How to Turn Off Yellow Light on Alexa?
419 viewsSpeakers
If that pesky yellow glow on your Alexa has got you puzzled, let’s dive into how you can squash it:
That yellow light’s just Alexa’s way of nudging you about unread notifications or messages. Could be you missed a call, left a few messages unopened, or have an update on your Amazon orders. Before you go all out and try to turn it off, just make sure there aren’t any notifications you’re missing.
Here’s the Lowdown on Turning It Off
  1. Ask Alexa about Notifications:
    • Simply say, “Alexa, what notifications do I have?” or “Alexa, read my messages.” She’ll tell you what’s up, and snapping through these will usually nudge that yellow light away.
  2. Use the Alexa App:
    • Pop open the Alexa app on your phone.
    • Tap on More at the bottom, hit Settings, and then Notifications.
    • You’ll see various categories there. Dig through them and switch off any notifications you think might be unnecessary.
  3. Give Do Not Disturb a Whirl:
    • Not keen on notifications popping up for a while? Just turn on Do Not Disturb:
      • In the Alexa app, head over to Devices, select your Echo, and tap that half-moon icon (Do Not Disturb). That should do the trick.
  4. Try Restarting Alexa:
    • Still seeing yellow? It might be time for a restart. Just unplug your device for about 10 seconds and then plug it back in.
  5. Check for Any Updates:
    • Voice check for updates by saying, “Alexa, check for software updates.” If she’s got one, follow her lead to update.
  6. If All Else Fails, Reset:
    • As your final move, if none of the above does the trick, a factory reset might be your only bet:
      • Hold down the Action button for 25 seconds until you see the device flashing an orange and then a blue ring.
If you stick to these pointers, your yellow light concerns should be history. Echoing the steps: ask Alexa what’s up with notifications, manage the app settings, or go into Do Not Disturb mode. If needed, restart or reset the device.
Hey there! If you’re seeing a yellow light on your Alexa device, don’t worry—it’s a common thing and usually easy to fix. Here’s a straightforward guide to help you out.
First up, those pulsing or steady yellow lights might be Alexa’s way of letting you know there’s something unread, like a notification or an Amazon delivery message. Just say, “Alexa, what are my notifications?” and she’ll spill the beans. You can also dive into the Alexa app, check out the Reminders & Alerts section, and clear out anything that’s piling up. And if these notifications are more annoying than helpful, you can switch them off in the Settings section of the app for some peace of mind.
Next, if your Alexa is in setup mode, you’ll notice a spinning yellow light. It usually means it’s ready to connect to Wi-Fi or was recently reset. Pop open the Alexa app, head to Devices, find your gadget, and follow the steps to reestablish that Wi-Fi connection. Or, just press and hold the little Action button (the one with the dot) on the device for 15 seconds to make the yellow light vanish.
Now, if the yellow light pulses, it could be a hint that your Wi-Fi isn’t cooperating. Try giving your router a break for 30 seconds by unplugging it, and then plug it back in. You can also reconnect your Alexa to Wi-Fi through the app: go to Devices, select your Alexa, and change Wi-Fi settings. Make sure that Wi-Fi signal’s nice and strong—a weak signal could be the culprit here.
But what if it’s a software or firmware hiccup causing the light? No sweat! Alexa devices usually update on their own, especially during downtime. To nudge it along, unplug the device for about 20 seconds and then plug it back in. That little reset can often do the trick.
Sometimes, it might be the Amazon Sidewalk feature poking its nose in. To switch this off, go back to the app’s Settings, click on Account Settings, then Amazon Sidewalk, and turn it off.
If after all this the yellow light is stubborn, it might be a more serious hardware issue. A good factory reset might be in order. Hold that Action button again—20 to 25 seconds this time—until the light rings through orange and blue. Set it up again from scratch. Still no luck? Don’t hesitate to reach out to Amazon’s support team—sometimes, you gotta call in the pros!
And here’s a little extra pro tip: You can customize how Alexa’s lights behave using Alexa Routines, so check that out if you’re keen on personalizing things a bit more. If your device is a model like the Echo Show, refer to its specific guide—sometimes they do things a bit differently.
All said and done, tackling these yellow light issues head-on will usually get you back to enjoying all the great things Alexa can do. If things aren’t resolved after trying everything, it could be time for a replacement or some expert help.
Getting rid of that pesky yellow light on your Alexa? No sweat. Here’s how you can tackle it like a pro:
First off, that yellow light usually means you’ve got some notifications or messages waiting for you. So, let’s see what’s happening there:
1. Clear Up Notifications:
  • Alexa App Method: Just pop open the Alexa app on your phone and hit the “Communicate” button at the bottom. Look through your new messages or notifications and clear them out.
  • Voice Command Method: If you’re more of a talker, go ahead and say, “Alexa, what are my notifications?” Listen to whatever Alexa has to say and deal with it. You can also ask, “Alexa, delete my notifications,” if you want to clean the slate.
2. Change Notification Settings:
  • Make sure your notifications aren’t going wild. Open the Alexa app, hit “Devices” at the bottom, tap on your Echo device, and head into “Communications” settings to tweak them as you like.
3. Restart or Reset It:
  • Sometimes, a fresh start is all Alexa needs. Unplug it, wait half a minute, then plug it back in. If she’s being a real pain, factory reset by holding down the Action button for about 25 seconds.
4. Get Amazon on the Line:
  • When all else fails and that yellow light’s being stubborn, holler at Amazon Support. They’re decent at figuring out hardware hiccups or walking you through other fixes.
Following these steps should sort out that yellow light business on your Alexa device without too much hassle. Good luck!
