How to Screenshot on Iphone Without Buttons?
439 viewsPhone
Alright, let’s be real—taking screenshots on your iPhone’s usually a matter of pressing a few buttons. But hey, sometimes those buttons aren’t working, or maybe you just want an easier method. Whatever the reason, here are some cool ways to grab a snapshot of your screen without fumbling around with buttons.
Using Siri
Siri isn’t just good for setting reminders or asking about the weather. Your trusty voice assistant can also take screenshots for you. Here’s how you do it:
  • First off, make sure Siri is turned on. Head over to “Settings” > “Siri & Search” and activate “Listen for ‘Hey Siri'” or “Press Side Button for Siri.”
  • Say “Hey Siri” or press and hold the side button to wake her up.
  • Then, just say “Take a screenshot.” Boom! You’ll see the thumbnail pop up in the bottom-left corner of your screen.
If you’re in a hurry, you can simply blurt out “Hey Siri, take a screenshot” and she’ll take care of it.
Using AssistiveTouch
AssistiveTouch is like your personal on-screen helper, making life easier by letting you perform tasks without those pesky physical buttons. Setting it up is super simple:
  • Open your “Settings” app and scroll down to “Accessibility.”
  • Under “Physical and Motor,” tap “Touch.”
  • Toggle on “AssistiveTouch.” You’ll see a small white dot appear on your screen.
  • Tap this dot, select “Device,” then “More,” and finally tap “Screenshot.” That’s it!
If you use it often, you can customize the AssistiveTouch menu by replacing one of the icons with “Screenshot.” Easy peasy!
Using Back Tap
Starting with iOS 14, Apple gave us this nifty feature called Back Tap. It lets you snap a screenshot by tapping the back of your phone a couple of times. Here’s how you get it rolling:
  • Head to “Settings” and find “Accessibility.”
  • Scroll to the bottom and hit “Back Tap.”
  • Pick “Double Tap” or “Triple Tap,” whichever you prefer. Then choose “Screenshot” from the list.
Just double or triple tap the back of your iPhone, et voilà! Screenshot taken.
Using Third-Party Applications
If you feel like exploring, there are apps on the App Store that let you take screenshots (and do a whole lot more). Some popular ones are Snagit, Screenshot Maker Pro, and Record it!. Install your chosen app and it’ll guide you through the rest.
Tips for Managing Screenshots
Once you’ve got your screenshots, it helps to keep things organized. Here’s how:
  • Create a designated album in your Photos app for screenshots. Keeps everything neat and easy to find.
  • Regularly review and delete the ones you don’t need to free up space.
  • Use the built-in editing tools to crop or annotate your screenshots before sharing them.
  • Share your screenshots easily using the Share button to send them via messages, email, or social media.
  • If you have iCloud enabled, your screenshots get backed up automatically, making them accessible from other devices.
These tricks and tips should make capturing and managing screenshots a breeze without ever touching a button.
Want to snap a screenshot on your iPhone without hitting any of those pesky buttons? No problem! There are a couple of nifty tricks in your iPhone’s settings that’ll let you do just that. Let’s dive in!
AssistiveTouch Method
First up, AssistiveTouch is your friend. This feature is a lifesaver when your buttons aren’t cutting it. Here’s how you get that set up:
  • Hit up your Settings.
  • Scroll down to Accessibility.
  • Tap Touch, then find AssistiveTouch.
  • Toggle it on, and you’ll notice a little white dot showing up on your screen—that’s your new shortcut buddy!
Now, to make taking those screenshots a breeze:
  • Go back to the AssistiveTouch menu and pick Customize Top Level Menu.
  • Tap an icon you want to replace or hit that “+” button to add something fresh.
  • Make sure to select Screenshot. Voilà! You’ve got a screenshot option right on that little dot.
When it’s time to capture that meme or cat video, just tap that white dot and then hit Screenshot. Easy peasy!
Back Tap Method
If you’ve got an iPhone 8 or newer, here’s a feature you might not know about—Back Tap. It’s like magic:
  • Head to Settings > Accessibility.
  • In Touch, scroll down to Back Tap and pick your poison: Double Tap or Triple Tap.
  • Assign Screenshot to your tap choice.
Now, just a couple of taps on the back of your phone and—snap—screenshot ready!
Ask Siri to Lend a Hand
And if you’re feeling talkative, don’t forget Siri. Just say, “Hey Siri, take a screenshot,” and Bam! Your screen capture is done just like that.
All these tricks mean you can capture everything you need without fiddling with buttons, especially if they’re on the fritz. Go, you tech wizard!
Trying to snap a screenshot on your iPhone without getting tangled up in button combinations? You’re in luck! There are some slick ways to get the job done without pressing any physical buttons. Let’s break it down.
When Button-Free Screenshots Come in Handy
  • Buttons Gone Bad: Your buttons kicked the bucket? No worries.
  • Easy Access: Sometimes you just need an easier touch-based method.
  • Speedy Convenience: Rapid-fire screenshots for constant users.
AssistiveTouch: Your Button Replacement Sidekick
Want a virtual button instead? Here’s how you can make it happen.
  • Turn On AssistiveTouch: Head over to Settings > Accessibility > Touch > AssistiveTouch and flick the switch. Look for the little floating buddy on your screen.
  • Customize the Screenshot Action: Tap into Custom Actions and choose between a double-tap or a long press. Then, pick Screenshot from the list.
  • Snap that Screenshot!: A double-tap or long press on the AssistiveTouch button, and voila, your screenshot is saved in Photos.
Tip: If you’re cruising with iOS 14+, you can add a special screenshot icon to the menu.
Back Tap Magic for iOS 14+
Give your phone’s backside a tap to snap those screenshots!
  • Navigate to Settings > Accessibility > Touch > Back Tap.
  • Set up either Double Tap or Triple Tap.
  • Select Screenshot. Then, tap away on the back!
Downside? Only works on iPhone 8 and newer. And if your phone’s super-sensitive, you might get surprise screenshots.
Let’s Talk: Voice Control Screenshots
Hands-free for the win with iOS 13+! Just say the magic words.
  • Start by turning on Settings > Accessibility > Voice Control.
  • Say “Take screenshot” out loud, and it’s done!
Great for multitaskers or those who are on the go.
Siri Shortcuts: Your Screenshot Ticket
Automate the process with shortcuts.
  • Open the Shortcuts app, hit the plus symbol, and create a new one. Search for “Take Screenshot”.
  • Add any actions you like, such as Save to Album.
  • Name it something fun, like “Quick Snap.” Call upon Siri, “Hey Siri, Quick Snap.”
Pro Tip: Pin the shortcut to your home screen for easy access.
Oops – Help When Things Go South
Screenshots failing you? Try these fixes:
  • Low Storage: Make room in Photos or iCloud.
  • Software Hassle: Give your device a reboot or update that iOS.
  • Overheated Device? Cool it down first.
  • Conflicting Features: Switch off other accessibility functions for a bit.
Bonus: Third-Party Apps
Apps like Picsew or Tailor can offer screenshot options with fancy edits. Just be cautious with security.
Wrapping Up the Screenshot Saga
  • Go with AssistiveTouch or Back Tap if you want easy-peasy options.
  • Voice Control and Shortcuts offer cool, niche alternatives too.
  • Keep your iOS game strong, since these tools require certain versions!
So there you have it—options galore for capturing your screen without stressing about those buttons. Tune your settings to match your style or device needs, and screenshot away!
Capturing a screenshot on your iPhone without hitting any buttons? Sure thing, it’s super handy! Let’s dive into some easy ways to do it:
First up, AssistiveTouch:
  1. Head over to Settings > Accessibility > Touch > AssistiveTouch.
  2. Flip on AssistiveTouch. You’ll see a little floating button dancing on the screen.
  3. Tap that button, then go for Device > More > Screenshot. Watch for that blink as proof your screenshot is snatched!
Then there’s Siri:
  1. Just say “Hey Siri” or press the Side button to get Siri’s attention.
  2. Simply ask, “Take a screenshot.” Siri will do the magic and snap a shot for you.
Next, Back Tap (if you’re rocking iOS 14 or later):
  1. Navigate to Settings > Accessibility > Touch > Back Tap.
  2. Choose Double Tap or Triple Tap, then link it to Screenshot.
  3. A quick tap or two on your iPhone’s back gets the screenshot done!
Finally, if you like apps:
  1. Grab a reliable screenshot app from the App Store, like Screenshot Maker Pro.
  2. Follow its lead to capture screenshots without any button hassle.
No sweat if your buttons are glitchy or you prefer touch options—these tricks have got your back!
