How Do You Split Screen on Your Samsung Android Device?
250 viewsPhone
So, you’re wondering how to split screen on your Samsung device, right? You\’ve come to the right place! Samsung makes multitasking a breeze, letting you juggle two apps like a pro with their Split Screen mode or even have a floating app with Pop-up view. Let’s dive into how you can make this work.
First up, let\’s tackle the Split Screen using Recent Apps. Just swipe up from the bottom and hold it to bring up the apps you\’ve recently used. Pick the app you want to start with, tap its icon up top, and hit \’Open in split screen view.\’ Voila! It\’s half of your screen now, waiting for a buddy. Choose your second app from the bottom half, and you’re multitasking! You can adjust the size of these apps by dragging the divider up or down. Don’t want it anymore? Just hit the Home button or drag that line until one app is gone.
If you’re already using the Edge Panel, here’s the scoop: launch your first app as usual. Then, swipe in the Edge Panel (yeah, it’s that curious little side menu thing) and drag the second app over to split your screen. Easy as pie!
Now, on to the Pop-up View. While flipping through your Recent Apps, tap that same icon again, but this time go for \’Open in pop-up view.\’ Your app will shrink down into a movable window that you can totally move around the screen. Or, use the Edge Panel to drag an app to the center, and just like that, you’ve got a nifty floating window. Adjust it to your liking by pulling at the edges.
But wait, there’s more! Check out Picture-in-Picture mode. If you’re navigating with Maps or binge-watching videos, pressing the Home button turns the app into a small window in a corner—perfect for peeking at directions while texting.
Got a favorite app duo you always use together? Save \’em! While they\’re split, tap the triple-dot menu on the divider, hit the star icon, and boom—app combo shortcut for the future, right on your Home Screen or Edge Panel.
Keep in mind, though, all these nifty features are generally available for Samsung devices from the Galaxy S8 onward, though there might be slight tweaks depending on your model and Android version. No sweat!
There you have it. You\’re now well-equipped to multitask on your Samsung like a champ. Whether you’re catching up on shows while texting or doing a quick browse while jotting notes, these features are here to maximize your productivity. Happy multitasking!
How to Split Screen on Samsung Android Devices
So, you’ve got yourself a Samsung phone or tablet and you’re ready to crank up your productivity with a little split-screen action! If you’re running Android 7.0 Nougat or later with One UI (that\’s Samsung’s brainchild), you’re all set. Let’s dive into some easy-peasy ways to get that going.
Ways to Get Your Split Screen On
Right off the bat, remember that not all apps are on board with multitasking. Most apps are game, but some, especially those full-screen games, might just give you the cold shoulder.
Method 1: Hit Up the Recent Apps Menu
  1. Open up the first app you’re itching to use.
  2. Tap the Recent Apps button. You know, that square icon down at the bottom, or just swipe up and hold it (if gestures are more your style).
  3. Press and hold the app’s icon at the top of the preview.
  4. Pick “Split screen” from the menu.
  5. Select your second app from either Recent Apps or your home screen.
  6. Slide the divider to decide how much each app gets to hog the screen—it’s all in your hands!
Method 2: Groovy Gestures (One UI 3.0+)
  1. Dive into your phone’s settings, tweak the navigation to swipe gestures: Head over to Settings > Display > Navigation Bar > Swipe gestures.
  2. Launch your first app and then swipe up and pause to pop open Recent Apps.
  3. Tap that app’s icon and pick “Split screen.”
  4. Select app number two.
Method 3: Quick Launch from the Edge Panel
  1. Turn on the Edge Panel:
    • Go to Settings > Display > Edge Panels and flip the switch.
  2. Swipe the Edge Panel handle from the right edge—like flipping through a magazine.
  3. Jump into the Apps edge tab, grab an app, and plop it on the top or bottom half of your screen.
  4. Pick the second app for the left-over space.
Troubleshooting the Usual Suspects
Issue: \’Split Screen\’ is MIA (Grayed Out)
  • Why This Happens:
    • The app doesn\’t want to play nice—it doesn\’t support multi-window.
    • Your Android\’s \’Multi window\’ feature is taking a nap.
    • Your device’s parental controls or power-saving vibes might be stifling your style.
  • How to Fix It:
    1. Test it out with the usual suspects like Chrome, Messages, or YouTube.
    2. Wake up Multi-Window in Settings > Advanced Features > Multi window.
    3. For the tech-savvy: Force your way through with Developer Options:
      • Enable it by tapping Build Number seven times in Settings > About Phone.
      • Go to Developer Options > Force activities to be resizable and flip it on. Give your device a quick restart.
Issue: Apps Freeze or Give Up
  • Root Causes:
    • Your device is feeling cramped—low RAM or too much hustle in the background.
    • Some pesky software glitch.
  • Fix-It Ideas:
    1. Close out unused apps hogging up the Recent Apps.
    2. Zap the app cache: Settings > Apps > [App Name] > Storage > Clear Cache.
    3. Don\’t forget those software updates hiding out in Settings > Software Update.
Some Final Whispers & Handy Tips
  • Split Screen or Pop-Up Play: Samsung\’s also got a “Pop-Up View” for you (a floating window). Just drag an app up top and catch a quick task.
  • App Pairing Hacks: For the Galaxy pros out there with the Fold/Z Flip—saving split-screen combos is a thing!
  • Heads-Up: Some apps pause videos in split mode, like Netflix. For an uninterrupted binge, maybe try the Pop-Up View.
And that’s your split-screen saga! If your device keeps acting rough, a restart might just be the magic wand. Or hit up Samsung Support if you need to dig deeper. Happy multitasking!
Getting split screen mode going on your Samsung Android device isn’t as tricky as it might seem. Here’s a straightforward way to tackle it:
  1. Pull Up Recent Apps: Hit the Recent Apps button—it’s typically chilling at the bottom of your screen. You’ll see your latest apps lined up for action.
  2. Pick Your First App: Got the app you want to pair up? Tap the icon on top of its preview window.
  3. Go for Split Screen: Hit Open in Split Screen View from the menu that pops up. This app will camp out on the top or left side of your screen.
  4. Choose the Second App: Now, pick the second app you want side-by-side from your recent apps list. Tap it, and voilà, it’ll fill the other half of the screen.
Quick Tips:
  • Resize the Windows: Want to change up how much space each app gets? Drag the divider line to adjust.
  • Exit Split Screen: No need for split screen anymore? Just drag that line all the way up or down, and one app will take over.
  • App Compatibility: Heads up, not all apps are split-screen friendly. If it doesn’t show the option, it’s probably not gonna work out.
This is a lifesaver for multitasking—double the apps, double the efficiency!
If you’re scratching your head over this, check out Samsung’s official support for more help.
