What’s the easiest way to turn on white noise on your iPhone?
Here’s a nifty trick for using your iPhone as a source of white noise. Whether you’re looking to chill, sleep better, or just need some peace, your iPhone’s got your back. It’s super simple, I promise.
First off, dive into your iPhone’s Settings. You’ll want to scroll down and tap on ‘Accessibility’. From there, look for ‘Audio/Visual’. Here’s where all the magic happens—tap on ‘Background Sounds’ and flip that switch to turn it on. Just like that, you’ve got a calming sound going.
But wait, there’s more to play around with. Tap ‘Sound’ and you’ll get to choose between Rain, Stream, Ocean, or even different noise levels like Balanced Noise. It’s like having your personal sound spa right in your pocket.
You can also tweak the volume to make sure it’s just right for you. And if you’ve got some tunes playing, you can let the background sound roll right along with it. Or, if you’re more chill with just the sound when your phone isn’t locked, there’s an option for that, too.
And here’s another cool thing: pop this feature into your Control Center for quick access. Plus, by setting up an Accessibility Shortcut, you can simply triple-click the Home or side button to start or stop the sound in a jiffy.
This feature works with iPhones running iOS 15 or later, so if you’ve got an older model like the 6S, just make sure your software is up to date. Seriously, it’s pretty awesome to have these sounds at your fingertips whenever you need a moment to chill or focus.
White noise on iPhones is a fantastic trick to help you sleep better, focus more, or drown out annoying background noise. Since iOS 15, Apple has made it super easy with built-in sounds like Rain, Ocean, Stream, or just good ol\’ White Noise. Here\’s a quick rundown on how to get started, fix any hiccups, and get the most out of it.
How to Turn It On
Built-in Background Sounds
First things first, you need to be running iOS 15 or newer, which works on iPhone 6S or later models.
Quick Access via Control Center:
- Head to Settings > Control Center.
- Add the Hearing option by tapping the +.
- Open Control Center by swiping down and tap the Hearing icon.
- Select Background Sounds and pick your noise — Rain is the default.
The Longer Route via Settings:
- Go to Settings > Accessibility > Audio/Visual.
- Flick on Background Sounds and set your preferences.
Cool Things It Does:
- It pauses automatically when you start playing music.
- It lets you adjust the noise volume relative to other audio.
Going Beyond: Third-Party Apps
If you want to mix things up a bit, try apps like \”White Noise: Baby Sleeper\” which have other cool sounds, even ones mimicking a hair dryer!
How to Get These Apps:
- Fire up the App Store and make sure you’re online.
- Search for “white noise” and download something like \”White Noise: Baby Sleep Sounds.\”
- Open the app, choose your favorite sounds, and set up a timer if you like.
Common Glitches & Fixes
Missing the Hearing Button?
- Probably wasn\’t added to your Control Center. Just pop back into Settings and add it.
Background Sounds Not Playing?
- Check if your iOS is up to date (iOS 15 or newer needed).
- If you\’re listening to something else, Background Sounds might pause. You can fix this in Settings > Accessibility > Audio/Visual.
Worried About Battery Life?
- Keep the volume down if you’re using it overnight.
- Use a timer in third-party apps so it doesn’t run forever.
Why It’s Worth It
This sound equalizer is like having a noise mask to manage distractions like city traffic. It\’s been shown to help people sleep, focus, and chill out. Apple made it super user-friendly, so it’s perfect for anyone needing a little quiet.
For those who want to mix things up, you can even play around with your audio/visual settings to layer it with your music. And if the default sounds don’t cut it, there’s a whole world of apps to try out.
Having both built-in options and apps gives you tons of flexibility to find what works best for you. If something\’s acting up, don\’t worry; there are solutions to most common issues right at your fingertips.
Want to get some white noise going on your iPhone without any extra apps? Here’s how you can do it easily:
- Open up Settings: First, head over to the Settings app from your home screen – you know, the one that looks like gears turning.
- Find Accessibility: Scroll down a bit and you’ll see Accessibility. Tap on that. It’s where Apple stashes all sorts of handy features.
- Dive into Audio/Visual: Once you’re in Accessibility, keep scrolling until you spot Audio/Visual. That’s your next stop.
- Go for Background Sounds: Look for the Background Sounds option inside Audio/Visual. Tap it, and you’re almost there!
- Switch on Background Sounds: Flip that switch to turn on the feature. As soon as you do, you’ll start hearing some relaxing ambient noises.
- Pick Your Sound: You’ve got choices here! Tap on Sound and take your pick—whether you’re into “Balanced Noise” or something darker, they’ve got you covered.
- Set the Volume: Adjust the Volume slider to get the sound just right, not too loud and not too soft.
- Play with More Settings (Optional): If you want, fiddle with the advanced settings to decide if the sound should keep playing while you’re watching videos or during calls. Totally up to you!
And there you have it. You’re all set to enjoy some background noise without any app downloads. It’s a nice little feature for chilling out or staying focused when you need it.
