How Can I View My Reddit History on Mobile?
436 viewsPhone
Here’s the lowdown on checking your Reddit history on mobile:
Browsing History
  • Using the Reddit App:
    • Open the app.
    • Tap your profile icon in the upper-right corner.
    • Choose “History” from the side menu.
    • You’ll get a list of stuff you’ve recently looked at. For more options, click “Recent” in the top-left corner and choose from “Upvoted”, “Downvoted”, or “Hidden”. Keep in mind, this history is tied to your device and won’t include stuff from Reddit on your computer.
  • Using a Browser:
    • If you’re logged into Reddit on a mobile browser, check the browser’s history. The steps might be different depending on which browser you’re using, but tapping on the history icon should show everything you’ve viewed.
Search History
Want to revisit searched terms? Click on the search box at the top of the app or site. You’ll see your recent searches pop up below. To clear individual searches, just click the “X” next to each one. Some browsers let you clear all search history in one go.
Other History Records
  • Posts and Comments:
    • Go to “My Profile” from the profile icon. This will show your posts and comments.
    • To delete a comment: tap it, go to the post page, hit the three dots next to “Reply”, and pick “Delete”.
  • Saved and Hidden Content:
    • Find saved content under “Saved” in the profile menu.
    • Hidden content is under “History”, then “Hidden”.
Notes
  • Data Retention:
    • On desktop, your browsing and search history will stick around until you delete it or log out. Logging out wipes it clean.
    • The mobile app keeps your history even if you log out, so you’ll find everything saved when you log back in.
  • Privacy Considerations:
    • Only you can see your browsing history; others can’t. However, your posts and comments are public. If privacy is your concern, clear your history or use Reddit’s anonymous mode.
Some third-party apps like Reddit Enhancement Suite (RES) or Reddit Browser also let you see your history, but always make sure they’re safe and reliable to avoid privacy risks.
To check out your Reddit history on your phone, it’s actually pretty simple. Here’s the scoop for both Android and iOS users.
First things first, grab your phone and open the Reddit app. Make sure you’ve logged into your account. Easy, right? Once you’re in, you’ll want to tap your profile icon. You know, that little picture in the top right corner. When you do, it’ll drop down a menu with all sorts of options about your account.
Alright, the next step is to hunt for the “History” option in the menu. It might take a quick scroll, but once you spot it, tap away! Now you’ve got a list of your recently viewed posts right there on your screen. And guess what? Unlike the desktop version which shows just a handful, the mobile app gives you a deeper dive into what you’ve been scrolling through.
Want a bit more control over what you’re seeing? You can sort through your history. Just peek at the top left for sorting options. Whether you want recent posts, things you’ve upvoted, or even those you’ve hidden, you can filter based on your style.
Let me throw in a bit more info here. Remember, your browsing history isn’t open for all to see—it’s private. But keep in mind, any public comments or posts you’ve made are still out there for others to see. And if privacy is nagging at you, you can clear out entries or wipe your whole browsing history through app settings.
So, bottom line? Swipe through your Reddit app to keep tabs on your history, click on your profile, hit up ‘History,’ and sort through your activity. Happy browsing!
So you want to check out your Reddit history on mobile, huh? Whether you’re trying to find that one memorable post or just curious to see what you’ve been up to, here’s how you can dive into your Reddit past on your phone.
Getting a Grip on Reddit History
Reddit history is basically two things:
  1. Browsing History: Stuff you’ve looked at, like posts and comments.
  2. Activity History: Stuff you’ve done, like posting, commenting, or upvoting.
Usually, Reddit keeps all this data unless you decide to wipe it clean. Finding it on your mobile isn’t too tricky but might vary a bit depending on when they last updated the app or what phone you’ve got.
Steps to Check Out Your Reddit History on Mobile
Going Through Your Browsing History
  • Fire up the Reddit app and tap your profile icon in the top-left corner.
  • Hit History from the dropdown menu.
  • Voila! You’ll see a list of stuff you’ve checked out.
Checking Out Your Activity History
  • Go to your profile page using that same profile icon.
  • Tap Posts, Comments, or Upvoted to get the scoop on your actions.
Common Problems & Fixes
Problem 1: Missing “History” Option
  • Possible Reasons:
    • Your app’s not up to speed.
    • You’re not logged in.
    • Your region has a different setup.
  • Fixes:
    • Get your app up-to-date through Google Play Store or Apple App Store.
    • Log out and log back in.
    • If all else fails, uninstall and reinstall the app.
Problem 2: Partial History
  • Possible Reasons:
    • Browsing in “Incognito Mode” (which Reddit doesn’t really support).
    • Automatic history delete due to app settings.
  • Fixes:
    • Turn off third-party browsers or extensions that mess with tracking.
    • Use Reddit’s “Save” feature to bookmark posts you want to find again.
Problem 3: Sync Issues Across Devices
  • Possible Reasons:
    • History doesn’t automatically sync between devices.
  • Fixes:
    • Open Reddit in your mobile browser while logged in for the full rundown.
Extras for the Savvy
  • Third-Party Tools: Check out something like Trend Analytics for Reddit, but remember it needs careful permissions.
  • Data Dump: Get your Reddit data through Settings > Privacy & Security > Download Data for an in-depth look.
Watching Your Privacy
  • Your Reddit history is private unless you decide to share it.
  • To clear out history, hit History > Clear All.
With these pointers, you’ll be managing your Reddit history like a pro on your mobile. If things don’t pan out, reaching out to Reddit support or the community could be worth a shot.
Checking out your Reddit history on your phone? It’s a breeze! Here’s how you can do it:
If you’re rocking an Android:
  • Pop open that Reddit app.
  • Log yourself in.
  • Hit the profile icon up there in the corner.
  • Tap on History to see all the good stuff you’ve been up to—posts, comments, you name it!
Rolling with iOS? Here’s your roadmap:
  • Fire up the Reddit app.
  • Get yourself logged in.
  • Tap the profile icon hanging out at the bottom-right.
  • Dive into History to check out what you’ve been posting, commenting, and searching for.
Now, let’s talk about clearing some of that history out—pruning time!
  • On Android, just long press on whatever you want gone and hit Delete.
  • Over on iOS, swipe left on a memory you want to forget and delete it like a bad habit.
There you go! With these steps, keeping tabs on your Reddit escapades, and tidying up when needed, is as smooth as a Sunday morning.
