How Can I Stop My Toshiba Laptop Screen from Sleeping When I Close the Lid?
339 viewsLaptops
Toshiba laptops usually go to sleep when you close the lid, which isn’t always ideal, especially if you’re using an external monitor or running background tasks. Here are some handy tips to stop your screen from sleeping when you shut the laptop lid:
Using the Control Panel
  • Open the Control Panel by searching for it in the Start menu.
  • Go to ‘Hardware and Sound’ > ‘Power Options.’
  • Click on ‘Choose what closing the lid does’ on the sidebar.
  • For ‘When I close the lid,’ select ‘Do Nothing’ for both ‘On battery’ and ‘Plugged in.’
  • Hit ‘Save Changes.’
Using the Settings App
  • Press Windows key + I to open Settings, or right-click the Start button and select ‘Settings.’
  • Head to ‘System’ > ‘Power & Battery.’
  • Under ‘Screen and sleep,’ set both ‘On battery’ and ‘Plugged in’ options to ‘Never.’
Modifying Power Plan Settings
  • Open Control Panel and go to ‘Power Options.’
  • Click ‘Change plan settings’ for your current power plan.
  • Set ‘Put the computer to sleep’ to ‘Never’ for both ‘On battery’ and ‘Plugged in.’
  • Click ‘Save changes.’
Using Command Prompt
  • Press Win + R, type ‘cmd’, and press Enter.
  • Type: powercfg -change -monitor-timeout-ac 0 for plugged in.
  • And: powercfg -change -monitor-timeout-dc 0 for battery.
Adjusting Advanced Power Settings
  • Click ‘Change plan settings’ for your current plan.
  • Go to ‘Change advanced power settings.’
  • Under ‘Power buttons and lid,’ set ‘Lid close action’ to ‘Do Nothing’ for both ‘On battery’ and ‘Plugged in.’
  • Under ‘Display’, set ‘Turn off display after’ to ‘Never.’
  • Apply and OK to save changes.
Using Third-Party Software
  • PowerToys: Download it from Microsoft’s GitHub. Open the Awake tab, toggle the switch to enable, and set the behavior to ‘Stay awake until expiration.’
  • Don’t Sleep: A free tool that prevents sleep mode. Download, install, and choose whether to keep the laptop awake indefinitely or for a specific period.
Some Tips and Considerations
  • Battery Life: Keeping your screen on while on battery power will drain it faster. It’s best to keep the laptop plugged in if possible.
  • Overheating: The laptop might overheat if run with the lid closed for too long. Make sure it has good ventilation or use a cooling pad.
  • Reverting Settings: If you don’t need the screen on anymore, just revert the changes to their default settings.
  • Compatibility: Most modern Toshiba laptops will support these settings, but older models might be limited.
By tweaking these settings, you can keep your Toshiba laptop from sleeping when you close the lid. This will allow you to continue using an external monitor or run background tasks without interruptions.
Alright, so if you’re tired of your Toshiba laptop screen taking a nap every time you shut the lid, here’s the scoop on how to fix that. It’s all about tweaking those power settings in Windows. Let’s dive in and get those adjustments done.
First things first, you want to head to the power options. Look down at your screen’s bottom right corner for that sneaky little battery icon. Can’t spot it? Sometimes you’ve got to click a tiny arrow to reveal all the hidden gems in the System Tray. Give the battery icon a right-click and say hello to “Power Options” from the menu that pops up.
Now onto switching up the lid closing behavior. In the Power Options window, there’s a nifty little link chilling on the left that asks, “Choose what closing the lid does.” Give it a click. Here, you’ll find options that let you decide what happens “When I close the lid.” You typically have two scenarios to play with:
  • For “On battery,” just choose “Do nothing” from the dropdown.
  • For “Plugged in,” you might want to set it to “Do nothing” as well, if you’re keen on keeping your laptop awake no matter how it’s powered.
Don’t forget to save those changes when you’re done fiddling. Scroll your way down and hit “Save changes” to lock in these settings.
Here’s the kicker: be careful about leaving your laptop awake with the lid shut, especially when it’s running on battery. No one wants to deal with a scorching laptop in an enclosed space—it could end in tears, or worse, overheating damage. If you’re using an external monitor, make sure all your gear, like your keyboard and mouse, is connected so you can roll without cracking open your laptop.
There you have it! By following these steps, your Toshiba can stay wide awake, even with its lid closed. Pretty handy, right?
Keep Your Toshiba Laptop Awake When Closing the Lid
If you’re looking to keep your Toshiba laptop buzzing away while its lid is shut, say for a big download, binge-watching a series, or just keeping the system accessible when you’re on the go, here’s how to do it:
A Little Tweak in Power Settings
Ever noticed how your laptop seems to nod off as soon as the lid shuts? That’s all thanks to its default settings, but we’ve got a quick fix:
  • Pop open the Control Panel, navigate to Hardware and Sound, and click on Power Options.
  • Find Choose what closing the lid does on the menu to the left and go for it.
  • Under When I close the lid, choose Do nothing for both On battery and Plugged in.
  • Don’t forget to hit Save changes!
Take Care of Hibernation
Hibernation could be sneaking in and putting your laptop to sleep when you least expect it. To put a stop to this ninja move:
  • Open up the Command Prompt (Admin).
  • Type in:
  • powercfg -h off
  • And voilà, hibernation is off the table, keeping the laptop from dozing off when closed.
Kick the Screen Saver
Screen savers and display timeouts can put a kink in your plans, making things sleep when you don’t want them to. Here’s how you can sort that out:
  • Head into Settings, tap Personalization, then Lock Screen, and finally Screen Saver Settings.
  • Set the Screen Saver to None and untick On resume, display logon screen.
  • While you’re at it, in Power Options, make the display stay on longer—or indefinitely!
Hardware and Driver Check
If those pesky sensors or drivers are playing tricks, here’s what you do:
  • Update those Power Management drivers via Device Manager (under System devices).
  • Test the lid sensor: Close it and see if the screen fires up again when you open it. If not, might be time to recalibrate or swap the sensor out.
Get Fancy with Third-Party Tools
For those wanting more control, check out:
  • Apps like Insomnia or Caffeine let you hold sleep at bay, especially handy when you’re downloading the latest season of a show.
  • Customize these apps to keep things lively during specific tasks.
Heads-Up Tips
  • Watch for heat: Running the laptop without sleep might fry it up a bit. A cooling pad could be just what the doctor ordered.
  • Don’t drain the juice: Set Do nothing only when you’re plugged in to keep the battery intact.
  • Live test: Close that lid and see if your tunes keep playing or downloads don’t skip a beat. You want to make sure everything’s set.
Tweak those settings and you’ll have your Toshiba laptop happily working in the background, perfect for keeping up with your day-to-day.
Looking to keep your Toshiba laptop screen from nodding off when the lid is closed? You’ve come to the right place. Here’s how you can sort that out for both Windows and Ubuntu users, without all the technical mumbo jumbo.
For you folks with Windows, here’s the lowdown:
First off, dive into Power Options. You can find this by clicking on the Start menu and hitting up the Control Panel. Once you’re there, mosey on over to System and Security, and then click Power Options. Easy as pie.
From there, you want to tweak what happens when your lid drops. On the left-hand menu, you’ll see the option to ‘Choose what closing the lid does.’ Set it to ‘Do nothing’ for both battery and plugged in scenarios. Make sure to save those changes.
If these basic tweaks don’t do the trick, there’s a deeper dive you can do. Click on Change plan settings next to your chosen power plan, then click on Change advanced power settings. You’ll want to fiddle around with the ‘Power buttons and lid’ section, setting ‘Lid close action’ to ‘Do nothing’ for both battery and plugged-in modes. Hit OK, and you’re sorted.
Now, if you’re running Ubuntu, things are slightly different. Pop open a terminal window and type in sudo nano /etc/systemd/logind.conf. You’re looking to change that line #HandleLidSwitch=suspend to HandleLidSwitch=ignore. Save with CTRL + O and exit with CTRL + X. Wrap things up by restarting systemd-logind with sudo systemctl restart systemd-logind.
If you’re feeling fancy, you can always throw a third-party program into the mix, like ‘Don’t Sleep’ for Windows. Just another option if all else fails!
These steps should do the trick to keep your Toshiba laptop screen alive when the lid’s down. If you’re scratching your head over any of it, checking out your laptop manual or reaching out to Toshiba support wouldn’t go amiss.
