Why Does My PS5 Turn On with the TV and How Can I Stop It?
489 viewsGame Console
If your PS5 keeps powering up whenever you turn on your TV, it can be really frustrating, especially if you like having control over your gadgets. This problem usually boils down to the HDMI-CEC (Consumer Electronics Control) feature, which lets your TV and PS5 communicate with each other. Let’s dive into how you can put a stop to this.
Why Does the PS5 Turn On With the TV?
This is all about the HDMI Device Link on the PS5. It’s a feature that lets your console and TV talk via HDMI-CEC, causing one to power up the other. Here’s why it might be happening:
  • HDMI-CEC on the TV: Your TV might have HDMI-CEC enabled, sending signals to your PS5 to turn it on or off.
  • Remote Play: If your PS5’s remote play is enabled, it could trigger the console to turn on when your TV powers up.
  • Rest Mode Settings: If your PS5 stays connected to the internet in rest mode, it might wake up when the TV powers on.
How to Stop PS5 from Turning On With TV
Method 1: Disable HDMI Device Link on PS5
  1. Power up your PS5 and go to the home screen.
  2. Hit the gear icon (Settings) in the top-right corner.
  3. Navigate to “System” and then select “HDMI.”
  4. Find the “Enable HDMI Device Link” option and switch it off.
  5. Turn off your TV and then turn it back on to see if the issue is fixed.
Method 2: Disable HDMI-CEC on Your TV
Disabling HDMI-CEC depends on your TV’s brand:
  • Samsung TVs: Go to Settings > General > External Device Manager > Anynet+ (HDMI-CEC) and turn it off.
  • LG TVs: Head to Settings > All Settings > General > Simplink (HDMI-CEC) and disable it.
  • Sony TVs: Access Settings > Watching TV > HDMI Settings > HDMI Control and switch it off.
  • Vizio TVs: Go to Settings > System > CEC and disable CEC.
Method 3: Turn Off Remote Play
  1. Open the Settings menu on your PS5.
  2. Select “System” and then choose “Remote Play.”
  3. Turn off the “Enable Remote Play” option.
  4. Turn off your TV and then power it back up to check if your PS5 still activates.
Method 4: Adjust Rest Mode Settings
  1. Go to Settings on your PS5.
  2. Navigate to “Power Settings” and click on “Features Available in Rest Mode.”
  3. Turn off the “Stay Connected to the Internet” option.
  4. Also, disable the “Enable Turning on PS5 from Network” option.
  5. Power down your PS5 to see if the glitch is gone.
Additional Tips
  • Check for Firmware Updates: Make sure both your PS5 and TV have their latest firmware updates. These updates can occasionally fix compatibility hitches.
  • Use Quality HDMI Cables: Cheap cables can mess with connectivity. Opt for certified HDMI cables for the best performance.
  • Test Different HDMI Ports: Give another HDMI port on your TV a try to see if it solves the problem.
  • Contact PlayStation Support: If nothing else works, getting in touch with PlayStation Support might be your best bet.
By following these steps, you should be able to stop your PS5 from automatically turning on every time you power up your TV. This can definitely give you more control over when and how you want to game.
Alright, so you’ve got your PS5 turning on every time your TV does, and it’s driving you up the wall. No worries, there’s a way to fix that. It’s all about HDMI-CEC, which is a fancy feature that lets your TV boss around other gadgets hooked up through HDMI, like your PS5. Let’s break down how to turn this thing off.
First off, don’t let HDMI-CEC’s big name intimidate you. It’s just a thing that makes every connected device play nice with each other, using the same remote. Meaning, flip on your TV and your PS5 acts like it’s been pulled onto stage, whether you wanted it or not.
Here’s where you come in—let’s shut down that impulsive behavior. Kick off by powering up your PS5. Once you’re in, head over to the settings—it’s the gear icon in the top right corner of the screen. Scroll on down till you hit “System,” and then following the trail to “HDMI.” When you’re in the HDMI section, look for “Enable HDMI Device Link” and turn that thing off. Now your PS5 can chill while your TV does its thing.
If you’ve got a particular setup where you’d like some interaction but not the full dance number, there are a couple of tweaks you can make:
  • “Enable One-Touch Play” makes sure the TV turns on when you fire up the PS5.
  • “Enable Power Off Link” lands your PS5 in Rest Mode when you shut down the TV.
You can shut down one or both, whatever suits you best.
Now, if shutting down the feature on your PS5 didn’t round the bases for you, dive into your TV’s settings. Each TV’s a little different—they might call it Anynet+, SimpLink, or other techy-sounding names—but it’s all the same HDMI-CEC stuff. Grab your remote, pop open the settings, track down the CEC features, and put them out of commission.
After all this, your PS5 should stay put without hopping to life every time you press the power button on your TV remote. There you have it—crisis averted!
If your PS5 keeps turning on every time your TV does, there are a few things you can try to stop this from happening. Here’s how you do it:
What’s Happening with HDMI-CEC?
Alright, so there’s this thing called HDMI-CEC (Consumer Electronics Control). It lets your TV and connected gadgets talk to each other through HDMI. Handy, right? But it can also make your PS5 power on or off whenever your TV does. That’s probably what’s messing things up.
Fixing the Problem – One Step at a Time
Step 1: Tweak the HDMI-CEC (Device Link) Setting
  • What’s Going On? Your PS5 syncs its power mode with the TV through something called HDMI Device Link.
  • What to Do:
    • Hop over to Settings > System > HDMI on your PS5.
    • Flip off Enable HDMI Device Link.
    • If you’re still stuck afterward, unplug both your TV and PS5 for about a half-minute. Let them reset their handshake!
Step 2: Check Rest Mode Activity
  • The Issue: Your PS5 can randomly wake up from its nap mode if it’s doing background updates or tasks.
  • Solution:
    • Take updates off autopilot:
      • Slide over to Settings > Saved Data and Game/App Settings > Automatic Updates.
      • Kick Auto-Download and Auto-Install in Rest Mode to the curb.
    • Go for a full shutdown instead of using rest mode.
Step 3: Your Connected Devices Might Have a Hand in This
  • What’s Going On? Connected stuff like media remotes or HDMI gadgets could be sending the PS5 signals it doesn’t need.
  • Solution:
    • Unplug any HDMI devices you don’t absolutely need.
    • Try running just the TV and PS5 to see if the problem hangs around.
Step 4: Deal with TV-Specific HDMI-CEC Settings
  • Culprit Behind the Scenes: Your TV’s brand-specific HDMI setup (think Samsung’s Anynet+ or LG’s SIMPLINK) might be the one wearing the pants here.
  • Solution:
    • Pull up your TV’s settings menu (how you do this can vary).
    • Either switch off HDMI-CEC or mess around with the HDMI input names and leave gaming stuff out.
Step 5: Firmware Oldies
  • What’s the Problem? Older systems on your PS5 or TV could have bugs making the HDMI-CEC act loony.
  • Fix It Up:
    • Get your PS5 patched up: Settings > System > System Software > Update Available.
    • Head to your TV’s maker for any fresh firmware updates.
Bonus Tips
  • Voice Command Mishaps: A voice command system like Amazon Alexa or Google Assistant might be stirring your PS5 awake. Don’t forget to turn those off!
  • PS5 Physical Check: Just in case, make sure your PS5’s power button isn’t stuck or finicky.
Once you’ve ticked these boxes, your PS5 should mind its own business and let your TV do its thing without fuss. Still frustrated? Give Sony Support a shout, and they’ll sort out any hardware drama.
If your PS5 keeps springing to life whenever your TV gets powered on, you’ve definitely come to the right place. Here’s how to keep that situation under control and take charge of your setup.
First off, your PS5 and its settings are your best friends here. Fire it up and dive into the “Settings” menu. Go for “System,” then hit up “HDMI.” Uncheck the “Enable HDMI Device Link” option—simple but effective.
Now let’s take a look at the TV. In most cases, it’s the HDMI-CEC settings that cause the PS5 to wake up. Head over to your TV’s settings and search for HDMI-CEC. They might have a fancy name like Anynet+ for Samsung, Bravia Sync for Sony, or Simplink for LG. Turn off whatever option your TV uses.
Here’s a nifty tip: Keep your firmware fresh. Make sure both your PS5 and TV are up-to-date. This way, any little quirks or bugs that might cause tech havoc are sorted out. Just surf over to the “Settings” menu on both devices and look around for updates.
If you’re still pulling your hair out over this issue, those good old user manuals or the support sites can be lifesavers. And hey, for other tips, check out PlayStation’s support page right here.
In a nutshell, these steps should do the trick to keep your PS5 from getting overly excited every time you turn on your TV. It’s all about managing your gadgets and taking back control. Give it a shot!
