How to Restart An Iphone Without Power Button?
451 viewsPhone
When the power button on your iPhone decides to quit, it can feel pretty inconvenient. But don\’t worry, you can still restart your iPhone without it. Here are some handy tricks:
Use the Settings App:
If your iPhone is still responding, you can use the Settings app to shut it down. Go to:
Settings General Shut Down
Drag the power-off slider, and your iPhone will turn off. Plugging it into a charger will automatically turn it back on.
AssistiveTouch Comes to the Rescue:
AssistiveTouch is a cool feature that lets you control your iPhone without the buttons. To enable it:
  1. Open the Settings app, then go to General Accessibility AssistiveTouch, and toggle it on.
  2. Tap the AssistiveTouch button that appears, select Device More Restart, and confirm.
Bold Text Trick:
This one’s pretty neat. Head over to:
Settings General Accessibility Bold Text
A prompt will pop up saying that enabling this feature will restart your iPhone. Hit Continue, and voilà, your iPhone restarts.
Force a Restart:
  • For iPhones with Face ID (iPhone X and newer): Quickly press and release the Volume Up button, quickly press and release the Volume Down button, then press and hold the Side button until the Apple logo shows up.
  • For iPhones with Touch ID (iPhone 8 and older): Hold down both the Home button and the Side (or Top) button until you see the Apple logo.
Letting the Battery Run Out:
If nothing else works, just let your iPhone\’s battery drain completely. After it shuts down, plug it into a charger. It will power back on once it has enough juice.
Reset Network Settings:
Not the most elegant solution, but it\’ll work. Go to:
Settings General Reset Reset Network Settings
Enter your passcode and confirm. Your iPhone will restart. Just remember, this will erase saved Wi-Fi passwords and paired Bluetooth devices.
Third-Party Software:
If your iPhone is stuck in recovery mode or just being stubborn, try third-party software like Tenorshare ReiBoot. Download it on your computer, hook up your iPhone, and follow the instructions to force a restart.
There you go, a bunch of ways to restart your iPhone without needing the power button!
Alright, so you’ve got an iPhone with a stubborn power button and you need to restart it—no worries, I’ve got some tricks up my sleeve. There are a few nifty ways to tackle this one, depending on your iPhone model and iOS version. Let’s dive in!
AssistiveTouch Magic
Meet AssistiveTouch, your new best friend for controlling your iPhone without pressing a single button. Here’s how to get this magical feature rolling:
  1. Fire Up AssistiveTouch:
    • Jump into Settings.
    • Hit up Accessibility.
    • Look for Touch and then tap AssistiveTouch.
    • Flip the switch to turn it on. Easy peasy!
  1. Get Your iPhone Restarted:
    • With AssistiveTouch on, you’ll see a floating button chilling on your screen.
    • Tap it, find Device on the list.
    • Press and hold the Lock Screen icon until the “slide to power off” slider shows up.
    • Slide it, sit tight until it’s powered off. Then plug it into a charger or your computer to start it up again.
Dive into Settings
Not feeling the AssistiveTouch way? No problem! Directly fiddling with the Settings gets the job done too:
  1. Pop open Settings.
  2. Sneak into General.
  3. Scroll all the way down and tap Shut Down.
  4. Slide to power off, like a boss.
To boot it back up, plug it into a charger or bump that volume button if you’ve got one.
The Battery Drain Drama
Okay, this one’s for those who don’t mind waiting a bit:
  1. Stick with your phone until it drains its battery completely and shuts down.
  2. Once it’s off, plug it in to charge; it’ll bring itself back to life after a couple of minutes.
This method requires some patience, but hey, it works!
Here’s how resetting those network settings can shake things up:
  1. Go to Settings > General > Transfer or Reset iPhone > Reset.
  2. Choose Reset Network Settings to give your device a quick reboot.
Expect to lose saved Wi-Fi networks, but your data remains intact.
Switch Up Bold Text
Here’s a sneaky tip: changing the bold text setting can also help restart the phone:
  1. Go to Settings > Accessibility > Display & Text Size.
  2. Flip the switch for Bold Text, and voila, you’ll get a prompt to restart now.
No Fuss Tricks
Honestly, fiddling with these settings is worth a shot if your power button’s acting up. Whether it’s Bluetooth outages or letting the battery sing its swan song, you’ve got plenty of options without even going near that button!
So, your iPhone’s power button isn’t working, huh? It happens more often than you’d think. Whether it’s from dropping the phone one too many times, it got splashed, or just wear and tear, you’re not alone in this. Don’t sweat it, ’cause there are ways to give your phone a fresh start, and you won’t need that stubborn power button to do it.
Behind the Breakdown
Basically, when the power button calls it quits, it’s usually due to:
  1. Physical damage: We all have those oops moments—dropping the phone or forgetting it outside when it rains.
  2. Software gremlins: Sometimes, tech has a mind of its own and just glitches out.
  3. Old age: After a while, things just stop working, right?
Anyway, if your power button is acting up, there are a bunch of ways you can restart your iPhone without it.
No Power Button, No Problem
AssistiveTouch is your friend
Works for: Any iPhone with iOS 11 or newer.
How-To:
  • Switch On AssistiveTouch:
    Slide into Settings, hit up Accessibility, then Touch, and finally, crank up AssistiveTouch.
  • Virtual Restart:
    Tap that AssistiveTouch bubble > Device > Lock Screen. Keep your finger down on the Lock Screen until you see the “Slide to Power Off”. Once off, plug your phone into a charger, or press that Side/Home button if it’s still got some mojo, and watch for the Apple logo.
Tweak Auto-Lock
Best for: Buttons not working temporarily.
Guide:
  • Set Auto-Lock to Never (hop into Settings > Display & Brightness > Auto-Lock).
  • Once the battery runs dry, charge her up and it’ll reset on its own.
Button Combos to the Rescue
Depends on the model
  • iPhone 8/SE (2nd/3rd gen) or newer:
    Here’s what you do: Ping the Volume Up, then Volume Down, and slap that Side button till you spy the Apple logo.
  • iPhone 7/7 Plus:
    Hold both Volume Down + Side button until you catch a glimpse of the Apple logo.
  • iPhone 6s or older:
    Press down on Home + Top/Side button till the logo pops up.
Gear Up with Accessories
  • Hook Up to a Computer:
    Connect your iPhone to a computer via USB. For those throwback iPhones like the 6s, pressing the Home button while connecting can kickstart a reboot.
  • Wireless Charger Magic:
    Slap that phone onto a Qi charger. Fingers crossed, it’ll reboot as it gets powered up.
For Software Snafus:
How to reset: Open up Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings. No loss of stuff, just clearing away those pesky software problems.
Keep That Button Working
  1. Lay Off the Physical Stress: Snag a protective case to keep things running smoothly.
  2. Don’t Skip Those Updates: iOS updates help fix the quirks that slow down your buttons.
  3. Set Up AssistiveTouch Early: Handy backup plan for when the buttons start acting their age.
Time to Call in the Pros
  • If you’ve tried it all without luck, it might be time for a trip to an Apple Store or hit up a repair shop to dig deeper.
Mixing up tech tools, button hacks, and being ahead of the curve can save you from depending on the power button too much while keeping your iPhone entertainingly running.
Alright, so you’ve got a broken power button on your iPhone and need to restart it? No worries, there’s a bunch of ways to get it done without that button.
First off, try using AssistiveTouch. Sound fancy, but it’s super easy:
  • Head into Settings, tap Accessibility, then Touch, and finally, AssistiveTouch.
  • Flick the switch to turn AssistiveTouch on. You’ll see a little button pop up on your screen.
  • Give it a tap, go to Device, then hold down Lock Screen (look for the padlock symbol). Just slide to power off.
  • Need to fire it up again? Just plug it in to charge, and voilà, back to life!
Got more ideas up my sleeve? Absolutely. Check this out:
Next trick is with the Accessibility Shortcut:
  • Go back to Settings, hit up Accessibility, then Accessibility Shortcut.
  • Pick AssistiveTouch. Now, triple-click that Home or Side button to get AssistiveTouch on the case.
And here’s a handy tip—software updates can also do the trick:
  • Connect to a Wi-Fi network, head to Settings, General, and then Software Update.
  • Tap on Download and Install if there’s an update. Once it’s finished, your iPhone restarts automatically.
Still need another option? Resetting the Network Settings could be the way to go:
  • Again, dive into Settings, find General, and then Reset.
  • Choose Reset Network Settings. Pop in your passcode if needed, and your iPhone will restart.
These tips should get you sorted without a functioning power button. But honestly, getting that button fixed is probably a smart move for the long haul.
