How Can I Turn Off 5G on My Samsung S20?
364 viewsPhone
If you’re looking to turn off 5G on your Samsung S20, here’s a step-by-step guide to help you out.
Why Turn Off 5G on the Samsung S20?
First off, let’s talk about the “why” before diving into the “how.” Here’s the scoop:
  • Battery Saver: Using 5G can drain your battery faster than 4G because it uses higher frequency bands and advanced tech. If you’re in an area with spotty 5G, your phone might be working overtime to find a signal, which really eats up your battery.
  • Coverage Issues: 5G isn’t everywhere yet. If you’re outside a major city, your S20 might constantly search for a 5G signal when there’s none to be found, which can drain your battery and make your connection unreliable. Switching back to 4G might save you a headache.
  • Network Congestion: Sometimes, 5G gets clogged up, especially in crowded places. You might find 4G offers a more stable connection during these times, making it better for things like video calls or gaming.
  • Compatibility: Occasionally, you might need to connect to older devices or services that aren’t optimized for 5G. Switching back to 4G ensures everything plays nicely together.
How to Turn Off 5G on Your Samsung S20?
Here’s the nitty-gritty on how to disable 5G:
Method 1: Using the Settings Menu
  1. Open the Settings app. You can either swipe down your notification shade and tap the gear icon or find it in your app drawer.
  2. Tap Connections.
  3. Choose Mobile Networks.
  4. Tap Network Mode.
  5. Select a network mode that doesn’t include 5G, like LTE/3G/2G.
Method 2: Via the Quick Settings Panel
  1. Swipe down from the top of your screen to bring up the Quick Settings panel.
  2. Find the Mobile Data icon. If you don’t see it immediately, swipe left to reveal more options.
  3. Long press the Mobile Data icon to jump straight to Mobile Networks settings.
  4. Follow the same steps as in Method 1 to switch off 5G.
Double-Check Your Settings
Once you’ve turned off 5G, have a look at the status bar on your screen. It should show “LTE” or “4G” instead of “5G,” confirming the switch.
Some Extra Tips
After switching to 4G, it’s a good idea to mess around with your network preferences to optimize data usage and battery life. If you run into connectivity issues after making the switch, try restarting your phone. Still not working? Head over to System Settings > General Management > Reset > Reset Network Settings to reset your network settings. Just remember, this will erase saved Wi-Fi passwords and Bluetooth connections.
There you have it! Turning off 5G on your Samsung S20 is pretty straightforward and can lead to a better overall experience, especially if 5G coverage is shaky in your area. Whether you’re looking to save battery or get a more reliable connection, switching back to 4G might be the way to go.
Want to ditch 5G on your Samsung Galaxy S20? Here’s how you can do it without any hassle:
First things first, dive into your phone’s Settings. Just swipe down from the top of your screen and tap the gear icon—that’s your shortcut.
Now, hit the Connections option. You should see it right there among your settings. This is your gateway to all things network-related.
Next stop is Mobile Networks. Inside the Connections menu, find Mobile Networks and give it a tap. You’re getting closer!
Time to tweak the Network Mode. Under Mobile Networks, you’ll spot Network Mode. Tap away to see what options are on the table.
Here’s the kicker: switch over to 4G/LTE. You’ll find options like 5G/LTE/3G/2G (auto connect). Pick “4G/LTE,” and, just like that, 5G is outta there, giving you that more familiar 4G vibe.
And that’s it! Give your settings a look-see to confirm everything’s good. Your Samsung Galaxy S20 is now cruising on a 4G connection.
Heads up, though: some folks have hit a snag finding these settings because of specific carrier tweaks or unique phone models. Heard of Samsung Band Selection? Some have found it handy when the usual route doesn’t cut it.
So, with this little walkthrough, you can tweak your network settings based on what your world (and data needs) are throwing at you. Happy surfing!
Turning Off 5G on Your Samsung Galaxy S20
So, you’re looking to ditch 5G on your Samsung Galaxy S20, huh? Totally get it. Here are some reasons you might want to switch back to good ol’ 4G:
  • Battery life’s a killer: Not gonna lie, 5G can zap your battery pretty quick, especially when signal’s sketchy.
  • Connectivity’s acting up: Sometimes 4G/LTE is like that reliable friend who’s always got your back.
  • Spotty 5G service: Let’s face it, not everywhere has the 5G setups of our dreams just yet.
Alright, let’s dive into how you can kick 5G to the curb.
Method 1: Turn Off 5G in Settings
  1. Open Settings:
    • Swipe down from the top and hit the little gear icon up there.
  2. Navigate to Connections:
    • Go into Connections then head to Mobile Networks.
  3. Poke into Network Mode:
    • Tap Network Mode.
    • If you spot options like 5G/4G/3G/2G (Auto Connect), switch it to 4G/3G/2G (Auto Connect) or LTE/3G/2G. Boom! 5G is out.
    Heads up: If you don’t see “Network Mode,” your carrier might have locked this down.
Method 2: Quick Settings Tile (One UI 3.1+)
Some Samsung models let you toggle 5G via the notification panel:
  1. Pull down the Quick Settings menu.
  2. Scope out a 5G or Mobile Data tile. Give it a long press for network options.
  3. Follow Method 1 to make the switch to 4G.
Troubleshooting: Can’t Find Network Mode? Let’s Sort This Out.
Issue 1: Carrier Restrictions
Some carriers (like Verizon or AT&T) might lock some settings on devices. Annoying, right?
  • Try This:
    • Hit up your carrier to ask for 4G mode access.
    • Or, cautiously try using a dialer code for hidden settings:
      • Open the Phone app, dial *#*#4636#*#*, hit Phone Information, and set Preferred Network Type to LTE Only.
Issue 2: Outdated Software
If your phone’s software is old, you might be missing some options.
  • Fix It:
    • Update your software: Go to Settings, tap Software Update, then Download and Install.
Issue 3: Regional Variations
Some international or Exynos models might have different labels on settings.
  • Solution:
    • Head to Mobile Networks > Network Operators > Select Manually, and pick a non-5G network.
A Couple More Tips
  1. Battery Saver Mode: Turning on Power Saving Mode in Settings > Battery might also curb 5G usage.
  2. Reset Network Settings: If things stay wonky, try going to Settings > General Management > Reset > Reset Network Settings.
So, Here’s Why We Care
5G’s a power hog because it uses higher-frequency bands, continually hunting for signals. Switching to 4G lightens the load a bit, helping with battery and connectivity. But hey, if you’re on a 5G-exclusive plan, double-check with your provider that going 4G won’t mess things up.
And if all else fails, maybe your device doesn’t support 4G fallback options, or there’s some hardware fuss. Don’t sweat it—give Samsung Support or your carrier a shout.
So, you’re looking to ditch the 5G on your Samsung S20, huh? Maybe the battery’s taking a hit or you’re in an area where 5G is more myth than reality. Anyway, here’s how you can make that switch to good ol’ 4G.
Kick things off by diving into your Settings – just tap the app on your home screen or wherever you keep it. Next, head over to the Connections section. It’s like the nerve center for anything network-related on your phone. Once you’re in, you want to hit up Mobile Networks. This is where the magic happens.
Now, here’s the kicker: find Network Mode. You might see something like Network Mode SIM 1 if you’re rocking a dual SIM setup. Choose LTE/4G or LTE/3G/2G (auto connect). It’s the ticket to ride the 4G train from there on out. And bingo—your phone should be humming along on 4G, saving battery and maybe giving you a better connection while it’s at it.
Heads up, though: these options might look a bit different depending on your carrier or whatever software version you’re running. If you hit a wall, a quick chat with your carrier’s support might do the trick.
Honestly, it’s not rocket science, but it’s worth knowing when the need arises. Happy surfing the 4G waves!
