How to Take a Xbox One Controller Apart?
366 viewsGame Console
Okay, so you’ve got an Xbox One controller that’s acting up, or maybe you just want to customize it. Whatever your reason, let’s dive into how you can take it apart.
Why You Might Want to Disassemble Your Xbox One Controller
Despite being pretty solid, Xbox One controllers can glitch out, especially after a lot of use or if they’ve been dropped. Plus, some folks might want to tweak their controllers for a custom look or just do some routine cleaning.
Tools You’ll Need
  • T-8 Security Torx Screwdriver: You’ll need this particular bit because the Xbox screws are a bit special with a little hole at the tip.
  • Prying Tool: A thin plastic prying tool works best to avoid damaging the controller while popping off the covers.
  • Other Tools: Tweezers can be handy for grabbing tiny screws and springs. You’ll also want a clean, well-lit space to work in.
Steps to Take Apart Your Controller
  1. Get Ready: Make sure the controller is turned off and unplugged. Remove any batteries or battery packs.
  2. Pop Off the Grip Covers: Use your prying tool to gently lift the left and right grip covers off. Start at one end and work your way around. Repeat for both sides.
  3. Remove the Battery Cover: Pry open the cover on the back. If your controller hasn’t been opened before, you’ll find a sticker inside the battery compartment. Push through it with your Torx bit or cut it away to reach the hidden screw.
  4. Unscrew Everything: Use your T-8 Torx bit to take out the screws. Start with the hidden one in the battery compartment, then tackle the ones under each grip cover.
  5. Separate the Shells: Carefully pull apart the front and back shells. Be gentle with the ribbon cable connecting them.
  6. Get Inside: Now that it’s open, you’ll see the buttons, analog sticks, circuit board, vibration motors, and triggers.
Things to Watch Out For
  • Warranty: Keep in mind that taking apart your controller might void the warranty. Only dive in if you’re confident with small electronics.
  • Be Gentle: The inside parts are delicate. Try not to touch the electrical components to avoid static damage.
  • Organize Screws: Use a small container or a clean surface to keep your screws in order. Remember where each one goes for easy reassembly.
  • Work Clean: Do your disassembly in a clean space to avoid dust getting into your controller.
Common Fixes and Maintenance
  • Cleaning: Use compressed air or a soft brush to dust off the buttons, analog sticks, and other parts. This might help fix sluggish button response or stick drift.
  • Replacing Parts: If some parts are worn or damaged, like the analog sticks or buttons, swap them out for new ones. Just make sure they fit your controller model.
  • Fixing the D-pad: If the D-pad isn’t working well, carefully remove the spring steel D-pad ring with a prying tool or tweezers. Adjust its arms to apply more pressure, then put it back in place. If that doesn’t work, you might need a new D-pad ring.
Putting It All Back Together
To reassemble, just reverse the steps. Line up the shells, reconnect the ribbon cable, screw everything back together, and snap the covers on. Pop the batteries in and test the controller to make sure it’s all working. If something’s off, backtrack your steps and adjust as needed. If you’re still having trouble, it might be time to call in a pro.
Enjoy sprucing up your Xbox controller!
Alright, if you’ve ever been curious about getting inside your Xbox One controller, let’s break down the process so you can give it a shot. Whether you’re looking to clean up some gunk, fix a sticky button, or just take a peek under the hood, I’m here to walk you through it.
What You Need
  • T-8 Safety Torx Screwdriver: You’ll need this handy tool to deal with those pesky screws holding everything together.
  • Prying Tool: Something plastic, like a spudger, to gently nudge things apart without wrecking your controller.
  • Flathead Screwdriver (optional): If you can’t find a prying tool, this might come in handy.
Step-by-Step Playbook
1. Find a Spot
Make sure you’ve got a nice spread—room with good lighting, no interruptions. You’ll want space to keep track of tiny screws and whatnot.
2. Batteries First
Pop open the battery compartment and ditch those AA batteries. We don’t need any surprises with juice running through the controller!
3. Sticker Situation
If you’re breaking the seal for the first time, a warranty sticker’s lurking in the battery area, hiding a screw. Slice through or peel it away gently to uncover it.
4. Screw It
Grab your T-8 safety Torx and go to town on those screws at the back:
  • You’re hunting down five screws: one sneaky screw under the sticker and two each side, chilling below the grips.
Keep it steady when unscrewing, or you’ll end up with stripped screws—a real headache!
5. Grip it Off
Time to gently coax off those grip covers with your prying tool:
  • Slide your tool into the crack along one side of a grip cover and wiggle till it pops off.
  • Rinse and repeat for the other grip cover.
6. Faceplate Freedom
With grips gone, you can lovingly pry off the faceplate:
  • Give the edges a little tug until it’s unhitched from the clips.
7. Inside Job
Now, peek at the internals like buttons, sticks, and circuit boards:
  • If they’re screwed down more tightly, you might need a smaller Torx (like T-6) screwdriver.
8. Stick and Button Shuffle
Pull those thumbsticks right off their posts, no sweat:
  • Lift buttons out; they should pop out easily without any padding blockade.
9. Clean Up Time
Now you’ve got free rein to do some cleaning or swapping parts:
  • Blast away grime with compressed air or go for rubbing alcohol on a cotton swab for tougher spots.
10. Piece It Back
To put the jigsaw back together:
  1. Rearrange all bits in their rightful spots.
  2. Snap the faceplate back on.
  3. Lock both grip covers in til you hear that satisfying click.
  4. Do a screw replay to secure everything.
  5. Pop those batteries back in, and you’re ready to roll.
So, give it a try, and you’ll be all set to handle any controller mishaps or mods without turning it into a puzzle.
Alright, folks! If you’re looking to take apart your Xbox One controller, here’s a straightforward guide that’ll help you get the job done without breaking a sweat.
Essential Gear
  • TR8/Torx Security screwdriver: This little guy is crucial for those funky screws on the back.
  • Plastic pry tools/spudgers: These will help you pop things open without leaving ugly scratches.
  • Soldering iron (optional): Only if you’re ready to mess around with the internal wiring.
Let’s Get into It!
  1. Kick Off with the Battery & Side Panels
    • First, slide off that battery compartment cover.
    • Use a pry tool to gently pop the side grips away from the front shell.
  2. Undo Those Back Panel Screws
    • Find the 5 TR9 screws hiding out back.
    • Unscrew them with your TR8 driver, but go slow to keep from stripping them.
  3. Split the Housing Apart
    • Carefully pry the front and back shells apart – start near the headphone jack.
    • Here’s the kicker: Gently lift the ribbon cable connector to disconnect the PCB.
  4. Digging into the Motherboard
    • Remove the 2 T6 Torx screws that hold down the motherboard.
    • If you’re swapping out analog sticks or triggers, you’ll need to desolder some wires.
Common Hiccups & How to Tackle Them
  • Stripped Screws: Get a rubber band action going between the screw and driver for extra grip.
  • Ribbon Cable Drama: Lift its latch straight up before trying to yank it out.
  • Buttons Acting Up: Clean those contact points with some isopropyl alcohol and a cotton swab.
Important Heads-Ups
  • Warranty Killer: Once you crack open that controller, kiss the Microsoft warranty goodbye.
  • Static Shock Warning: Ground yourself to avoid zapping your electronic bits.
  • Pro Tip for Reassembly: Check if buttons are working before screwing everything back together.
Post-Teardown Tips
  • Fix for Stick Drift: Clean those potentiometers with some electronic contact cleaner.
  • Fine-Tune the Triggers: Adjust those tension springs if they need a little extra kick.
If you’re into visual aids, check out iFixit’s teardown of the Xbox One Elite Controller. Trust me, staying safe from static and using the right tools can save you from a repair disaster.
Alright, if you’re looking to take apart your Xbox One controller, here’s how you do it without losing your marbles:
Stuff You’ll Need:
  • T8 Security Torx Screwdriver
  • Plastic Pry Tools or a Flathead Screwdriver
  • A clean, bright spot to work
Let’s Get Into It:
1. Ditch the Battery Cover:
First things first, slide off the battery cover on the back and pop out those batteries.
2. Go After the Rear Screws:
Grab the T8 Security Torx Screwdriver and get to work on those five screws in the back. Here’s where they hide:
  • A couple under the battery cover
  • One tucked away under the sticker in the battery bay (go easy while peeling it back)
  • Two sneaky ones under the side panels
3. Pry Off the Side Panels:
Take your plastic pry tools and ease off those side grips. Stick the tool in the seam and gently work your way around until the grips give in.
4. Pull Apart the Shells:
With all screws out and side panels off, just pull the front and back shells apart. They should come loose without much trouble now.
5. Lift Out the Inside Bits:
Carefully lift the circuit board out—keep an eye on those wires. Remove the analog sticks, the D-pad, and whatever else you need to get at or replace.
6. Spruce Up or Fix:
Time to clean up! Use a brush or canned air to get rid of any dust or grime.
7. Put It All Back Together:
Now play it all in reverse! Make sure everything’s snug before you start screwing the controller back into one piece. Snap those side panels back on, screw it all in, pop the batteries back, and secure the battery cover.
With these steps, you’ll have your Xbox One controller apart, cleaned, and fixed up in no time. Keep a steady hand to avoid any oopsies!
