How can I stop forward calls from my landline to my cell phone?
501 viewsPhone
Want to stop forwarding calls from your landline to your cell phone? Here’s the scoop on how you can do it, plain and simple. But heads up, the exact steps might differ a bit depending on your phone service provider.
For Landlines
Using Specific Codes:
  • Unconditional Call Forwarding: Lift your receiver, wait for the dial tone, and punch in 73 (or *73). That’s usually the go-to code to turn off unconditional call forwarding for most services. Listen for that confirmation tone or message to know it’s done, then hang up.
  • Conditional Call Forwarding:
    • Busy: Dial *67 and wait for the beep or confirmation message.
    • Unanswered: Dial *61 and hang tight for the confirmation.
    • Unreachable: Dial *62 and you know the drill – wait for the confirmation tone.
Via Call Settings: Got a landline phone with menu options? Poke around in the settings for the “Call Forwarding” option and turn it off there.
For iPhone
Using Call Forwarding Codes:
    • Busy: Open your Phone app, tap on Keypad, dial ##67#, and hit the Call button.
    • Unanswered: Dial ##61# and press Call.
    • Unreachable: Dial ##62#, press Call. You’ll get a confirmation message or tone telling you the forwarding is off.
  • Unconditional Call Forwarding: Open Settings, scroll down to “Phone,” find “Call Forwarding,” and simply toggle the switch to off.
For Android
  • Conditional Forwarding: Open the Phone app, tap on the Menu (three dots) icon, select Settings, then Call Forwarding. Pick the type you want to disable, dial the right code (##67# for Busy, ##61# for Unanswered, ##62# for Unreachable), and turn it off.
  • Unconditional Forwarding: Again, open Phone app, Menu icon, Settings, Supplementary Service, Call Forwarding, Voice Calls, Always Forward, and disable it or remove the number.
Other Methods
  • Check with Your Service Provider: Still scratching your head and not getting the codes right? Just give your service provider a call. They can walk you through it or even switch off the call forwarding for you.
  • Check Your Phone’s Settings: Smartphones usually come with settings you can fiddle with directly to change call forwarding features.
And there you have it! That’s the basic rundown on stopping call forwarding from your landline to your cell phone. Make sure to tweak it a bit based on your specific phone and provider. Happy dialing!
So, you’ve got calls from your landline getting redirected to your cell phone, and wish to stop that? No worries, here’s how you can turn off call forwarding in a few simple steps.
First thing: grab your landline, check if you’ve got a dial tone, and get ready to punch in some numbers. Most providers have a deactivation code, and the trusty go-to is usually *73. But hey, providers have their quirks, so here’s a quick rundown:
  • Verizon: just dial *73.
  • AT&T: fans might need #21#.
  • T-Mobile: give ##21# a try.
Once that’s done, pause a second and listen for that sweet confirmation sound—a few beeps or a voice telling you it’s a done deal. That’s your cue that things are on the up and up.
Still feeling a bit unsure if it worked? No biggie—try calling your landline from another phone. If it rings there instead of popping over to your cell, you’re in the clear!
But what if things don’t go according to plan? Maybe the code doesn’t cut it or the tone’s gone AWOL. Then, chatting with your service provider could save the day. They’ll help figure things out and might have some unique tips and tricks for your setup.
Now, if you’ve dabbled in conditional call forwarding (only when you’re busy or when no one picks up, that sort of thing), it might take another code to nip that in the bud. Toss in codes like:
  • Busy times: ##67#
  • No answer: ##61#
  • Phone’s unreachable: ##62#
One last nugget of knowledge: each provider has their quirks, so if things seem off, they’re probably worth a call.
With these steps, your landline calls should stay put instead of taking a detour to your cell. It’s all about getting those calls where you want them, without the fuss.
So, you want to stop your landline from forwarding calls to your cell phone? No sweat, we got you covered!
Call forwarding is convenient for some folks, but let’s face it, it can be a real headache if it wasn’t your idea or if it’s gone rogue. Let’s break it down and see why this might be happening and how you can fix it without pulling out your hair.
The Lowdown on Call Forwarding
Okay, here’s how it works: Call forwarding—or call diversion, if you’re feeling fancy—sends your incoming landline calls to another number, usually your mobile. You can kickstart this manually with dial codes, through your phone company’s settings, or via gadgets like answering machines.
Why and How to Fix It
  • 1. Hit by Dial Codes
    Reason: Maybe you (or someone else) dialed the wrong codes and triggered call forwarding. Oops!
    Fix: Time to hit up those deactivation codes.
    • Usual deactivation codes (they’re different everywhere):
      • In North America, punch in *73 or ##004#.
      • If you’re in the UK/EU, go with #21#.
      • For a good all-rounder, try ##002# to clear everything.
    • Steps:
      1. Pick up the landline receiver—old school style.
      2. Dial the code that matches your region or provider.
      3. Wait for that sweet confirmation tone or message.
    • Tip: If you’re stumped, peep your provider’s website or manual for clues.
  • 2. Provider Shenanigans
    Reason: Sometimes, providers toss in call forwarding as part of their deals—like “Voicemail-to-Mobile” or “Always Forward”—without you even knowing.
    Fix: Give them a ring and axe the feature.
    • Steps:
      1. Hit up customer service (AT&T, Verizon, BT, whoever).
      2. Ask them nicely—firmly works too—to scrap call forwarding services.
      3. Get them to double-check that no sneaky forwarding rules slipped through.
    • Pro Tip: Drop phrases like “disable unconditional call forwarding” when you’re telling them what you want.
  • 3. Voicemail Hiccups
    Reason: Sometimes, voicemail systems send those calls to your mobile if your landline stays silent.
    Fix: Tweak those voicemail settings.
    • Steps:
      1. Ring into voicemail: Use your provider’s number (like *86 for AT&T).
      2. Find the menu option for “Call Forwarding” or “Greetings.”
      3. Stop it right there from forwarding to your cell.
  • 4. Sneaky Third-Party Devices
    Reason: Gadgets like answering machines, VoIP adapters, or even home security systems might be secretly forwarding calls.
    Fix: Give all connected devices a glance.
    • Steps:
      1. Unplug everything hooked to the landline—fax machines, VoIP boxes, the works.
      2. Make a test call to check if forwarding’s gone. If your call doesn’t bounce, plug devices back in one by one to find the culprit.
      3. Tweak settings on the offending device or reach out to the manufacturer.
  • 5. Unauthorized Tinkering
    Reason: Maybe someone managed to mess with your settings—think weak passwords or a little social engineering.
    Fix: Tighten up your account security.
    • Steps:
      1. Change up your telephone account password ASAP.
      2. Get your provider to look at recent account changes and spot anything fishy.
      3. Put the security patrol on duty with two-factor authentication, if it’s an option.
Extra Tips
  • Test Your Moves: After going through the steps, make a call to your landline from another phone to confirm the forwarding is a thing of the past.
  • Scan for Malware: Using VoIP? Give your network a malware scan just to be cautious.
  • Line Check: Once in a blue moon, dodgy wiring or splicing could lead to misdirection. Let your provider know if you suspect anything unusual.
Time to Call in the Reinforcements
If nothing’s working, here’s the plan:
  1. Ask for a Provider Reset: Politely (or not) ask your carrier to reset your line to factory settings.
  2. Lodge a Complaint: When all else fails and calls keep bouncing, report it to the powers that be, like the FCC in the U.S. or Ofcom in the UK.
Once you tackle these pesky problems, you’ll be back in the driver’s seat, controlling your landline’s call routing like a pro and warding off any stray calls. Happy calling!
So, you’ve got calls from your landline going to your cell phone and it’s driving you mad? Let’s fix that up, shall we?
Quick Fix on Your Phone:
  • Grab your landline phone and pick up the receiver to get that classic dial tone.
  • Punch in *73 if you’re hanging out in the US. You should hear a beep or some sort of message that lets you know it’s done.
  • Put the phone back on the hook.
Check Your Service Provider Codes:
  • A lot of places let you dial #21# to stop forwarding. So, take a peek and see what your service provider suggests.
Poking Around Online:
  • Dive into your landline service provider’s website account.
  • Look for call settings or something along those lines.
  • Turn off call forwarding. Bam, done!
Call in the Pros:
  • Not getting anywhere? Don’t sweat it. Just ring up customer support from your landline service provider. They’ve got your back and can walk you through it.
