How Can I Stop My Phone from Vibrating When Typing?
764 viewsPhone
When you’re typing on your phone, computer, or other devices, those little vibrations can get quite annoying. Here’s how you can get rid of them on different devices:
Android Devices
  • Through System Settings:
    1. Open the “Settings” app on your Android.
    2. Scroll down and tap “Sound & Vibration” or “Sound & Notification,” depending on your device.
    3. Select “Vibration Intensity” or “Vibration Feedback.”
    4. Find “Keyboard Vibration” and either move the slider to the minimum level or just toggle it off.
  • Using the Keyboard App Settings:
    1. Go to “Settings.”
    2. Tap “Language & Input” or “System.”
    3. Pick “Virtual Keyboard” or “On-Screen Keyboard.”
    4. Select your active keyboard (like Gboard or Samsung Keyboard).
    5. Go to “Preferences” or “Typing.”
    6. Turn off the “Vibration on Key Press” option.
iOS Devices
  • For iPhones and iPads:
    1. Open the “Settings” app.
    2. Scroll to and tap “Sounds & Haptics.”
    3. Under “Sound and Vibration Patterns,” tap “Keyboard Clicks.”
    4. Toggle off “Vibrate on Silent.” To completely disable vibrations for keyboard clicks, also switch off “Vibrate on Ring.”
Windows Computers
  • Via Settings Menu:
    1. Click the Start menu and select “Settings.”
    2. Click “Devices.”
    3. Pick “Typing” from the menu on the left.
    4. Under “Touch Keyboard,” find the “Vibrate” option and turn it off.
Mac Computers
  • Through System Preferences:
    1. Click the Apple menu and choose “System Preferences.”
    2. Navigate to “Keyboard” and select the “Keyboard” tab.
    3. Uncheck the “Enable Keyboard Feedback” option to turn off vibrations.
Third-Party Keyboard Apps
  • Gboard:
    1. Open the Gboard app.
    2. Go to “System” then “Languages & Text Input.”
    3. Tap “Virtual Keyboard” and select Gboard.
    4. Head to “Preferences” and turn off “Vibration When Pressing Keys.”
  • SwiftKey:
    1. Open SwiftKey.
    2. Go to “Sound and Vibration.”
    3. Turn off “Vibration When Pressing Keys.”
OPPO Devices
  • Through the Settings Menu:
    1. Open “Settings.”
    2. Navigate to “Sounds” or “Vibration.”
    3. Turn off “Vibrate on Type” or lower the intensity if you still want some feedback.
If you’re having trouble finding the right setting, use the search function in the Settings app. Sometimes, different keyboards have their own vibration settings, so make sure to disable it for each one. If your device still vibrates, switch to the default keyboard or check for software updates, as they might fix any bugs causing the issue.
**new_answer:** Here you go! Just follow these steps, and you’ll get rid of those annoying vibrations in no time.
Hey there! You’re trying to ditch the typing vibes on your Android phone, right? Let’s break it down so you can type without feeling like your phone’s got a mind of its own.
First up, if you’re using Gboard, Google’s trusty keyboard, here’s what you do. Start by tapping into any text box. Once your keyboard’s up, look out for that gear icon—it’s like the secret entrance to a world of settings. Tap it, and then head into ‘Preferences.’ Keep scrolling until you spot ‘Haptic Feedback on Keypress’. It’s like a little switch that keeps the vibes going, so you’ll want to flick it off. Done and done—no more key press tremors!
Got a Samsung phone? Their keyboard’s got similar moves. Pop into any text field to get the keyboard showing. Find that gear icon and dive into the settings there. Look for the ‘Swipe, Touch, and Feedback’ section—it’s not as secret as it sounds, promise. From there, toggle off the ‘Vibration’ in ‘Touch Feedback’. Bam! Your Samsung keyboard should quiet down on the vibrations.
Now, if none of these match your device, don’t sweat it. There’s a bit of an all-purpose method for other Android versions. Start by hitting your device’s main settings menu, find the sound settings that might be under ‘Sound & Vibration’ or something along those lines. Here’s where the magic happens—you can turn off ‘Keyboard vibration’ or ‘Vibration & haptics’ if you spot them.
Bottom line: Whether you’re rocking Gboard or Samsung’s, following these steps should let you type like a pro without the constant buzzing. Good luck, and happy typing!
Trying to get rid of typing vibrations? Let’s dive into a few tricks that might just do the job. We’re talking everything from device tweaks to deep dives in settings. Buckle up, ’cause we’re gonna tackle this head-on.
Hey, What’s Up with Keyboard Vibration?
Ever feel that buzz when you type? That’s haptic feedback. It’s supposed to make typing feel more real, but sometimes it’s just annoying or kills your battery. Here’s why you might be feeling it:
  • Some system settings are taking over the show.
  • Your favorite third-party keyboard apps might have it as the default setting.
  • Could be your hardware acting up – think stuck sensors or bugs.
Let’s Sort This Out
Time to Tweak Those Keyboard Settings
Got an Android? Do this:
  • Head over to Settings > Sound & vibration > Vibration & haptics.
  • Turn off Touch feedback or Keyboard vibration.
  • If you’re using Google Gboard, open the app, swim over to Preferences > Vibration on keypress, and crank that slider down to 0ms.
Rocking an iPhone?
  • Swing by Settings > Sounds & Haptics > Keyboard Feedback.
  • Flip Haptic off.
Favourite third-party keyboards like SwiftKey or Grammarly?
  • Dive into the app’s settings.
  • Find something like Vibration or Haptic feedback under Typing or Preferences. Turn it off.
How About Turning Off System-Wide Haptics?
If the buzz won’t quit, the system’s being a rebel:
  • On Android, visit Settings > Accessibility > Vibration & haptic strength, and tone down the Touch feedback.
  • For iOS, explore Settings > Accessibility > Touch > Haptic Touch and play around with the sensitivity or shut it down.
Software or Keyboard Apps Need Some Love?
Old software sometimes throws tantrums:
  • Look for OS updates over at Settings > System > Software Update.
  • Give those keyboard apps a refresh via the Google Play Store or the App Store.
Put Android in Safe Mode – It’s worth a shot!
There might be some bad apples messing things up:
  • Hold down the power button, then tap and hold Power Off to boot into Safe Mode.
  • If the buzz takes a break, start uninstalling apps you recently added.
For Persistent Buzz, Check Your Hardware
If nothing else fixes it, might be hardware:
  • Try a reset of all settings (Android: Settings > System > Reset; iOS: Settings > General > Transfer or Reset).
  • If it’s still vibing, swing by an authorized service center.
Little Nuggets of Wisdom
  • Hit up battery saver mode to tone down the haptic feedback automatically.
  • Got a gaming phone like an ASUS ROG or Xiaomi Black Shark? Turn off any Game Mode vibrations.
This rundown dives straight into the nitty-gritty of device settings to nix any unwelcome typing shakes. Good luck!
Getting rid of that pesky vibration when typing isn’t just about comfort—it’s way quieter and even saves some juice on your battery. Here’s a straightforward way to nix it on both Android and iPhone gadgets.
Let’s first tackle Android phones:
On most Android devices, you want to dive into the Settings. Scroll until you hit the Sound & vibration or maybe Sounds and notifications, give it a tap. Under Advanced or Other sounds, find that Vibrate on touch or Keyboard vibration option and flip it off! Easy peasy.
Google Pixel owners, listen up:
  • Head over to Settings, jump into System.
  • Next, navigate into Languages & input, then Virtual keyboard.
  • You’ll want to tap into Gboard and hit Preferences.
  • Once you’re there, just switch off Haptic feedback on keypress. No more vibrations!
And for you Samsung Galaxy folks:
  • Pop open Settings, hit General management, and then Language and input.
  • Choose On-screen keyboard, then head on over to Samsung Keyboard.
  • There, you need Preferences.
  • Now just turn off Key-tap vibration and you’re sorted.
Now, iPhone users:
  • If you’re on iOS 13 or newer, crack open the Settings app.
  • Find your way to Sounds & Haptics.
  • Keep scrolling till you land on Keyboard Feedback.
  • Just toggle off the Haptic there, and you’re done.
Once you’ve got those settings adjusted, typing becomes a blissful experience—quiet and smooth, just the way it should be.
