Why is My Windows 11 Version 10.0.22631 Experiencing Intermittent System Crashes?
510 viewsComputer
1 Answer
Intermittent system crashes with Windows 11 10.0.22631 can really throw a wrench in your daily grind. Here’s a rundown to help get you back on track:
1. Check for Windows Updates:
Alright, first off, see if there are any updates waiting for you. Sometimes the solution lies in downloading the latest software fixes.
Here’s how:
  1. Head over to Settings > Windows Update.
  2. Hit Check for updates and install anything new.
2. Update Drivers:
Outdated drivers are notorious for sending your system haywire. Let’s make sure they’re all up-to-date.
Steps:
  1. Fire up Device Manager.
  2. If you spot any warning icons, right-click and select Update driver.
  3. Follow the prompts to let Windows handle it.
3. Perform System File Check:
This one might sound techy, but running the System File Checker is actually super straightforward.
How to do it:
  1. Launch Command Prompt as an administrator.
  2. Type sfc /scannow and hit Enter.
  3. It might take a while, so grab a coffee while you wait.
4. Check Your Hardware:
It’s not usually the first thing people check, but hardware issues can be sneaky troublemakers.
Steps:
  1. Try Windows Memory Diagnostic for RAM issues.
  2. Use chkdsk /f /r via Command Prompt to check your hard drive.
5. Disable Overclocking:
Overclocking might supercharge performance, but it could also destabilize your system. How to go back to the norm:
Steps:
  1. When you restart, jump into BIOS/UEFI settings.
  2. Make sure overclocking settings are reverted to default.
6. Perform a Clean Boot:
A clean boot is handy for figuring out if some app is causing issues. Here’s how you go about it:
  1. Look up msconfig in the search bar and smash Enter.
  2. Navigate to System Configuration, then the Services tab.
  3. Hide all Microsoft services and disable the rest.
  4. In the Startup tab, hit Task Manager.
  5. Turn off all the startup items and reboot.
7. Reinstall Windows:
If you’re still stuck, reinstalling Windows after securing your important stuff might be your last resort.
Steps:
  1. First thing’s first: backup anything you can’t live without.
  2. Use the Media Creation Tool to make installation media.
  3. Boot from there and follow the cues to start fresh.
Stick to these steps to hopefully get a handle on those pesky crashes plaguing Windows 11 10.0.22631.
Resources:
  • Microsoft Support
  • Windows Central
