How Do You Take a Scrolling Screenshot on iPhone?
160 viewsPhone
Ever tried grabbing a scrolling screenshot on your iPhone but weren\’t sure how to do it? Well, here\’s the lowdown on making it happen.
First things first, you need to take a regular screenshot. If you’re rocking a newer iPhone, hit the side button and volume up button together. Got an older device? You might need to use the home button and the side or top button instead.
Once that\’s out of the way, the magic happens when the preview pops up in the bottom left corner. Tap it quick before it fades away—it’s like catching a butterfly! This will whisk you away to the editor screen.
Here’s where it gets interesting: if you see a “Full Page” option at the top right, bingo! This means your content scrolls beyond the screen, like lengthy web pages or detailed PDFs. Not seeing it? Well, some apps are party poopers and just won’t support the full-page capture.
If “Full Page” is your jam, picking it will show the entire scrolling capture. You can even crop it to get just what you need. Once everything’s picture-perfect, you can hit “Done” to save it as a PDF, or use the share option and send it wherever you please.
For those tricky apps that don\’t let you scroll capture natively, apps like Picsew can be real lifesavers, letting you stitch multiple screenshots together. Remember, some iPhone models have quirks—like the iPhone 12 where scrolling screenshots might not work everywhere. In those cases, a trusty screen recording or one of those cool third-party apps can pinch hit.
So there you go! With these steps, you’re all set to chronicle long content like a pro on your iPhone.
If you’re looking to grab a scrolling screenshot on an iPhone, here’s how to do it:
  • First things first, make sure your iPhone is running iOS 13 or later. This feature didn’t exist before that, so it’s crucial to have the right software.
  • Open up whatever app or webpage you’re eyeing. This usually works best in Safari or apps that play nice with Apple’s screenshot magic.
  • Ready? Take a screenshot by pressing the Side Button and the Volume Up Button at the same time if you’re on an iPhone X or newer. For those sporting older models with a trusty Home button, press the Home Button and Power/Side Button simultaneously.
  • Quick, tap the thumbnail that pops up in the corner before it vanishes!
  • Here’s the kicker: in the edit screen, you’ll see “Screen” and “Full Page” at the top. Go for “Full Page” if you’re set on snagging the whole shebang.
  • Wrap it up by hitting “Done” and saving as a PDF to Files. Bam, your scrolling screenshot is all set!
This little trick is perfect for scooping up entire web pages or apps that support this nifty feature. Keep in mind, though, that it won’t always work in third-party apps that aren’t on board with Apple’s full-page screenshot game.
So you\’ve got an iPhone and you want to take a scrolling screenshot, huh? Maybe it’s to help with keeping that long chat thread or snagging some juicy article you found online. Well, the iPhone doesn’t make this easy-peasy like a few Android phones, but I\’ve got some tricks up my sleeve that can help you get there.
1. Here\’s the Deal with iPhone Scrolling Screenshots
You hear \”scrolling screenshot\” or \”long screenshot,\” and think it\’s pure magic, right? It basically squashes together a bunch of screen grabs into one long snapshot. On iPhones, you can sort of do this with the Safari browser\’s \”Full Page\” option, but for anything else, you’ll need an extra app.
2. Doing It the Apple Way (In Safari)
Good ol’ Safari has a built-in way to capture long webpages. Try this:
  1. Snap a usual screenshot—hit the Side and Volume Up buttons.
  2. \n
  3. See that little preview at the corner? Tap it before it disappears.
  4. \n
  5. At the top, you’ll find the Full Page tab. Click it.
  6. \n
  7. Slide the handles to capture just what you need.
  8. \n
  9. Hit Done and then Save PDF to Files.
  10. \n
But there’s a catch: it’s only available on Safari and a few nifty apps. Plus, it saves as a PDF, not a photo. Bummer, right?
3. Need More Freedom? Go Third-Party
For stuff beyond the web, try apps like Picsew, Tailor, or Snagit. They\’re lifesavers when you’re dealing with chat apps or other wonky places.
Picsew Walkthrough:
  • Take screenshots as you scroll.
  • Fire up Picsew, choose Stitching.
  • Pick your shots and line them up.
  • Save them as an image format you like.
Screen Recording Method (iOS 14+):
  • Enable this feature in your Control Center.
  • Record, scroll through whatever’s interesting, and stop.
  • Use an app like Snagit to stitch it into an image.
4. Troubleshooting? No Sweat!
If the Full Page option is hiding:
  • Make sure you\’re using Safari. Older iOS? Time to update!
Blurry stitch? Misaligned shots?
  • Stick to about a 20% overlap when snapping screenshots manually or go for apps that offer auto-stitching.
Facing app hurdles?
  • Go to Settings and let that screen recording shine in Control Center.
5. Why Apple Keeps It Strict
Apple’s all about user privacy and keeping things neat, which sometimes means limiting system-wide screen grabbing. This approach has its perks – it’s safe! – but makes things complicated for long screenshots.
6. Pro Tips from Yours Truly
  • If you\’re on social media or just chit-chatting, give Snagit’s auto-scroll a whirl to keep things smooth.
  • When dealing with PDFs? Mark them up right in Safari—add notes or crop away!
In the end, you can totally conquer long screenshots on your iPhone if you juggle Safari and a few handy apps. It’s not too shabby, even if it seems a bit fragmented at first glance!
