How to Take a Screenshot on a Samsung Without Using the Power Button?
429 viewsPhone
Taking screenshots on a Samsung Galaxy device usually involves pressing the Power and Volume Down buttons at the same time. But what do you do if the Power button is busted or missing? Don’t worry, there are several nifty ways around this problem. Here are some alternative methods:
Using the Edge Panel
Ever heard of Samsung’s Edge Panel? It’s been around since 2014 and is a pretty slick way to access your favorite features, including taking screenshots. Just a heads-up, it isn’t available on all models or software versions.
Supported Models: Galaxy S6 and later, Note 7 and later, Galaxy Z Fold and Z Flip versions, and some Galaxy A series.
  • Go to “Settings” and then “Display.”
  • Scroll down and turn on “Edge Panel.”
  • You’ll notice a gray handle on the screen.
  • Swipe the handle from the side.
  • Tap the “Edit” button and look for “Screenshot.” Add it to your Edge Panel.
  • When you need a screenshot, just swipe to open the Edge Panel and tap “Screenshot.”
Using the Quick Settings Panel
The Quick Settings menu can also come in handy for taking screenshots, though you might need to add this option manually.
Supported Models: Devices running One UI 5.1 and above.
  • Swipe down from the top to open Quick Settings.
  • Swipe down again to expand the menu.
  • Swipe left and tap the “+” button.
  • Find and drag the “Take Screenshot” button to the panel.
  • Now, just tap the “Take Screenshot” toggle whenever you need it.
Using the Assistant Menu
The Assistant Menu lets you take screenshots without touching any physical buttons and it’s mainly designed for people with physical impairments.
Supported Models: Galaxy S10 and later, Note 10 and later, A50 and later, and Galaxy Tab S6 and later.
  • Go to “Settings” > “Accessibility.”
  • Tap “Interaction and Dexterity” and enable the “Assistant Menu.”
  • Open the content you want to capture and tap the floating Assistant Menu.
  • Tap the “Screenshot” button.
Palm Swipe to Capture
This is one of the coolest features. You can take a screenshot just by swiping your palm across the screen.
Supported Models: Galaxy S3 and later, Note 2 and later, A50, A70, and A80 series.
  • Head to “Advanced Features” > “Motions and Gestures” in Settings.
  • Turn on “Palm Swipe to Capture.”
  • To take a screenshot, simply swipe your palm across the screen.
Using Voice Commands
Bixby and Google Assistant can also help you capture screenshots. Just make sure your device is connected to Wi-Fi or a mobile network.
Supported Bixby Models: Galaxy S8 and later, Note series, A series, M series, Tab series, Z Flip, and Z Fold.
  • Open the screen you want to capture.
  • Say “Hey Bixby/Google, take a screenshot.”
  • The assistant will do the job for you.
Using the Game Booster
The Game Booster app is your friend when you’re in the middle of a game and need to take a quick screenshot.
Supported Models: Galaxy 10 and later, Note 10 and 20 series, Z Fold, Z Flip, and newer A and Tab series.
  • Go to “Settings” > “Apps.”
  • Look for “Samsung App Settings” to see if you have Game Booster. Tap it.
  • Under “Shortcuts,” select “Screenshot.”
  • When gaming, tap the floating or bottom-right “Screenshot” icon to capture the screen.
Using the S Pen
Got an S Pen? You’re in luck! You can use it to take screenshots, too.
Supported Models: Galaxy Note series, S20 Ultra, and other S Pen-compatible devices.
  • Pull out the S Pen and go to the screen you want to capture.
  • Tap the “Air Command” menu and select “Screen Write” to capture.
  • Edit if needed, then save or share your screenshot.
Using the “Take Screenshot” Shortcut in the Tasks Edge Panel
  • Swipe left on the Edge Panel handle and keep swiping to open the Tasks panel.
  • Tap the “Settings” icon at the bottom, swipe to select the “Tasks” panel, and tap “Edit.”
  • Add “Take Screenshot” to your shortcuts.
  • Navigate to the desired screen, swipe the Edge Panel handle, and select “Take Screenshot.”
Using Smart Capture
If you’re looking to capture long content, Smart Capture is a game-changer.
  • Open what you want to screenshot.
  • Press Power and Volume Down buttons for a second and let go.
  • Tap the Scroll Capture icon in the Smart Capture menu to continue capturing until you hit the bottom.
  • Add tags, edit, or share your screenshot as you see fit.
Taking a screenshot this way gives you more options to edit, tag, and share immediately. You can find all your screenshots in the Gallery app under the Screenshots folder or in the My Files app under Images.
So, whether your Power button’s kaput or you just want to try something different, these methods should have you covered!
If you’re looking to take a screenshot on your Samsung device and the power button just isn’t cooperating, don’t sweat it. There are plenty of ways to snap that shot without ever touching the power button. Trust me, it’s easier than you might think.
Quick Settings Hack
Ever tried poking around the Quick Settings panel? It’s like a treasure trove for shortcuts, including one for screenshots. Here’s the deal:
  • Step 1: Flick your finger down from the top of the screen to open the Quick Settings panel.
  • Step 2: Slide down again to see all the hidden goodies.
  • Step 3: Hunt down the “Take Screenshot” tile, and if it’s M.I.A, hit the “+” icon to add it.
  • Step 4: Tap that tile, and boom, you’ve got a screenshot!
This nifty trick works on devices running One UI 5.1 and beyond.
Palm Swipe Magic
Okay, here’s a fun one. Samsung phones from Galaxy S3 onward let you swipe your palm across the screen like some modern-day magician to grab that screenshot:
  • Step 1: Dive into “Settings” > “Advanced Features” > “Motions and Gestures.”
  • Step 2: Flip the switch to enable “Palm Swipe to Capture.”
  • Step 3: Brush the edge of your hand across the screen from left to right or the other way around. Screenshot caught!
Chatty Screenshot with Bixby or Google Assistant
Sometimes talking is just easier, especially when your hands are busy or you’re feeling lazy. Get Bixby or Google Assistant on the job:
  • Step 1: Make sure Bixby or Google Assistant is ready to roll.
  • Step 2: Get to the screen that needs capturing.
  • Step 3: Utter, “Hey Bixby” or “Ok Google,” and follow up with “take a screenshot.”
Heads-up: Your trusty assistant needs an internet connection for this one.
Edge Panel Shortcut
Got a Galaxy S6 or something newer? The Edge Panel might just have you covered:
  • Step 1: First, turn on the Edge Panels by heading to “Settings” > “Display” > “Edge Panel.”
  • Step 2: Get into the habit of swiping from the side to access it.
  • Step 3: Tap “Edit” and toss in the “Screenshot” option if it’s missing.
  • Step 4: Now, grab that screenshot whenever you need by swiping the panel open and tapping “Screenshot.”
Easy Access with Assistant Menu
Accessibility can really come in handy, and Samsung’s Assistant Menu is a lifesaver for some:
  • Step 1: Pop into “Settings” > “Accessibility.”
  • Step 2: Hit “Interaction and dexterity,” then switch on the “Assistant Menu.”
  • Step 3: A floating menu appears—give it a tap when the time’s right.
  • Step 4: Pick “Screenshots” from this handy menu.
Rolls out smoothly on Galaxy S10 and newer phones.
Bottom line: Samsung gives you options here, folks. Whether you’re a fan of the Quick Settings, gestures with a palm swipe, simple voice commands, slick Edge Panels, or the coherent Assistant Menu—there’s all sorts of ways to capture what you need without touching that stubborn power button.
Capturing a screenshot on your Samsung device without using the power button can be handy, especially if your power button’s acting up, or you just prefer a different approach. There are some neat tricks you can try, and here’s how:
Palm Swipe Gesture: This one’s a breeze, and most Samsung phones will have it. You just need to turn it on by heading to Settings, then Advanced Features, followed by Motions and Gestures, and flick on Palm Swipe to Capture. Once that’s done, open whatever you want a screenshot of and swipe your hand across the screen—bam! You’ll hear a shutter sound, and you’re good to go. The thing about this method is that it uses the phone’s motion sensor, which is pretty neat.
Bixby Voice Command: Sometimes, you might want to keep your hands free. Bixby, Samsung’s voice assistant, comes to the rescue. Just holler “Hi Bixby” or press the Bixby button if your phone’s got one, and say “Take a screenshot”. Bixby does the heavy lifting, but you’ll need to set it up first and hope it catches your voice right.
Edge Panel Shortcut: If multitasking is your game, then this method could be your best pal. Just switch on the Edge Panel in the Display settings. Swipe the Edge Panel handle from the side, hit “Tasks”, and then tap the “Screenshot” icon. It’s as easy as pie!
Assistive Menu: For anyone dealing with dodgy buttons, the Assistive Menu is a lifesaver. Switch it on in the Accessibility settings, and the floating menu replaces all those physical button functions. Tap the floating menu icon when you want to take a screenshot—it’s as simple as that!
Third-Party Apps: Apps like “Screenshot Touch” or “Screen Master” let you tailor how you catch those screen grabs, offering triggers like shaking the phone. All you gotta do is download one from the Play Store and follow their instructions. Just double-check those app permissions so nothing sneaky gets in.
S Pen (Note/Galaxy Ultra Series): For those with a stylus-happy Samsung, the S Pen comes in clutch with screenshot shortcuts too. Just flick out the S Pen and tap “Screen Write” from the Air Command, or press the S Pen button and select your snapshot area.
Scrolling/Long Screenshots: For those lengthy pages or articles, grab a standard screenshot using one of these methods, then tap on the floating thumbnail and hit “Capture More”.
Troubleshooting Tips: If you’re finding it tricky, double-check that the gesture’s turned on and clean your screen for better sensor accuracy. If Bixby or Edge Panel seems missing, a software update might be the fix.
Whatever your preference, there’s a method here that can keep you snapping screenshots like a pro, without that pesky power button. Whether it’s swiping your palm or using a snazzy app, Samsung’s got plenty of options to keep you in the game. Cheers to easy capturing!
Alright, let’s dive into some nifty ways to take screenshots on your Samsung phone without touching that power button. Samsung’s got some neat tricks up its sleeve, and here’s how you can make them work for you:
1. Palm Swipe Gesture:
This one’s cool and feels like a magic trick! Lots of Samsung phones have a gesture feature to capture screenshots.
Steps:
  • Go to Settings.
  • Check out Advanced Features, then hit Motions and Gestures.
  • Flip on Palm swipe to capture.
  • To snap a screenshot, just swipe the edge of your hand across the screen – left to right or right to left, whatever floats your boat.
2. Assistant Menu:
Think of the Assistant Menu as your on-screen sidekick, ready to handle tasks, including grabbing those screenshots.
Steps:
  • Mosey over to Settings.
  • Navigate to Accessibility.
  • Click on Interaction and Dexterity.
  • Turn on the Assistant Menu.
  • Find the Assistant Menu on your display and hit Screenshot.
3. Bixby Voice:
If your phone talks Bixby, you’re in luck. You can just say the word to capture your screen with ease.
Steps:
  • Wake up Bixby by pressing its dedicated button or saying “Hi Bixby”.
  • Drop this command: “Take a screenshot.” Bingo!
4. Quick Settings Panel:
Here’s a handy trick: you might sneak a screenshot button into the Quick Settings on some Samsung gadgets.
Steps:
  • Flick down from the top to open the Quick Settings.
  • If ‘Screenshot’ is MIA, tap Edit.
  • Drag Screenshot into your active lineup.
  • Tap the Screenshot button when you’re ready to capture the screen.
5. Third-Party Apps:
There are tons of apps out there just waiting to help you snap a screenshot without using the power button.
Check These Out:
  • Screenshot Easy
  • Super Screenshot
  • Assistive Touch for Android
Just pick your favorite app, follow what it says, and you’re all set to snap away.
There you have it! These tips offer all kinds of ways to take screenshots on your Samsung device without being glued to the power button, making life easier. Enjoy snapping pics of your screen in style!
