How Can I Stop My Samsung from Downloading Games Automatically?
682 viewsPhone
Samsung devices are generally user-friendly, but some users have reported that their phones download games automatically. This can be frustrating, especially if the downloaded games are unwanted or consume significant storage space. So, what’s going on and how do you stop it?
Why Your Samsung Phone Downloads Games Automatically
  • Automatic Updates: This is a big one. If you’ve got automatic updates turned on in the Google Play Store, your phone might be grabbing updates for games without you noticing. Some games even download extra stuff during these updates.
  • Pre-Installed Apps: Samsung devices come with a bunch of apps pre-loaded, like the Galaxy Store or Game Launcher, which might have settings that allow automatic downloads. The Galaxy Store, for example, might push recommended games to your phone.
  • Malware or Adware: If your phone’s got some nasty malware or adware lurking around, it might be causing those unwanted downloads. These malicious programs can exploit vulnerabilities to sneak games onto your device.
  • Third-Party Apps: Sometimes, apps you’ve installed might have permissions to download other content. If you’ve recently put any sketchy apps on your phone, they could be the reason behind these surprise installations.
  • Carrier-Related Issues: Your network carrier might also be involved. Some carriers have apps or services that push games onto your phone, like Verizon’s App Manager.
Stopping Samsung Phones from Downloading Games Automatically
  • Turn Off Automatic Updates in Google Play Store:
    • Open the Google Play Store app.
    • Tap the three horizontal lines in the top-left corner to open the menu.
    • Go to “Settings.”
    • Tap “Auto-update apps,” and select “Don’t auto-update apps” or “Auto-update apps over Wi-Fi only.”
  • Change Galaxy Store Settings:
    • Open the Galaxy Store app, tap the menu (three lines), and go to “Settings” (gear icon).
    • Tap “Auto update apps” and select “Never.”
    • Toggle off “Get news and special offers.”
    • Check “About Galaxy Store” for other updates settings and adjust accordingly.
  • Limit Permissions for Galaxy Store and Game Launcher:
    • Go to “Settings” > “Apps,” and find “Galaxy Store” or “Game Launcher.”
    • Tap “Permissions” and disable permissions like “Allow background data usage” and “Install unknown apps.”
  • Disable Game Launcher:
    • Find the Game Launcher app, long-press its icon, select “App info,” and hit “Disable.”
  • Control App Recommendations in Galaxy Store:
    • When you first open the Galaxy Store, you might see a recommendation page. Unselect any pre-checked apps and skip the “Customize Profile” page if it pops up.
  • Hunt Down Suspicious Apps:
    • Open “Settings” and go to “Apps” or “Applications.”
    • Look through the list for any apps you don’t recognize and uninstall them.
  • Install Antivirus Software: Get apps like Avast, AVG, or Norton from the Google Play Store to scan and remove any malware or adware.
  • Disable In-App Ads:
    • Open the app with ads, and find the settings to disable in-app ads or opt out of personalized ads.
  • Clear Cache and Data:
    • Go to “Settings” > “Apps,” select an app, tap “Storage,” and hit “Clear cache” or “Clear data.”
  • Turn Off App Cloud:
    • In “Settings” > “Apps,” find “App Cloud” and disable it if it exists.
  • Factory Reset: If all else fails, do a factory reset. Back up your data first. Go to “Settings” > “General management” > “Reset” > “Factory data reset” and follow through with the instructions. This will completely wipe your phone.
Final Thoughts
So, there you have it! These steps should help you get a handle on those automatic game downloads on your Samsung phone. Whether it’s tweaking your settings or uninstalling suspicious apps, you can regain control and keep your storage space for things you actually want.
You know that frustration when your Samsung starts downloading games you don’t want? It’s like, “Who asked you to do that?” Well, there’s a way to put a stop to it. It’s usually because of Galaxy Store settings or even carrier settings pulling in unwanted apps. Let’s crack on with how to sort this out.
Step 1: Stop Automatic Downloads in Google Play Store
First off, let’s deal with Google Play Store.
  • Pop open the Google Play Store on your device.
  • See your profile icon on the top right? Tap it.
  • Head over to Settings.
  • Navigate to Network Preferences.
  • Now, choose App download preference and set it to Ask me every time.
  • Also, hit Auto-update apps and switch it to Don’t auto-update apps.
That should help keep the Play Store from jumping the gun on downloads.
Step 2: Manage Galaxy Store Settings
Now, the Galaxy Store can be a bit cheeky too:
  • Open the Galaxy Store app.
  • Hit the hamburger menu (those three lines) on the top left.
  • Go into Settings (with the gear icon).
  • Find Auto update apps and set it to Never.
  • Turn off Get news and special offers. Those can sometimes lead to junk downloads.
Step 3: Strip Galaxy Store Permissions
Dialing back on permissions can reduce unwanted downloads:
  • Go to your device’s Settings.
  • Tap Apps and hunt down Galaxy Store.
  • Tap on Permissions and cut back on any that aren’t needed, especially for storage and background data.
Step 4: Deal with Carrier-Installed Apps
The carrier could be up to something, slipping in games via specific apps:
  • In the Settings Menu under Apps, look for any carrier-specific apps (like Verizon App Manager).
  • If you spot them, think about disabling or uninstalling these if they don’t serve a purpose.
Step 5: Give Your Device a Malware Check
If it feels like malware’s involved:
  • Grab a solid antivirus app from the Google Play Store to scour your device for any nasties.
  • Follow the app’s lead to zap anything it finds.
Step 6: Switch Off Automatic Restore
Just switched phones or reset yours? Turn off automatic restore:
  • Open Settings, go to System settings.
  • Tap Backup & reset and flick off automatic restore.
There you go! By going through these steps, you should stop those pesky game downloads from taking over your Samsung. Good luck!
Hey there! If you’re fed up with your Samsung device sneaking in unwanted game downloads, you’re not alone. Here’s the lowdown on how to kick those automatic game downloads to the curb.
First Things First: What’s Going On?
Now, you might be scratching your head wondering why your phone is busy downloading games without your say-so. Here’s the scoop: It could be your device coming pre-packed with apps that update on their own, settings from third-party stores, pesky malware, or even a slip of the finger on your part. These downloads don’t just gobble up storage, they suck your data down like nobody’s business! So, let’s dive into how you can stop this madness.
Give Those Pre-installed Game Apps the Boot
Samsung tends to pile on games straight out the gate, and they could be set to auto-update, which is a real nuisance.
Here’s how you reign them in:
  • Head to Settings > Apps. Then, search for those sneaky pre-installed games like “Samsung Games” or whatever they’ve thrown in there.
  • Hit Disable—or Uninstall if you’re feeling brave and it’s possible.
  • If you have to keep it, restrict its background antics: Drag yourself to the app’s info page and turn off Mobile data > Disable “Allow background data usage”.
Tweak Those Google Play Store Settings
The Play Store might be overzealous with its auto-update feature and downloading games without asking your permission.
Knock these auto-downloads off their perch:
  • Open up Google Play Store > Profile icon > Settings.
  • Pop over to Network Preferences > Auto-update apps.
  • Choose Don’t auto-update apps or pick Auto-update over Wi-Fi only.
  • Don’t forget to disable Enable auto-install for those suggested apps and games.
Sweep Away Malware or Adware
Nasty malware can cozy up disguised as games and fire off downloads or ads without batting an eyelid.
Banish these troublemakers:
  • Start by booting up your phone in Safe Mode: Hold the power button till you see Power off, then long-press it and select Reboot to Safe Mode.
  • In Safe Mode, hunt down and uninstall suspicious apps via Settings > Apps > [App name] > Uninstall.
  • Use Samsung’s Notistar or NiceCatch—they’re there to help pinpoint ad sources.
  • If all else fails, a factory reset might just do the trick (but make sure you’ve backed up your data first: Settings > Accounts and Backup > Backup Data).
Hold the Samsung App Store in Check
Permissions might be off and the Samsung Galaxy Store could be merrily downloading games.
Stop it in its tracks:
  • Pull up Galaxy Store > Menu > Settings and turn off Auto-update apps and Push notifications.
  • Cancel out unnecessary permissions: Settings > Apps > Galaxy Store > Permissions > Disable “Storage” or “Install unknown apps”.
Lock Down Accidental Downloads with Parental Controls
Maybe the little ones got their fingers on your screen, or you slipped and downloaded something by mistake.
Tighten the reins with parental controls:
  • Get yourself Google Family Link, set up restrictions for app downloads on both your phone and the kiddo’s.
  • With Samsung’s Game Launcher, flip the switch for Child mode: Go to Game Launcher > Settings and activate Parental Controls with a PIN.
Tips to Keep Your Device Squeaky Clean
  • Clear out app caches to nix leftover files from old games—do this by navigating to Settings > Storage > Clean Now.
  • Keep third-party app stores at arm’s length to dodge malware—you know the ones, like those APK sites.
  • Do a sweep of installed apps and permissions regularly via Settings > Apps > [App name].
Well, there you have it! Tackling these sneaky game downloads is quite a feat, but with these pointers, you can smooth out your phone’s performance and reclaim your storage space. Happy decluttering!
Alright, if you’re tired of your Samsung phone sneakily downloading games, let’s dive into how you can put a stop to it. Here’s what you can do:
First up, try disabling those pesky auto-updates in the Google Play Store:
  • Fire up the Google Play Store.
  • Give your Profile Picture a little tap in the top corner.
  • Go for Settings.
  • Hit Network preferences.
  • Tap on Auto-update apps.
  • Choose Don’t auto-update apps.
Easy-peasy, right? Now, let’s make sure unwanted apps aren’t trying to crash the party:
  • Head to Settings.
  • Tap on Apps.
  • Hit the 3 dots in the top right and select Special access.
  • Look at Install unknown apps.
  • Double-check nobody shady has install permissions.
Next, let’s deal with that Samsung Game Launcher:
  • Pop open Settings.
  • Navigate to Advanced features.
  • Hunt down Game Launcher.
  • Turn it off.
Feeling suspicious about that random game? Here’s how to clear it out:
  • Back to Settings we go.
  • Tap on Apps.
  • Give those apps a good scroll and find anything weird.
  • Tap Uninstall on the culprits.
Finally, keep things clean by scanning for malware:
  • Jump into Settings.
  • Find Device care.
  • Tap Security.
  • Run a scan to make sure nothing harmful is lurking.
By keeping an eye on your app permissions and doing regular malware scans, you can keep your phone safe and running smoothly. It’s all about staying ahead of those sneaky downloads!
