll feel like you’re locked out from all your favorite sites.
Fixing DNS Connection Issues: Step by Step
  1. Start with the Basics: Your Network Connection
    • Check if your device is getting any internet love. Test other devices on the Wi-Fi to see if your network is just having a bad day.
    • Switch it up—use Ethernet instead of Wi-Fi. Sometimes, going old school can make all the difference.
  2. Kick-start Your Router
    • Unplug that power cable, wait a half-minute, and plug it back in. It’s the electronic version of a coffee break—it sounds simple, but it clears up minor hiccups.
  3. Give Your DNS Cache a Fresh Start
    • If you’re using Windows:
      1. Fire up your Command Prompt with admin powers.
      2. Type ipconfig /flushdns and hit Enter. Easy peasy.
    • If you’re on macOS:
      1. Open up Terminal.
      2. Input sudo killall -HUP mDNSResponder and press Enter. Look at you, tech savvy!
    • This little move clears out any bad stuff hiding in your DNS cache.
  4. Go for a DNS Server Swap
    • Your ISP’s default DNS might be taking a nap. Try something more reliable, like Google’s servers.
    • Switch to:
      • Primary: 8.8.8.8
      • Secondary: 8.8.4.4
    • Here’s how you do it:
      • On Windows: Jump to Control Panel > Network and Internet > Network Connections > right-click your active link > Properties > Internet Protocol Version 4 (TCP/IPv4) > Properties > Use the following DNS server addresses.
      • On macOS: Tweak settings in System Preferences > Network > select your current network > Advanced > DNS tab > tap the “+” button to add new servers.
  5. Try Turning Off IPv6
    • Sometimes, IPv6 can be the troublemaker. Turn it off if you suspect it’s causing trouble.
    • On Windows:
      1. Head to Network Connections.
      2. Right-click your connection and hit Properties.
      3. Uncheck “Internet Protocol Version 6 (TCP/IPv6)” and you’re done.
    • On macOS:
      1. Navigate to System Preferences > Network.
      2. Pick your active connection and go Advanced.
      3. Under TCP/IP, set “Configure IPv6” to “Link-local only.”
  6. Update Your Network Adapter Drivers
    • Rusty or broken drivers can be a huge issue.
    • If you’re on Windows:
      1. Right-click Start and slide into Device Manager.
      2. Expand Network adapters, right-click your adapter, and pick Update driver.
  7. Turn Off Security Software—Just for a Bit
    • Your firewall or antivirus might be blocking internet access like an overprotective parent.
    • Disable these temporarily and see if that helps; just remember to switch them back on afterward.
  8. Use Built-In Troubleshooter Tools
    • Got a problem? These troubleshooters can save the day:
      • On Windows: Settings > Update & Security > Troubleshoot > Additional troubleshooters > Internet Connections.
      • On macOS: Hold Option and click the Wi-Fi icon in the menu bar, then select “Open Wireless Diagnostics.”
  9. Give Your Computer a Time-Out
    • A simple restart might kick those problems to the curb. Who knew?
  10. Reach Out to Your ISP
    • If it feels like you’ve hit a dead end, check if your ISP is having issues. They might be able to solve it.
Work your way through these steps, and you should be able to tackle most DNS-related troubles.
In a nutshell, dealing with DNS server issues often means pulling out all stops. Give these steps a shot—from router restarts to updating network drivers, to getting your ISP on the line. You got this!
Dealing with constant internet dropouts and DNS issues? Yeah, that can seriously throw a wrench in your day. So, let’s dive into some no-nonsense fixes:
1. Give Your Router and Modem a Break:
Unplug both from the wall for about 30 seconds. Plug ‘em back in and wait until they’re fully back online. This can often clear up those annoying temporary glitches.
2. Tweak Your DNS Settings:
Try changing over to a public DNS like Google’s (8.8.8.8 and 8.8.4.4) or Cloudflare’s (1.1.1.1 and 1.0.0.1). Head into your network settings, swap it out, save, and see if that does the trick.
3. Clear Out That DNS Cache:
Pop open Command Prompt with admin rights, type in ipconfig /flushdns, and hit Enter. Then, restart your machine so everything locks in.
4. Keep Your Network Drivers Up-to-Date:
Launch Device Manager, find your network adapter, right-click it, and click “Update driver.” Follow the steps, then reboot your system.
5. Toggle the Network Adapter:
In the Network Connections section, right-click your network adapter and hit “Disable.” Wait a bit, then re-enable it.
6. Check for Router Updates:
Log into your router’s web interface and check if there’s a firmware update hanging around. If so, grab it and restart your router afterwards.
7. Reset Your Network Settings:
Head over to Network & Internet in your computer’s settings, find the “Network reset” button under Status, and follow the instructions. After that, reboot your PC.
8. Examine Cables and Connections:
Take a good look at your ethernet cables and connections. Make sure they’re snug and not damaged. Swap out any dodgy cables for a more reliable link.
These steps should help knock out most DNS hiccups. Still having trouble? Might be time to give your Internet Service Provider a call. They’ll dig deeper into what’s up.
