How Can I Uninstall Games on PS5 Without Losing Data?
529 viewsGame Console
The PlayStation 5 is an incredible gaming console with a bit of a hiccup when it comes to storage space. As you stack up more and more games, you might eventually need to clear some room. But don’t stress—uninstalling games doesn’t mean you have to kiss your game progress goodbye. If you do it the right way, you can free up space without losing any valuable data. Let’s dive into how you can do this:
Why You Might Need to Uninstall Games
  • Limited Storage Space: The PS5 comes with just 825GB of storage, and once the system files are accounted for, you’re left with about 667.2GB. That space fills up fast with today’s massive game sizes, so you might find yourself needing to delete some games to make way for new ones.
  • Data Preservation: You’ve probably invested countless hours into your games, and the last thing you want is to lose that progress. Luckily, you can uninstall games while keeping your save data intact so you can jump back in whenever you’re ready.
Ways to Uninstall Games Without Losing Data
  • Uninstalling via the Game Library:
    • Power on your PS5 and head to the home screen.
    • Navigate to the Game Library.
    • Find the game you want to uninstall, highlight it, and press the Options button on your controller.
    • Select “Delete” from the menu that pops up.
    • Confirm by selecting “OK.” The game will be uninstalled, but your data will stay safe.
  • Uninstalling via Settings Menu:
    • From the home screen, go to the Settings menu.
    • Select “Storage” and then “Games and Apps.”
    • You’ll see a list of your installed games. Select “Delete Content.”
    • Choose the games you want to uninstall but avoid selecting save data by mistake.
    • Confirm the deletion to start the uninstallation.
  • Uninstalling via PlayStation App:
    • Open the PS App on your mobile device.
    • Tap the gear icon in the top-right corner of the “Play” tab.
    • Tap “PS5 Storage” at the top.
    • Select the game you want to delete and tap “Delete Game.”
    • Your PS5 will automatically delete the game the next time it’s in Rest Mode or when you turn it on.
Keeping Your Data Safe
  • Local Storage: On the PS5, your game save data is stored separately from the game files, so when you uninstall a game, your save data remains untouched. Just be careful not to delete it unless you really want to.
  • Cloud Saves: If you have a PlayStation Plus subscription, your save data gets backed up to the cloud automatically. Even if you lose local data or uninstall the game, you can always download your cloud save to pick up right where you left off. This is also super handy if you switch or upgrade consoles.
Handy Tips
  • Double-Check Before Deleting: Always make sure you’re only deleting the game files and not your save data. Errors here can be a real pain.
  • Back Up Important Data: Even though your save data should remain safe, it’s never a bad idea to back up critical progress to an external drive or the cloud. Better safe than sorry, right?
  • Manage Cloud Save Sync: Keep your PlayStation Plus subscription active and make sure cloud save sync is turned on in your settings. This keeps your cloud saves up-to-date with your latest game progress.
So yeah, it’s totally possible to uninstall games on your PS5 without any data loss. Just make the most of the PS5’s storage settings and cloud features to keep your progress intact. Happy gaming!
Alright, so you’ve got a game or two hogging up space on your PS5, but you’re worried about losing all your progress? No sweat—here’s how to keep your saved data safe while freeing up some storage.
First thing’s first: You want to be sure your game saves are backed up. If you’re on PlayStation Plus, your saves can hit the cloud automatically. Here’s the deal:
  1. Hit up Settings from the main screen.
  2. Head over to Saved Data and Game/App Settings.
  3. Pick Saved Data (PS5) or Saved Data (PS4) depending on what you’ve got.
  4. Flip that Auto-Upload switch on if it’s not already.
And just like that—your game progress is safely stashed away.
Next up, figure out which games are eating up the most room on your PS5:
  1. Go into Settings from the main screen.
  2. Select Storage.
  3. If you’ve got an external drive, you can choose between Console Storage or Extended Storage.
  4. Check out Games and Apps to eyeball what’s using up all your space.
Once you know the culprits, you’ll have an idea of what should go.
Now, choose the game you’re ready to part with and follow the steps below:
  1. From the main screen, highlight the game you’re ditching.
  2. Hit that Options button on your controller.
  3. Select Delete from the list.
  4. Confirm when it asks.
This cleans out the main game files but keeps your saves nice and cozy.
After you’ve done the deed, double-check that your saved data is still kicking around:
  1. Go back to Settings > Saved Data and Game/App Settings.
  2. Revisit Saved Data (PS5) or Saved Data (PS4) to see your game saves.
If everything went right, your data should still be there, unless you, you know, deleted it yourself.
Changed your mind? No problem! Here’s how to reinstall the game:
  1. Hop into your Game Library from the main screen.
  2. Find the game—it’ll live under your purchased titles.
  3. Give the download icon a click.
Your saved data will jump back on your console thanks to that lovely cloud sync.
Keep your games backed up, be smart about your storage space, and uninstall without worry. Seriously, it’s as easy as pie—and you won’t lose any precious progression along the way!
How to Uninstall Games on PS5 Without Losing Data
Getting rid of games on your PS5 isn’t rocket science, but keeping your save data safe is a bit more involved. Here’s the lowdown on how you can clear some space without sacrificing your progress.
What’s Up with PS5 Game Data?
When it comes to game data, your PS5 keeps things pretty neat with two separate categories:
  1. Game Application: This is the main bulk of files, gobbling up space on your console’s SSD or external storage.
  2. Save Data: Your hard-earned progress lives separately. It can be local or up in the cloud if you’re rocking PlayStation Plus.
Thanks to this setup, uninstalling a game won’t wipe out your save data. Pop the game back in anytime, and your progress is right where you left it.
Doing the Deletion Dance
Here’s how you can kick those games to the curb but keep your data:
Method 1: Inside the Game Library
  1. Head over to your Game Library from the PS5’s home base.
  2. Tap into “Your Collection” to see what’s installed.
  3. Find the game you’re saying goodbye to.
  4. Press the Options button on the controller.
  5. Pick “Delete” and confirm it—goodbye game!
Method 2: Straight From the Home Screen
  1. Locate the game tile right on the home screen.
  2. Options button—hit it!
  3. Select “Delete” and confirm. It’s that easy.
Keep in Mind:
  • Your save data chills in the “Saved Data and Game/App Settings” section, tucked away under Settings > Storage.
  • Cloud saver? Switch on Automatic Uploads with PlayStation Plus to keep everything backed up.
Got Concerns? We’ve Got Solutions!
1. Whoops! Accidental Save Data Deletion
  • Cause: Manually deleting files through Settings > Storage > Saved Data.
  • Solution: Steer clear of the “Delete Saved Data” option unless you mean it. Double-check before you hit that delete.
2. Low Storage Blues After Uninstalling
  • Cause: Those pesky leftover save or cached files.
  • Solution:
    • Manually clean out old save files via Settings > Storage > Saved Data.
    • Give your console some TLC with “Console Storage Maintenance”.
3. Getting Back On Track: Reinstalling Games
  • Your save data should hit the ground running once you reinstall. For disk games, just make sure the game version jives with your save region.
Quick Tips for Peace of Mind
  • Backup Regularly: Count on PlayStation Plus cloud storage or slap a USB drive into action for those all-important saves.
  • Get Proactive with Storage: Scrub out unused games and check your save data every month like clockwork.
By following these steps, you can declutter your PS5 without losing a minute of gameplay. And if technology acts up, make sure your system software is up to snuff.
Getting rid of a game on your PS5 but don’t want to lose your hard-earned progress? Don’t worry. It’s a breeze! Here’s how you can do it:
First things first, make sure your saved data is comfortably resting either on your PS5 or in the cloud, especially if you’re a PlayStation Plus member. You can double-check this by going to Settings, then hitting Saved Data and Game/App Settings, and looking under Saved Data (PS5) in Console Storage.
Now, if you’ve got PlayStation Plus, consider backing your saves up to the cloud. You don’t want any nasty surprises later on. Head over to Settings again, choose Saved Data and Game/App Settings, and then Sync Saved Data. Be sure to turn on Auto-sync Saved Data to keep everything tip-top without lifting a finger.
Alright, let’s kick that game off your console. Go to your main menu, find the Game Library, and pick the game that’s taking up space. Hover over it, hit the Options button on your controller, and smack Delete. Say goodbye to the game—but don’t worry, your save files aren’t going anywhere.
After clearing space, just do a quick check to ensure your save data is still there. Hop into Settings, Saved Data and Game/App Settings, then once again, Saved Data (PS5) in Console Storage. If you see your files, you’re golden.
What’s cool is, when you feel like reinstalling the game later on, your saved data will be sitting there, waiting for you, whether it’s on your console or in the cloud. It’s like a digital safety net! Just make it a habit to back up those saves regularly, especially if you’re juggling a bunch of games.
Following these steps will keep your PS5 storage clear without messing up your game progress. Happy gaming!
