How Can I Stop My AirPods from Reading Texts?
511 viewsHeadphones
When using AirPods, it can be pretty annoying when Siri automatically starts reading incoming texts or other notifications out loud. If you’re wondering how to shut this feature off, here’s a handy guide to help you out.
So, why might you want to stop your AirPods from announcing notifications? Well, for one, privacy is a big deal. No one wants their personal messages broadcasted to everyone nearby. Also, constant notifications can be super distracting when you’re trying to work, study, or just chill with some music. And honestly, some people just prefer checking their notifications manually.
Let’s get into it.
Disabling the “Announce Notifications” Feature
The Settings Route:
  • Open the “Settings” app on your iPhone.
  • Tap “Notifications,” then “Announce Notifications” under the Siri section.
  • Flip the “Announce Notifications” switch to off. Boom, no more Siri interruptions.
The Control Center Shortcut:
  • Open Control Center on your iPhone.
  • If you don’t see the “Announce Notifications” icon, you might need to add it. Long-press any empty area, choose “Add a Control,” and then add the “Announce Notifications” icon.
  • Tap the bell icon to turn off the feature. Or, long-press it to turn it off for just an hour or a day. Easy peasy.
Customizing Notifications for Specific Apps
  • Go to “Settings” > “Notifications” > “Announce Notifications.”
  • Scroll through your apps, pick one (like Messages), and toggle off “Announce Notifications” just for that app.
Adjusting by Connection Type
  • Open Settings, tap “Notifications,” and head to “Announce Notifications.”
  • Under “Announce When Connected To,” turn off the “Headphones” switch. This way, Siri won’t bug you when your AirPods are connected.
Using Focus Mode
  • Swipe into Control Center and hit the moon icon to activate “Do Not Disturb.” This silences all notifications.
  • Or, long-press the moon icon to fine-tune your Focus settings, setting specific times or conditions for fewer interruptions.
Additional Tips
  • Tweak Siri’s Voice Volume and Speed: Head to “Settings” > “Accessibility,” tap “AirPods,” and adjust the volume for Siri’s voice. For speed adjustments, go to “Settings” > “Accessibility” > “Siri.”
  • Use Siri Commands: You can still ask Siri to read out specific messages, even with automatic announcements turned off. Just say, “Hey Siri, read my incoming message.”
By following these steps, you can stop AirPods from reading texts out loud and regain control over your notifications. And hey, if you change your mind later, just reverse the steps to turn the feature back on.
Ever been interrupted by Siri while you’re jamming out with your AirPods? Not fun, right? Luckily, switching off Siri’s notifications is more straightforward than you might think. Here’s how you can get back to music without the chatty interference.
Stop Siri from Interrupting Your Groove
  1. Settings Adventure: Pop open your Settings on your iPhone or iPad. You know, the gear icon—you’ve got this.
  2. Scroll Down a Bit: Tap on “Notifications” when you see it.
  3. No More Announcements: In Notifications, hunt down “Announce Notifications” and give it a tap.
  4. Slide to Silence: There’s a switch there—flip it off, and boom! Siri’s quiet while your AirPods are on.
Quick Fix with Control Center
  1. Control Center Move: Swipe down from the top right corner if you’ve got a newer iPhone, or up from the bottom on older ones.
  2. Find the Bell Icon: Spot the Announce Notifications icon—it’s shaped like a bell if you added it there.
  3. Tap and Done: Just tap that bell, and you’ll temporarily stop the announcements. No need to dig through settings every time.
Keep Some Apps Quiet
Don’t want to shut Siri up completely? You can hush only certain apps:
  1. Open Up Notifications: Back into Settings, click on “Notifications.”
  2. Pick and Choose: Scroll until you spot the app you want—like Messages—and tap it.
  3. Silence them Individually: Turn off the announce setting for the particular app. Easy peasy.
Take a Break with Do Not Disturb
If you really need a break:
  1. Control Center Again: You know the way by now.
  2. Set the Mood: Hit the moon icon for Do Not Disturb mode, and let peace reign until you decide to switch it off. Sometimes, a bit of silence is golden.
All said and done, these tweaks should let you enjoy the tunes without Siri butting in. Now you’re in control of what really matters—your vibe.
Sometimes those AirPods just seem to have a mind of their own, right? If you’ve been caught off guard by Siri reading your texts out loud through your AirPods, there are a few tricks to stop it. Let’s get into it.
First off, you might want to look at the “Announce Notifications” setting on your iPhone. This gem of a feature got introduced with iOS 14, and while it can be nifty if you want to know what’s happening without checking your phone, it can also get a bit irritating. Here’s how you turn it off: Head to Settings, then Notifications, and find Announce Notifications. Just switch that baby off. If you like the feature but not for everything, you can just pick specific apps and turn off announcements only for those.
But what if Siri’s still blabbing those messages? Well, then we gotta rein in your friendly assistant herself. Pop open Settings, go into Siri & Search, and then make sure Announce Calls and Announce Notifications are switched off. While you’re at it, check out Messages and stop Siri from reading them to you there.
Here’s the kicker: sometimes settings in Accessibility could be the culprit, like VoiceOver or Speak Selection. These can lead to having Siri read more than you bargained for. Check them out under Settings > Accessibility > Spoken Content, and make sure any auto-read features are off.
It’s worth having a look at app-specific notifications too. Even if you’ve turned off everything globally, certain apps might still be piping up when you don’t want them to. Take a spin through Settings > Notifications, pick the app, like Messages, and manage alerts there.
And if things are still acting up, you could try resetting your AirPods. Put them snug in their case, wait a good half a minute, then follow the steps to forget the device and reconnect them. While you’re at it, check if your firmware is up to date—sometimes stuff just needs a refresh.
Lastly, consider using Focus Modes for some peace and quiet; you can activate them from Control Center. It’s a lifesaver if you just want to shut off the chatter temporarily.
All these settings can start acting up due to default configurations or even accidental long presses on the AirPods. If you’re still stuck, it’s time to give Apple Support a shout.
Hope this helps get your AirPods behaving again!
So, your AirPods have started reading texts aloud, and honestly, it can be a bit annoying, right? Thankfully, there’s a straightforward way to put a stop to it, and it’s not rocket science. Let’s dive into it:
Turn Off Announce Notifications Directly on Your iPhone
  • First off, open up Settings on your iPhone.
  • Scroll until you hit Notifications and give it a tap.
  • Head over to Announce Notifications.
  • Here’s the kicker—just flip the switch to turn off Announce Notifications.
Tailor-made Siri Announcements—Only for the Apps You Choose
  • Jump back into Settings on your iPhone.
  • Scroll and tap on Siri & Search.
  • Find Announce Notifications and tap on it.
  • Take your pick (say, Messages) and turn off Announce Notifications for the app you’re not keen on sharing aloud.
Quick Fix from Control Center—Easy Peasy
  • Swipe to open the Control Center on your iPhone.
  • Hold your finger on the tile with things like Airplane Mode and Wi-Fi.
  • If you see the Hearing icon (looks like an ear), tap it.
  • Just toggle off Announce Notifications.
And there you have it! You’re all set to enjoy your tunes without the interruption of Siri shouting your texts for the world to hear. If you need more tips or a little more hand-holding, check out Apple Support—they usually have some tricks up their sleeve.
