How Do I Stop Discord from Opening When I Start My PC?
503 viewsComputer
Discord’s a pretty awesome chat app, especially for gamers, but it can get super annoying when it starts up with your computer. This is meant to keep things updated and running smoothly, which is nice and all, but it can slow down your boot time and clutter up your desktop. So, let’s dive into how you can stop Discord from opening automatically whenever you turn on your PC:
For Windows Users
  • Through Discord Settings: Pop open Discord and hit that gear icon in the bottom-left corner to get into settings. Head over to “Windows Settings” under the “APP SETTINGS” list. Just flip the switch next to “Open Discord” in the startup section to off. Restart your PC, and voila, no more auto-launch.
  • Using Task Manager: Press Ctrl + Shift + Esc to open Task Manager. Switch to the “Startup” tab (or “Startup apps” depending on your Windows version). Find Discord in the startup programs list. Sometimes it shows up as “Update.exe” or might have the GitHub logo. Right-click it and hit “Disable.” This won’t pull Discord off the list, but it stops it from running at startup.
  • Via Windows Settings: Click the Start button and head to “Settings.” Click on “Apps” from the left menu, then choose “Startup.” Scroll down until you find Discord, which might be labeled as GitHub. Turn off the switch next to Discord and restart your PC.
For Mac Users
Click the Apple logo up in the top-left corner and pick “System Settings” from the dropdown. Once in System Settings, click “General,” then “Login Items” in the General settings list to see your startup apps. Locate Discord, select it, and click the minus sign at the bottom-left of the list to remove it. Now, Discord won’t start up with your computer. If you later decide you want Discord to open at startup again, just click the plus sign and add it back.
Benefits of Preventing Discord from Opening at Startup
  • Faster Boot Time: With fewer apps launching, your computer boots quicker.
  • Improved Performance: Cutting down on background apps frees up resources like CPU and RAM, boosting overall performance.
  • Extended Battery Life: On laptops, fewer background processes can help your battery last longer.
  • Reduced Clutter: A cleaner system tray and fewer background apps make managing your system easier.
Why Does Discord Open on Startup by Default?
Discord’s set to open automatically so it’s ready to go for frequent users. It saves time since you don’t have to manually open the app, plus it handles updates quietly in the background for a smoother experience.
Remember, stopping Discord from starting up with your computer won’t mess with how it works. You can still open and use it just like always. If you want to check if Discord is set to run at startup without actually opening the app, just look in the Startup tab in Task Manager on Windows or navigate to System Preferences > Users & Groups > Login Items on a Mac.
Hey there! Want to stop Discord from popping up every time your PC starts? No worries, I’ve got some tricks for you, whether you’re on Windows or Mac.
Windows 10 and 11:
First up, Discord Settings. Just fire up the app, click that gear icon by your username, and head to “Windows Settings” under “App Settings”. Flip the “Open Discord” switch off and you’re good to go—no more automatic launches!
Next, you can try the Task Manager route. Right-click your taskbar or hit Ctrl + Shift + Esc to pull it up directly. Jump over to the “Startup” tab, find Discord, give it a right-click, and smack that “Disable” option. Easy peasy, right?
If you’re feeling adventurous, dig into Windows Settings. Hit the Start button and pick the Settings icon. Then stroll over to “Apps” and find “Startup”. Once you see Discord lurking there, just toggle it off.
Now here’s another little trick—check your Startup Folder. Press Win + R, type shell:startup, and hit Enter. If you spot a Discord shortcut, just ditch it from the folder. Bye-bye, Discord!
Oh, and don’t forget to look out for any sneaky update processes. They might sneak Discord back into your startup lineup. So go back to Task Manager, scope out any update-related entries, and give it the boot.
Mac:
Hop over to System Preferences. Click the Apple menu, hit “System Preferences”, then go to “Users & Groups”. Pick your user account and slide into the “Login Items” tab. See Discord? Give it the ol’ minus button and poof—no more startup surprise!
Those are the moves to ensure Discord stays away until you call! Honestly, once you’ve unhitched Discord from auto-start, it’s like a breath of fresh tech air. Enjoy a smoother boot-up, folks!
Stopping Discord from Automatically Launching When Your PC Starts Up
Ugh, Discord booting up every time you turn on your computer can be annoying, right? Well, fear not, because we’ve got some ways to stop it in its tracks. Let’s jump right in!
1. Turn Off Auto-Start in Discord Settings
Discord’s got this sneaky default setting that launches the app automatically, but you can change that:
  • Fire up Discord.
  • Hit that little gear icon (⚙️) by your profile pic to get into User Settings.
  • Head over to App Settings and then Windows Settings.
  • Flip the switch for Open Discord in System Startup Behavior to off.
  • Restart your PC to see if the changes stick.
2. Tweak Startup Settings in Windows
Sometimes, Discord is marked as a startup app in Windows itself. Here’s how to tackle that:
  • Press Win + I to dive into Settings.
  • Go to Apps and then Startup or Startup Apps if you’ve got Windows 11.
  • Find Discord in there and toggle it to Off.
  • Give your system a quick reboot to check the changes.
3. Use Task Manager to Stop Discord at Startup
If Discord’s being stubborn, head to Task Manager and block it from the launch party:
  • Press Ctrl + Shift + Esc to open up the Task Manager.
  • Switch over to the Startup tab.
  • Right-click on Discord and pick Disable.
  • Again, restart to make sure it’s really gone.
4. Tinker with Registry Entries as a Last Resort
Okay, this one’s for when things get a little dicey with registry entries playing tricks:
  • Press Win + R, type regedit, and hit Enter.
  • Navigate to:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
  • Hunt down and delete any entry named Discord or related to its executable path.
  • Restart your PC to see if it’s fixed.
5. Reinstall Discord if All Else Fails
Sometimes, a corrupted install is the culprit. Here’s the last resort:
  • Uninstall Discord by navigating to Settings > Apps > Installed Apps.
  • Get the freshest version from Discord’s official site.
  • During setup, make sure the Start Discord on login option is unchecked.
Extra Tips
  • Check if Discord’s lurking in the background processes. Head to Task Manager and terminate it if needed.
  • Consider using tools like CCleaner or Autoruns to get a handle on startup entries if you want to make sure nothing’s missed.
Hopefully, these steps will help you boot up your PC without Discord butting in. If Discord’s still being a pest, there might be some software conflicts or system updates causing trouble—worth checking those out too!
Hey there! If you’re tired of Discord popping up when you start your computer, I’ve got some simple tricks to fix that up for you. Let’s dive right in!
Way 1: Switch It Off in Discord Itself
  • Launch Discord: Go ahead, open the app.
  • Settings Snag: Spot the gear icon next to your username and give it a click.
  • Windows Options: Tap on ‘Windows Settings’ under ‘App Settings’.
  • Stop the Madness: Turn off ‘Open Discord’. Easy peasy!
Way 2: Task Manager to the Rescue (Windows)
  • Task Manager Open Sesame: Hit Ctrl + Shift + Esc or give the taskbar a right-click and pick ‘Task Manager’.
  • Dig Into Startup: Jump to the ‘Startup’ tab.
  • Ditch Discord: Find ‘Discord’, right-click, and zap it with ‘Disable’.
Way 3: System Configuration (Windows)
  • Run, Buddy, Run: Smash Windows Key + R to launch the Run Dialog.
  • Type Away: Punch in “msconfig” and hit Enter.
  • Startup Hocus Pocus: Head to the ‘Startup’ tab and grab ‘Open Task Manager’.
  • Ban Discord: Spot ‘Discord’, right-click, and hit ‘Disable’. Gone!
Way 4: Windows Settings, You Got This!
  • Settings Go Time: Press Windows Key + I to open up Settings.
  • Navigate Journey: Click on ‘Apps’, then ‘Startup’.
  • Bye Discord: Find ‘Discord’ and turn that pesky switch to ‘Off’.
With these handy tricks, you’ll stop Discord from auto-launching, and your PC will feel a bit peppier, like it just chugged a cup of coffee. Good luck!
