How to Turn on Ps5 Without Controller?
421 viewsGame Console
Turning on a PS5 without a controller can come in handy, especially when your controller is out of battery, acting up, or you just don’t feel like dealing with it. There are a few tricks you can use to fire up your console without the controller. Let’s dive in:
Use the PS Remote Play app
  • Download the PS Remote Play app: Grab it from Google Play™ or the App Store and install it on your mobile device.
  • Enable Remote Play on your PS5: Fire up your PS5, head to “Settings”, go to “System”, and toggle on the “Remote Play” feature.
  • Connect the app to your PS5: Open the app on your phone, sign in with your PSN account, and let the app find and hook up to your PS5.
  • Turn on the PS5 remotely: Once you’re connected, use the app to turn on your PS5 and even navigate the menus or play games.
Use the physical power button
  • Locate the power button: It’s on the front of your console — if your PS5 is upright, it’s the lower button; if it’s laid flat, it’s the button on the left.
  • Press the power button: Just push it to turn on the PS5. If it’s in rest mode, this will wake it up.
Use HDMI Device Link
  • Check your TV for HDMI Device Link: Make sure your TV supports it and enable it following your TV’s manual.
  • Connect PS5 to the TV via HDMI: Get an HDMI cable and connect your PS5 to your TV.
  • Use your TV remote: Control your PS5 using the TV remote, including turning it on or off, navigating menus, and more.
Use a keyboard and mouse
  • Hook up a keyboard and mouse: Plug them into your PS5’s USB ports.
  • Navigate with the keyboard and mouse: Use them to move through the PS5 menus and play games that support these peripherals.
Use voice commands
  • Set up voice commands on your PS5: Make sure you’ve got a microphone connected, whether it’s an external mic or a compatible headset.
  • Command your PS5: Say “Hey, PlayStation,” followed by your command, like “Turn on the PS5” or “Open [Game Title]”.
Use a universal remote
  • Program your universal remote: Follow the setup instructions to get it working with both your TV and PS5.
  • Control PS5 with the remote: Use it to turn on the PS5, navigate menus, and manage media playback.
Use the PS5 companion app
  • Get the companion app: Download and install the PlayStation app on your mobile device.
  • Sync the app with your PS5: Sign in with your PSN account on the app to connect it to your console.
  • Turn on the PS5: Power on your PS5 and access other features through the app.
Use a Cronus Zen adapter
  • Connect the Cronus Zen: Plug the adapter into your PS5 via USB.
  • Attach a controller to the Cronus Zen: Hook up an alternative compatible controller to the adapter.
  • Turn on the PS5: Use the physical button on the console or the PS Home button on the connected controller.
Use the Wake-on-LAN feature
  • Enable Wake-on-LAN on your PS5: Go to “Settings” -> “System” -> “Power Saving” and turn on “Enable Turning on PS5 from Network”.
  • Use a network device to wake up PS5: From a device like your computer or phone on the same network, send a Wake-on-LAN command to your PS5.
So, there you have it. Several ways to get your PS5 up and running without the controller. Whether you’re into smartphone apps or you have a knack for techie tweaks, there’s probably an option here that’ll work for you.
Want to switch on your PS5 without reaching for that controller? No sweat! Here’s how you can do it:
  1. Find the Power Button: Look no further than the front of your PS5. On the Digital Edition, it’s the only button on there since there’s no disc drive to worry about.
  2. Give the Power Button a Press: A gentle press is all it takes to power up your PS5. If it’s been lounging in Rest Mode, just tap the button, and it’ll wake right up.
  3. Hold the Button If Needed: Let’s say you want to make sure it’s fully off or slipping into Rest Mode—you can hold down that power button. One beep means Rest Mode; two beeps, and it’s completely shutting down. Hear that second beep? Lights out for your PS5!
  4. Remote Play is Your Friend: Not at the console? No problem. If you’ve set up Remote Play and got everything connected to the internet, grab your phone with the PS Remote Play app. It’s a handy way to wake up your console from afar.
So, that’s basically all you need to know to get your PS5 going without a controller! Easy as pie, right?
So You Want to Turn On Your PS5 Without a Controller? Let’s Dive In!
Maybe your controller went AWOL or took an unfortunate spill down some stairs—don’t worry. There are a number of ways to bring your PlayStation 5 (PS5) back to life without that trusty wand of gaming magic. Let’s jump right in and see what’s what.
A Few Tricks to Get Your PS5 Up and Running Sans Controller
Hitting the Power Button—Old School Style
First things first. The PS5 sports a good old-fashioned physical power button right on its lovely face. If you’re looking for simple, this is your golden ticket.
  • How to do it:
    1. Find that button: It’s a little vertical groove on the console’s front panel. Right beneath the disc slot for those rocking the disc edition.
    2. Give it a press: Tap it lightly if you’re coming out of rest mode, or give it a solid 1-2 second press if it’s totally powered down. Your console should make a happy beep sound.
    3. Pro Tip: No beep? Check it’s all plugged in and ready for action.
Got a PS5 Media Remote?
No controller? No problem. If you’ve snagged yourself a PS5 Media Remote, you’re in luck. It’s got a power button ready for action.
  • What to know:
    • Your PS5 needs to be in rest mode, not catching Z’s in full shutdown.
    • You should’ve already paired that remote, otherwise, it’s just a fancy TV remote.
  • How it works:
    1. Smack that Power button, or the PS button, on your remote.
    2. If nada happens, maybe swap out those batteries or double-check the pairing game.
Phone to the Rescue with PlayStation App
Here’s a cool one: you can shake your PS5 awake with the PlayStation App on your smartphone. It’s pretty nifty if things are set up right.
  • Here’s what you need:
    • Make sure your PS5 is sleeping in rest mode and set to stay connected to the internet.
    • Your phone and console need to be on the same network hitched up to your PSN account.
  • Steps to awaken the beast:
    1. Open up the PlayStation App and log into your PSN account. Simple stuff.
    2. Go to “Connect to Console” and give your PS5 a little wake-up call.
HDMI Device Link (HDMI-CEC)—TV Magic
If your TV’s got some handshake skills with HDMI-CEC, it can get your PS5 dancing when the TV struts its stuff.
  • Need-to-know:
    • HDMI-CEC settings gotta be activated both on your TV and PS5.
    • Ensure your PS5’s chilling in rest mode and plugged in via HDMI.
  • Do this:
    1. Fire up your TV using its very own remote.
    2. With the right setup, your PS5 should spring to life on cue.
    3. If HDMI-CEC isn’t stirred up on your PS5 yet, check the settings: Go to Settings > System > HDMI > Enable HDMI Device Link.
You Might Want to Check the Power Supply
If your PS5 is refusing to budge even in the presence of a controller, maybe the issue lies in the power supply.
  • What you could try:
    1. Ensure the power cable is snug as a bug in a rug both into the PS5 and the outlet.
    2. Give the outlet a whirl with another device.
    3. If you happen to have an extra power cable, swap it out and see if that does the trick.
What if Trouble Comes Knocking?
Physically pressed the power button and got no love from your console?
  • Fixes to attempt:
    • Reset the power dance: Unplug your PS5 for a minute or two, then plug it back in like nothing ever happened.
    • If your PS5’s still playing hard to get, you might have a hardware issue on your hands. Time to give Sony support a shout.
Remote or app methods giving you grief?
  • Steps to remedy this:
    • Make sure your PS5 is actually snoozing in rest mode and not entirely off.
    • Check that your network is giving everything the green light for the PlayStation App.
    • Try re-pairing the Media Remote by heading to Settings > Accessories > Bluetooth Accessories.
Few Final Thoughts to Keep You Straight
  • Rest Mode vs. Shutdown: Most remote-related tricks need your PS5 to be in rest mode. Head to Settings > System > Power Saving > Features Available in Rest Mode to put it in the right groove.
  • Controller Drama?: If your controller’s shot, you might need a new one or try a little USB re-pairing magic.
With these tips at your fingertips, you should be able to wake your PS5 without its usual sidekick. And if things get a bit hairy, don’t hesitate to tap into Sony’s support resources. Game on!
Turning on your PS5 without a controller might sound tricky, but it can be done with a bit of ingenuity. Here’s how to go about it:
First up, the good old-fashioned way involves the Power button on the console itself. You’ll find this button on the front panel near the bottom of your PS5. Just give it a quick press, and you’re in business. If you need Safe Mode, keep the button pressed for about 7 seconds until you hear that sweet second beep.
Now, if you’re looking for a modern workaround, let’s talk about PS Remote Play on your mobile device. You’ll need to snag the app from either the Apple App Store or the Google Play Store and sign into your PlayStation Network account. Here’s the thing: your PS5 should be in Rest Mode and on the same network as your phone or tablet. Pick your PS5 from the list, follow the steps to connect, and voila! You can use on-screen controls to power up your console.
Or hey, if you’re more of a computer person, try PS Remote Play on your PC or Mac. Hit up the official PlayStation website, download the app, install and open it, then log in with your PlayStation Network account. Again, make sure your PS5 is lounging in Rest Mode and network-ready. Choose your console from the listed devices, run through the connection process, and you’re all set to turn on your PS5 from your computer.
Bottom line: Even if your controller’s gone on a little vacation—lost, busted, or battery dead—these nifty alternatives can keep your gaming sessions alive and kicking. Give one a shot!
