How to Reset Computer Without Admin Password?
413 viewsComputer
Background
There are lots of reasons why you might need to reset a computer without knowing the admin password. Maybe you’ve forgotten your own password and can’t access your device, or perhaps you’ve bought a second-hand computer and don’t have the previous owner’s login details. In these cases, a factory reset can be a lifesaver to get you back in action.
Risks and Precautions
Before diving into a reset, just a heads up: this process will wipe out everything on your device—documents, photos, apps, the lot. So, if you can, back up anything you’d hate to lose either to an external drive or cloud storage.
Methods
Windows
  • Reset This PC:
    • Access the Advanced Startup Options menu: Restart your computer and keep hitting the F11 key as it boots up. You’ll end up in the Advanced Startup Options menu. Choose “Troubleshoot” and then “Reset this PC.”
    • Choose reset option: In the “Reset this PC” window, you’ll see options like “Keep my files” or “Remove everything.” Since we’re dealing with a forgotten password, go with “Remove everything” to make sure it’s a clean reset.
    • Follow on-screen instructions: The system will walk you through some prompts to confirm the reset. Once you’re done, the reset process will kick off and could take anywhere from several minutes to an hour. After that, your computer will restart, and you’ll see the initial setup screen, where you can create a new admin account and set it up how you like.
  • Command Prompt:
    • Access the Advanced Boot Options menu: Restart the computer and press the F8 key repeatedly to enter the Advanced Boot Options menu. Select “Repair your computer.”
    • Open Command Prompt: Click on “Troubleshoot” and then choose “Command Prompt.” In the Command Prompt window, type the command “rstrui.exe” and press Enter. This will open the System Restore window.
    • Complete the system restore: Click “Next,” pick your restore point, and follow the on-screen steps to complete the process. Your computer will restart and reset to the chosen restore point.
Mac
  • Recovery Mode:
    • Boot into recovery mode: If you’ve got an Intel-based Mac, turn it off, then hold Command and R while turning it back on. Let go once you see the Apple logo or hear a chime. For Macs with Apple silicon, turn it off, then press and hold the power button until the startup options screen pops up; hit Options, then Continue.
    • Open Disk Utility: Inside recovery mode, select Disk Utility from the macOS Utilities screen. Find your Mac’s boot disk (usually called Macintosh HD) in the sidebar and click Erase in the toolbar. Name the disk, format it as APFS, and you’re good to go.
    • Reinstall macOS: Quit Disk Utility, choose Reinstall macOS from the macOS Utilities screen, and follow the instructions to reinstall macOS. Once that’s done, your Mac will restart, and you can set up a new admin account during the setup process.
  • Create a New Administrator Account:
    • Boot in safe mode: Just press Shift + Power button or Command + S when starting up.
    • Create a new admin account: Navigate to Users & Groups > + (Plus symbol) > Quick Actions, select Administrator as the role, and add in a name and password. Save those changes.
    • Grant privileges and reset the original password: Switch to the new admin account, go to Applications > Utilities folder, open the System Information app, click System Report, select System Parameters, and copy the MAC address. Go back to the original user account and use methods like Command + S > Terminal > net account passwd to reset the admin password for the original account.
Third-Party Software
If neither of those options works for you, there are third-party password reset tools that can help. Be cautious and make sure the software comes from a reputable source. Double-check its terms of service and privacy policy to understand how your data will be handled. A few well-known tools include iSumsoft Windows Password Refixer and PassFab 4WinKey.
Post-Reset Steps
After resetting, you’ll need to go through the initial setup process again. This means selecting your language preferences, connecting to Wi-Fi, setting up a new admin account, and so on. Also, don’t forget to update the operating system and any software to their latest versions to keep things running smoothly.
Final Thoughts
Losing access to your admin password can be a major hassle, but it doesn’t mean you’re completely locked out. By following the right steps for your operating system, you can reset your computer and regain access. Just remember to back up any critical data beforehand. And in the future, consider using password recovery options or a password manager to avoid similar headaches.
Trying to reset your computer without the admin password, huh? No worries, there are a few nifty tricks you can pull off whether you’re on Windows 10 or Windows 11. Let’s dive into how you can get back into your system, easy peasy.
First up, don’t sweat it. We’ve got a slick method using the Advanced Startup Options. Here’s the deal: head over to the login screen after firing up your computer. Hit that Power icon down in the corner, hold onto the Shift key, and click “Restart.” This magic combo drops you right into the Windows Recovery Environment—fancy name, but it’s pretty straightforward.
  • Pick “Troubleshoot,” and you’ll see “Reset this PC.”
  • Now, you can either hang onto your files and bid adieu to just apps and settings or wipe everything clean.
  • You also get to pick between downloading Windows from the cloud or reinstalling it from local files.
Just follow the prompts, kick back, and let your PC do its thing.
If that doesn’t work, don’t start pulling your hair out just yet—we’ve also got the installation media trick up our sleeves.
  • Grab yourself another computer, visit Microsoft’s site, and snag their media creation tool to make a bootable USB drive.
  • Plug that bad boy into your locked computer, jump into the BIOS with a little button mashing (think F2, F12, Esc, or Del), and set your USB drive to boot first.
  • Go ahead, install Windows fresh, and kick annoying passwords to the curb.
Got some built-in recovery options lurking in your system? Sweet!
  • Try shutting down your computer by holding the power button and do this dance thrice to access WinRE automatically.
  • Once you’re in, follow the steps like before—reset your PC, keep your files if you feel like it, or take the full cleanse approach.
Honestly, these methods sound like a lifesaver, right? You’ll be up and running soon without that pesky admin password blocking your path. Happy resetting, and may your tech troubles breeze away!
So, you’ve got a computer that you need to reset but you can’t remember the admin password? Don’t sweat it. This kind of situation pops up more often than you might think, whether you’ve simply forgotten your password, bought a second-hand device, or run into a few system hiccups. Let’s break down some ideas on how to tackle this dilemma.
First off, let’s look at where things might have gone sideways. If you seldom use your admin account, it’s easy to forget the password. Acquiring a second-hand PC can leave you carrying someone else’s locked baggage. Sometimes, all it takes is a few corrupted files and your login credentials are tossed out the window. And hey, if you don’t have admin rights, resetting the computer can feel out of reach.
Now, how can you dig yourself out of this hole? Here are some tricks you might find handy.
One way is to reset through your Microsoft account if it’s linked up with your Windows account. On the login screen, hit “I forgot my password,” and follow the prompts to reset it via email or SMS. Once you’ve sorted your password, hop over to Settings, Recovery, and then Reset This PC to start fresh.
You could also try booting into Safe Mode as a way to sidestep the login hassle on Windows 10 or 11. Restart your computer, hold Shift and click Restart to access recovery mode, then dive into Troubleshoot > Advanced Options > Startup Settings > Restart. Once you’re in Safe Mode, see if you can log in using the default Administrator account — sometimes, it doesn’t have a password.
Can’t catch a break? Bring out the big guns with the Command Prompt using installation media (like a USB or DVD). Boot from that, go for Repair Your Computer, and swap the sticky keys utility with CMD using these commands:
copy c:\windows\system32\sethc.exe c:\
copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe
Reboot, tap Shift five times at login, and there you go — Command Prompt opens up! Now reset your password with:
net user [username] [new_password]
Plug in your details for username and new password, and you’re all set.
You can also go the factory reset route via a recovery partition — handy but risky as it erases everything. On restart, tap the right key (like F11 for HP or F9 for ASUS) and follow the prompts for a clean slate.
Finally, for the tech-savvy folks, third-party tools like Offline NT Password & Registry Editor or PCUnlocker can do the trick. Fire up a bootable USB on another computer, then run the locked PC from the USB and let the tool do its thing.
Before you dive in, it’s smart to back up any crucial data. With system resets or third-party tools, you could lose files, so better safe than sorry. Plus, ensure your method vibes with your OS, and remember — make sure you own the computer you’re troubleshooting!
And there you have it. Some tested-and-true suggestions to help you take back control of your PC, even when the password slips away. Best of luck!
How to Reset Your Computer Without the Admin Password on Windows 10 or 11
So, you’re locked out of your own computer because you can’t remember the admin password—been there! Thankfully, there are some tricks up our sleeves. Let’s dive into a couple of ways you can reset your computer without that elusive password.
First off: Using Windows Recovery Environment (WinRE)
Here’s the scoop:
– You gotta restart your computer.
– Hit that Shift key and keep tapping F8 like it owes you money until you see the Advanced Boot Options menu pop up.
Once you’re in:
– Head over to Troubleshoot, then Reset this PC.
– Go for the Remove everything option to wipe the slate clean.
And just follow the prompts on the screen to get through the reset.
Next up: Doing a Reset from the Login Screen Using Shift + Restart
Here’s the kicker:
– When you’re stuck at the login screen, hold that Shift key, click on the Power icon, and choose Restart.
After it fires back up:
– Select Troubleshoot, then Reset this PC.
– You’ll have the choice to keep your stuff or ditch it all. It’s up to you!
Pick an option and let the on-screen wizard guide you through.
Safe Mode to the Rescue
How does this sound:
– Reboot the computer and keep hitting F8 like you’re playing an old arcade game.
– Choose Safe Mode with Command Prompt from the list.
Once Command Prompt shows its face:
– Type in net user administrator /active:yes and hit Enter.
– Restart and log in as the Administrator.
After you’re back in:
– Swing by Settings, go to Update & Security, select Recovery, then find Reset this PC and follow the setup prompts.
Lastly: Using a Bootable USB Drive
Here’s the plan:
– Borrow a friend’s computer to download the Windows Media Creation Tool from Microsoft’s website and whip up a bootable USB drive.
Stick the USB into your locked computer:
– Boot from it and set up your preferences—language, time, and all that jazz.
Head down to the bottom left corner:
– Click Repair your computer in the setup window.
– Navigate through Troubleshoot, then hit Reset this PC and follow the instructions to get it sorted.
Word to the wise: This process will wipe out your data, so it’s a good idea to have your stuff backed up before you go full steam ahead.
Well, there you have it. With these steps, you can reset your computer without the admin password on Windows 10 or 11. Just remember to proceed with caution and make sure your key files are safe and sound.
