How to Transfer Ps4 Data to Ps5 Without Ps4?
249 viewsGame Console
So, you’ve bagged yourself a shiny new PS5, but there’s a catch – your PS4 is nowhere to be found. Don’t sweat it! There are a few slick ways to transfer your PS4 data to the PS5 without the old console. Here’s the lowdown:
Firstly, why bother transferring your PS4 data?
  • Keeping Your Game Progress and Achievements: You’ve poured hours into your favorite PS4 games. Transferring data means you can pick up where you left off and flaunt your trophies on the new console without missing a beat.
  • Saving Time and Internet: Re-downloading all those games? Ain’t nobody got time for that. Transferring saves you the hassle and the bandwidth.
  • Better Performance: Games look and load better on the PS5. Bring over your PS4 data to enjoy enhanced gameplay.
Now, onto the methods:
1. Borrowing a Friend’s PS4
If you can borrow a friend’s PS4, this method is a lifesaver.
  • Log In and Set it as Your Primary: Sign into your PlayStation Network (PSN) account on your friend’s console and set it as your primary PS4. This lets you access your stored cloud data. Just a heads up, only one primary PS4 can be active at a time.
  • Network Transfer: Connect both consoles to the same network. On your PS5, head to “Settings” > “System” > “System Software” > “Data Transfer” > “Continue.” Pick the borrowed PS4 as the source and start the transfer. After it’s done, remember to log out and deactivate the PS4 as your primary.
2. USB Drive Method
Don’t have a PS4 handy? A USB drive can step in.
  • Backup on Original PS4: Insert a USB drive into your PS4, go to “Settings” > “Application Saved Data Management” > “Saved Data in System Storage” > “Copy to USB.” Select the game saves you want to move.
  • Transfer to PS5: Plug the USB into the PS5, navigate to “Settings” > “Saved Data and Game/App Settings” > “Saved Data (PS4)” > “USB Drive.” Choose “Copy to Console Storage” to move your saves. Note, some games might need extra steps or may not support USB transfer at all.
3. Third-Party Data Transfer Tools
Not the most straightforward, but it gets the job done.
  • Connect Your Storage: Hook up the backup USB drive or original PS4 storage (if you have it), and your PS5 storage to a computer.
  • Tool Installation: Download EaseUS Todo PCTrans Professional or a similar program.
  • Data Transfer: Open the tool, locate your PS4 data and set the source and target disks. Hit “Transfer” and let the magic happen.
4. PlayStation Plus Cloud Storage
If you’ve got PlayStation Plus, using cloud storage is a breeze.
  • Upload to Cloud: On your PS4, head to “Settings” > “Application Saved Data Management” > “Saved Data in System Storage” > “Upload to Online Storage.” Pick your game saves to upload. Note: You need a PlayStation Plus subscription.
  • Download on PS5: On the PS5, go to “Settings” > “Saved Data and Game/App Settings” > “Saved Data (PS4)” > “Cloud Storage.” Choose “Download to Console Storage” and select which saves to pull down.
There you go, folks. Hopefully, one of these methods will help you get your PS4 game data onto your PS5 without all the fuss. Happy gaming!
Transferring your PS4 data to a PS5 without having your old console lying around can seem a bit tricky, but don’t sweat it. If you’ve got a buddy who’ll lend you their PS4 for a hot minute, you’re golden. Or, if you were clever enough to have saved your data to the cloud ahead of time, you’re all set too. Let’s break it down.
So, first up, borrow your friend’s PS4. Make sure they’ve given you the nod and know what’s going down. Once you’re in, you need to log into your PlayStation Network account on their console; it’s gotta be your account so your saved goodies don’t get lost in the shuffle.
Here’s the kicker: you’ve got to make your friend’s PS4 your primary console. Head into Settings, then Account Management, and Activate as Your Primary PS4. Hit Activate so you can get all your purchased games and saved data moving.
Now, with your data ready to go, upload it to cloud storage if you’re rocking a PlayStation Plus subscription. Zip over to Settings again, then Application Saved Data Management. Click Saved Data in System Storage and Upload to Online Storage, then choose the saves you’re interested in keeping safe.
Don’t forget to log out and deactivate their PS4 from your account when you’re all done. Back to those settings again, hit Deactivate, and you’re off.
Now, let’s get those saves onto your PS5. Log into your PSN account and head over to Settings, Saved Data and Game/App Settings, then Saved Data (PS4) and finally, Cloud Storage. Pick the saves you’re dying to get back and download them to your console storage.
If you had the foresight to chuck your saves into online storage before the PS4 went MIA, things get simpler. Just log on to your PS5 with your account, mosey over to Settings, Saved Data and Game/App Settings, and you’re looking for Saved Data (PS4) and Cloud Storage. Pick and download, and you’re back in business.
But before you jump into action, here’s what matters: You’ll need a PlayStation Plus subscription to pull off the cloud trick. Not everything is moving seamlessly—double-check which games are backward-compatible on the PS5. And some game developers have quirks about how data gets transferred, so keep an eye out.
Basically, whether you’re borrowing gear or leveraging the cloud storage, moving your PS4 data to the PS5 isn’t too wild. Just takes a couple of steps and a little patience.
How to Get Your PS4 Data onto Your PS5 Even Without the PS4
So, your PS4 is out of commission, and you’ve got this shiny new PS5. But what about all your saved data and games? No worries—you can still transfer your data without having that PS4 around. Check out these methods for keeping your game progress alive.
1. Tap into PlayStation Plus Cloud Storage
If you were using PS+, chances are your game progress is chilling up in the cloud.
Here’s how to get it back:
  • Sign in to your PS5 with the same PSN account you used on your PS4.
  • Head to Settings > Saved Data and Game/App Settings > Saved Data (PS4) > Cloud Storage.
  • Grab those saved files and bring them down to your PS5.
Watch out for:
  • If your PS+ subscription was inactive during the upload or download stages, you might face some hiccups.
  • Only saves you uploaded before losing access to your PS4 can be retrieved.
2. Get it from an External Drive
Did you back up stuff on an external HDD or SSD? Perfect! You can plug it right into your PS5.
Here’s what you do:
  • Connect your external storage device to the PS5.
  • Navigate to Settings > Storage > External Storage.
  • If it asks to format the drive, make sure it was used with your PS4.
  • Install games or copy saves off the drive.
A couple of heads-ups:
  • It’s quicker to install games this way than to re-download them.
  • You’ll need to manually copy save files to the PS5’s internal storage via Settings > Saved Data > USB Drive.
3. Re-download from Your PSN Library
Your digital PS4 games are still tied to your PSN account, ready for a fresh download.
Here’s how:
  • Log into your PS5 with your PSN account.
  • Hop over to the Game Library (look for the icon on the home screen).
  • Go to Your Collection and select which PS4 games you want to download.
If you have those physical discs:
  • Pop the PS4 disc into the PS5 (make sure you have the disc version).
  • Your PS5 will install the game but will need the disc for verification whenever you play.
4. Sync Trophies and Account Data
Your trophies and profile details are automatically backed up via PSN.
Here’s what to do:
  • Check that your PS4 trophies synced up with PSN: On the PS4, go to Trophies > Options > Sync with PlayStation Network.
  • Log into your PS5 with the same account—your trophies and friend lists will show up.
5. Use a Buddy’s PS4
If you’ve got a friend who’s holding onto your PS4 data, you’re in luck:
  • Sign into your PSN account on their PS4.
  • Copy your saves to a USB drive or upload them to cloud storage.
  • Follow the steps from earlier to get your files onto your PS5.
Tackling Common Hang-ups
  • No Cloud Saves Found: If you didn’t enable backups to the cloud, tough luck—they’re stuck on the PS4. Enable Auto-Upload for next time.
  • Games Not Working on PS5: Most PS4 games should work, but double-check on Sony’s list for any outliers.
  • Region Headaches: For region-lock issues (like in China), you might need a local PSN account first before transferring data.
Keep Future Backups in Mind
  • Don’t forget to regularly back up saves to both cloud and external storage.
  • Update your PS4 software to dodge any unforeseen issues.
These tips should have you covered without needing your old PS4, focusing on cloud services, external drives, and PSN account tricks.
Trying to transfer your game data from a PS4 to a PS5 without the PS4 itself? Yeah, it can be a bit of a head-scratcher, but let’s see what tricks we’ve got up our sleeve to help out:
1. First off, cloud storage is your buddy if you were smart enough to have PlayStation Plus and backed up all your PS4 stuff there. This is how you roll with it:
  • Make sure your PS5 is cozy with the internet.
  • Use the same PlayStation Network account that you had on the PS4.
  • Head over to Settings, then Saved Data and Game/App Settings, and from there, navigate to Saved Data (PS4) > Cloud Storage.
  • Pick the game data you need and download it straight to your PS5, easy-peasy.
2. Got an external hard drive lying around with a PS4 backup? Then this is your move:
  • Hook up that external hard drive to the PS5.
  • Jump into Settings, find Storage, then move to Extended Storage.
  • Simply move your PS4 data to your PS5’s internal storage.
3. Here’s a twist: some games are fancy with cross-save or in-game account linking features:
  • Launch the game on your PS5 and log in with the good ol’ account from your PS4.
  • Stick to the game’s guidelines to move your data over or link your accounts like a pro.
4. If all else fails and you’re still stuck in a jam, your last hope might be calling up PlayStation Support for some specialist advice tailored just for you.
Hopefully, one of these methods will be just what you need to get back to gaming without missing a beat!
