How Can I Reduce the White Point on My iPhone to Make the Screen Easier on the Eyes?
167 viewsPhone
If you\’re finding your iPhone screen too bright and it\’s giving your eyes a hard time, especially in lower light situations, you’re not alone. Many people want to make that bright white background a bit gentler. Here\’s what you can do:
Getting to the Root:
You might be talking about the \”white point,\” which is just fancy language for screen brightness settings. Or, maybe you’ve got actual \”white spots\” on your screen (like stuck pixels), which could be a hardware issue. Let’s break it down.
Software-Based Fixes:
If your screen\’s white areas are too intense, iOS has your back with a feature called \”Reduce White Point.\” Here\’s how you can try it out:
  • Pop into your Settings.
  • Head to Accessibility, then Display & Text Size.
  • Flick the switch on Reduce White Point and move the slider until things look just right for you.
  • Want a warmer screen? Pair it with \”Night Shift\” (same Settings journey, just look under Display & Brightness).
This combo should make reading in the dark more comfortable.
Tackling White Spots:
Spotted some stubborn white dots? It could be dead or stuck pixels. Here’s a quick test:
  • Pull up a plain black image in a dark room. Still see those spots? Likely a hardware issue.
Fixes? Not a guarantee, but here’s what to try:
  • Gently rub the spot with a microfiber cloth (easy does it, too much pressure might be bad news).
  • For real damage, hitting up an Apple service center is your best bet.
Handling Software Glitches:
Sometimes, it’s just a glitch. Try this:
  • Give your phone a fresh start. Force-restart it:
    • If you’ve got an iPhone with Face ID: tap Volume Up, then Volume Down, and hold the Side button until the Apple logo shows up.
If that doesn’t cut it, a settings reset might do the trick:
  • Head to Settings > General > Transfer or Reset iPhone > Reset All Settings (don’t sweat, your data stays safe).
App Trouble?
Maybe an app’s stirring things up:
  • Boot your phone in Safe Mode (restart it while holding the Volume Down) to rule out third-party apps.
  • Spot the troublemaker? Try uninstalling any recent apps that might be messing with your display.
Tips to Keep Your Screen in Good Shape:
Keep your phone away from extreme temperatures and sharp bumps. Screen protectors can be your phone’s best pal, too. And always keep iOS up-to-date—it helps nip those little bugs in the bud.
In the end, if things just aren\’t getting better, it might be time to check in with Apple Support. And remember, it\’s always a good idea to back up your data before going for any major fixes. Good luck!
Hey there! Struggling with your iPhone’s bright screen? I’ve got you. Let’s dial down that glare by reducing the white point on your device. It\’s super simple; just follow these steps:
  1. Fire up the Settings app.
  2. Scroll until you see Accessibility and tap on it.
  3. Hit up Display & Text Size under Accessibility.
  4. Slide on down ‘til you spot the “Reduce White Point” option.
  5. Flip that switch to on and play around with the intensity slider to find your sweet spot.
Tweaking the white point lessens those intense colors, making it way easier on the eyes, especially in dim light. But heads up, if you max out your slider—like pushing it to 89%—it might get tricky to see your screen when you’re out in the sun, particularly for folks with the iPhone 14. If it starts to go all squinty in bright sunlight, maybe ease up or switch it off for a while to hit the right balance for wherever you are.
Give it a whirl, and you’ll have your iPhone’s display feeling much comfier for your peepers—no more blinding yourself when you check your phone at night!
If the brightness on your iPhone is too intense, there’s a nifty trick you can use called ‘Reduce White Point.’ Here’s how you can make your device easier on the eyes:
  1. Jump into Settings: Hit up the Settings app right there on your home screen.
  2. Find Accessibility: Scroll around until you see Accessibility. Give that a tap.
  3. Go to Display & Text Size: Once you’re in Accessibility, head over to Display & Text Size.
  4. Turn on Reduce White Point: Look for Reduce White Point, then flick the switch to get it going.
  5. Slide to Adjust: Now here’s the kicker—see that slider? Move it around to find what feels just right for you. The further right you go, the softer the whites.
This can be a lifesaver if bright screens give you a headache or you’re just trying to save a bit of battery. It’s one of those hidden gems on the iPhone. Check out Apple’s support page if you’re curious for more details.
