How to Screenshot on Iphone Without Home Button?
314 viewsPhone
Snapping a screenshot on an iPhone without a home button is no sweat, and there are a few neat ways to do it. Let’s dive right into them and see what works for you!
Button Combo Magic
For those newer iPhones (like the iPhone X or later), it’s all about that button combo. Here’s what you do:
  • Spot the Buttons: You’ve got the Side button on the right and the Volume Up one on the left.
  • Press and Release: Just give both buttons a quick press and release at the same time.
  • Boom—Screenshot: Your screen will flicker with light, and a thumbnail will appear down in the corner so you can edit or share it at your leisure.
Watch out though—fumble this quick enough, and you might just turn your phone off by mistake!
AssistiveTouch to the Rescue
If playing “press the right buttons before you power off” isn’t your thing, AssistiveTouch is a lifesaver:
  1. Get it Going:
    • Head to your Settings.
    • Tap Accessibility.
    • Hit Touch, then click AssistiveTouch.
    • Turn it on, and voilà—a floating button appears.
  1. Jazz Up the Menu:
    • Dive into the Customize Top Level Menu in AssistiveTouch settings.
    • Slip in the Screenshot action wherever you fancy.
  1. Screenshot Galore:
    • Tap the floating button.
    • Choose Device, tap on More, and then hit Screenshot.
And hey, if you’re feeling fancy, set it up so a simple double-tap or long-press of the AssistiveTouch button does the trick!
Back Tap Wonder
This feature is mighty cool. You can snap a screenshot just by giving your phone’s back a good tap:
  1. Set It Up:
    • Go to Settings > Accessibility > Touch > Back Tap.
    • Choose either Double Tap or Triple Tap and set it to Screenshot.
  1. Tap Away: Simply tap the back of your phone to snag a screenshot. Easy peasy.
Siri—Your Screenshot Sidekick
You can go hands-free with Siri, too. Here’s how:
  • Make Sure Siri’s Awake: Turn her on in the settings.
  • Have a Chat: Say “Hey Siri” or hold the Side button down.
  • Give the Command: Just say, “Take a screenshot,” and let Siri do her thing.
What’s somehow surprising is just how many ways you can go about grabbing a screenshot if a home button isn’t in the cards. Try any of these tricks, and you’ll have all your important info saved without breaking a sweat. Whether it’s with buttons, taps, voice, or menu magic, you’ve got options!
Taking Screenshots on an iPhone Without a Home Button
If you’ve got an iPhone without a Home button (think iPhone X and above), you might be scratching your head wondering how to snag a screenshot. It’s not just a need-to-know situation for newbies—sometimes you’ve got buttons that are on the fritz or might just prefer an easier way. Let’s dive into how you can grab those screenshots effortlessly.
Easy Peasy: Button Combo Method
Ready to snap that screen? For iPhones like the X and newer, here’s the lowdown:
  1. Find Your Tools:
    • The Side button is your power/lock savior and sits on the right side.
    • The Volume Up button chills on the left.
  2. Get Smashin’:
    • Give the Side and Volume Up buttons a quick squeeze together for about a second.
    • See the screen flash and hear the click? You’ve nailed it.
  3. Ta-da! Find Your Screenshot:
    • Now just head over to Photos > Albums > Screenshots to see your masterpiece.
If your buttons are giving you grief, don’t worry—we’ve got tricks up our sleeve! Let’s keep moving.
Riding on Backup Plans
AssistiveTouch Vibes (Virtual Button)
Broken buttons? No sweat! Turn on AssistiveTouch, an on-screen helper to save the day.
Get It Going:
  1. Open Settings > Accessibility > Touch > AssistiveTouch.
  2. Flick the AssistiveTouch switch on—you’ll see a nifty floating button.
  3. Shape It How You Want:
    • Hit Customize Top Level Menu.
    • Replace an icon or add one by hitting the +, choosing Screenshot.
  4. Instant Screenshot Rush:
    • Assign Screenshot to single/double tap or long press in the AssistiveTouch settings—snap a shot quicker than you can say “cheese.”
Tap That Back: Magic of Double-Tap
Here’s the kicker: hidden settings let you capture with a quick tap of your phone’s backside. Yeah, really.
Setting It Up:
  1. Navigate through Settings > Accessibility > Touch > Back Tap.
  2. Pick Double Tap or Triple Tap.
  3. Smack Screenshot in the list of tricks.
  4. Give your phone’s back a double or triple tap to try it out.
Uh-oh, When Things Get Wonky
Common Hurdles
  • Button Funk: Maybe your hardware is kaput.
  • Software Drama: Get up-to-date; don’t leave those settings hanging.
  • Gesture Woes: Fiddling gone wrong with AssistiveTouch or Back Tap.
Fixes You’ll Love
  1. Boost Button Mood: Clear debris and hit up Apple Support if needed.
  2. IOS Revamp: Keep the iOS in its prime by updating via Settings > General > Software Update.
  3. Freshen Up Settings: Give AssistiveTouch/Back Tap a reset when they get finicky.
Wrap-Up Without the Wrap-Up Feel
So, what it boils down to is this:
  • First choice? Go for that Side + Volume Up button combo.
  • Or, bust out AssistiveTouch or Back Tap if your phone doesn’t want to cooperate.
  • Stay current with iOS updates—just a little TLC goes a long way!
Mix and match these approaches, and screenshots will be your best friends despite missing that Home button. Have fun getting your shots!
Want to grab a screenshot on an iPhone that’s missing a home button? No worries, I’ve got a few tricks for you!
First up: the button combo. Just press the Side button on the right and the Volume Up button on the left at the same time. Boom, the screen will flash, and you’ll catch that screenshot. A little thumbnail will pop up on the bottom left—tap it if you’re in the mood to doodle or share it with someone.
Next, let’s talk AssistiveTouch. Go to your Settings app, dive into ‘Accessibility,’ and hit up ‘Touch.’ Flip on ‘AssistiveTouch’ from there. You’ll see a little circle on your screen now. Tap it, hit ‘Device,’ then ‘More,’ and snag that ‘Screenshot’ option. Flash! You’re all set.
Feeling lazy? Just ask Siri! Wake Siri by holding down the Side button or throwing out a ‘Hey Siri,’ and simply say, ‘Take a screenshot.’ Siri’s got your back.
So, whether you’ve got an iPhone X or a shiny new model without a home button, these are your go-to moves for snagging that perfect snapshot.
