How to Use Your Phone as A Mic on Pc?
433 viewsPhone
If you’re itching to use your phone as a microphone for your PC, you’re in luck! Here’s a straightforward way to get things rolling whether you’re on Android or iPhone. It mostly involves downloading an app on both your phone and computer, so it’s easier than mixing cocktails.
Rocking the Android Mic
First up, we have the trusty Android.
  • Grab AudioRelay:
    • Head over to the Google Play Store and snag the AudioRelay app for your Android device.
    • Then leap over to your Windows PC and download the AudioRelay client from their official site.
  • Set Up Your Phone:
    • Fire up the AudioRelay app on your Android.
    • Jump to the “Server” tab and hit “Microphone.” Now you’re broadcasting, baby!
  • Get Your PC in Tune:
    • Open the AudioRelay client on your computer.
    • In the “Player” tab, select “Mic” for the output mode.
    • Check out the list of servers and tap on your phone to connect.
  • Make it Official:
    • Right-click on the sound icon down in your taskbar and choose “Sounds.”
    • Flip to the “Recording” tab, find “Virtual Mic for AudioRelay,” and set it as your default setup.
  • Give it a Test Drive:
    • Bust out Zoom or Discord—whatever tickles your fancy.
    • Make sure the app’s settings are cool with “Virtual Mic for AudioRelay” as the mic input.
    • Breathe life into your phone, and watch the audio levels dance if everything’s in sync.
iPhone in the Mic Mix
Switching gears to the iPhone:
  • AirDroid Invites You:
    • Go hunting in the App Store for AirDroid Cast on your iPhone.
    • Swing by your Windows PC and download AirDroid Cast from the official page.
  • Link the Tech:
    • Boot up AirDroid Cast on your PC and jot down the code or scan the QR code.
    • On your iPhone, hop onto AirDroid Cast, hit up “Cast Screen,” and punch in the code or scan away.
  • Mic Streaming Magic:
    • Once you’re connected, tap “Start Broadcast” and flip that microphone toggle in AirDroid Cast.
  • Check the Mic One, Two:
    • Peek into your PC’s sound settings to make sure AirDroid Cast is the input device.
  • See if You Can Hear Me Now:
    • Just like before with Android, pull up any microphone-reliant app to check if AirDroid Cast is your chosen one.
A Few Nuggets of Wisdom
  • Keep both devices on the same Wi-Fi—it’s the secret sauce for smooth sailing.
  • If you’re facing glitches, maybe poke around firewall settings or check if anything’s hogging your microphone mojo.
  • Want more options? Apps like WO Mic can also get you there, but spare some time for setup.
By following these steps, you can wing it using either an Android or iPhone as your PC’s mic—no extra gadgets needed!
And there you have it—a juicy guide to using your phone as a PC mic that’s laid-back and packed with personality!
Hey folks! Ready to transform your smartphone into a microphone for your PC? Whether you’re diving into streaming, gaming, or just trying to sound crystal clear on a video call, using your phone as a mic can be a lifesaver. Let’s jump into some cool ways you can do this, tackle a few hiccups that might pop up, and understand why these steps are the real deal.
Getting the Right App (Wi-Fi, USB, or Bluetooth)
Try out apps like WO Mic or SoundWire. They can do magic by connecting your phone to your PC in no time. Why do these apps rock? They create a virtual audio driver that ties your devices together.
Here’s how you can run with this:
  1. Get the App: First things first, download the app on your phone and your computer.
    • On your phone, search for “WO Mic” (available for Android and iOS).
    • On your PC, grab the client from the app’s site.
  2. Hook It Up:
    • Wi-Fi: Make sure both devices are partying on the same network. Launch the app on your phone, jot down the IP address it shows, and type it into the PC client.
    • USB: For Android, flip on USB debugging in settings (hunt for Developer Options). On iOS, trust the connection when it prompts you. Plug it in and hit the “USB” option.
    • Bluetooth: Get your devices to buddy up in your system’s Bluetooth settings, then click “Bluetooth” in the app.
  3. Set it Default: Make that virtual mic the star by selecting it as the default in your PC’s sound settings. On Windows, it’s as easy as heading to Settings, then Sound, then Input.
If Things Don’t Go as Planned:
  • Connection Woes: Could be firewall or antivirus playing spoilsport. Give them a break, or double-check that IP if you’re on Wi-Fi.
  • Lag Trouble: To smooth things over, opt for USB since Wi-Fi can slow you down.
Going Old School with Bluetooth
There’s the good ol’ Bluetooth route, though it’s a bit finicky. Some phones can pull this off thanks to certain Bluetooth profiles, but the quality ain’t always top-notch.
Steps to Get Rolling:
  1. Pair ‘Em Up: Fire up Bluetooth on your gear. On Windows, aim for Settings > Devices > Bluetooth.
  2. Make it Talk: Right-click on the sound icon, head over to Sounds > Recording. If your phone’s showing up, set it as the default.
What’s the Catch?
  • Be aware, not every phone can handle this. It’s worth a check using a basic voice recording app first. Don’t expect audiophile quality here, though.
Android Exclusive: USB Audio Routing
Some Androids can act as USB mics, thanks to USB OTG support. Not all phones play nice with this method, but it’s worth a shot.
Here’s the Downlow:
  1. Enter Developer Mode: Navigate to Settings > About Phone; tap “Build Number” seven times until you unlock Developer Options.
  2. Flip the Switch on USB Audio: In Developer Options, turn on USB Audio Routing.
  3. Plug and Play: Connect your phone with a USB cable. On your PC, head to Sound Settings and select your phone as the input.
Using Third-Party Tools (Discord/Zoom)
If you spend time on apps like Discord, this might be right up your alley. These platforms can let you use your phone as an input mic.
Here’s the Deal:
  1. Install the app on both your devices.
  2. Join the same call on each.
  3. Mute your PC’s mic and let your phone take the stage.
What’s the trade-off? This trick works only inside these apps and won’t help outside their bubble.
Common Glitches & Quick Fixes
  1. Silence…Why?: Could be pesky permissions. Make sure the app’s got the green light to use your mic.
  2. Buzzkill Background Noise: Might be interference; switch to USB or sit closer to that router.
  3. Driver Drama: Too many drivers butting heads. Disable what you don’t need in Sound Settings > Recording.
Why Choose Your Phone as a Mic Anyway?
  • Your smartphone might just outshine budget PC mics, especially with noise cancellation. Plus, it’s a handy alternative, especially if you’re on the move or penny-pinching.
By rolling with these tips, you’re all set to make the most out of your phone’s audio powers. USB’s your best bet for rock-solid connections, but play around with different apps to find what sings to you.
So, you wanna use your phone as a PC mic? No worries, I’ve got you covered. Whether you’ve got an Android or an iPhone, there are some neat tricks to get this rolling:
Android Users, Listen Up:
1. Grab WO Mic:
– Get the WO Mic App from Google Play on your phone.
– Then download the WO Mic Client and WO Mic Virtual Device on your computer.
2. Pair Your Devices:
– Fire up the WO Mic app on your phone, dive into the settings, and pick a connection method (Wi-Fi, Bluetooth, or USB).
– Do the same on the WO Mic Client on your PC.
3. Time to Rock:
– Hit start on your phone’s app.
– Then, tap connect on your PC client. Voilà, your phone’s now your very own mic!
Now, For the iPhone Crowd:
1. Megaphone Magic:
– Install the Megaphone App from the App Store.
2. Plug In and Play:
– Connect your iPhone’s headphone jack to your PC’s mic input with a 3.5mm cable (you might need that lightning to 3.5mm adapter).
3. Get Going:
– Switch on the Megaphone app. Bam, your iPhone’s ready to be your mic.
Here’s Some Extra Juju for Both Android and iPhone:
1. Get Microphone Live:
– Download Microphone Live if you’re on an iPhone.
2. Connect Over Wi-Fi:
– Make sure your phone and PC are on the same Wi-Fi.
– Start broadcasting with the app. Now, you might need something like SoundWire on your PC to snag the audio signal from your phone.
Honestly, these hacks can turn your smartphone into a pretty nifty mic for your computer. Just make sure everything’s in sync to keep the sound crisp and clear.
If things get tricky, definitely hit up some tech forums or the official app websites for more tips and advice.
