How Can I Recover Deleted Images from WhatsApp on Android?
327 viewsPhone
WhatsApp is such a popular app for messaging, but sometimes we all accidentally delete those cherished images. Whether we were too quick on the delete button or just trying to free up some space, it can really throw a wrench into our day. But don’t sweat it; getting those precious photos back is actually possible! Let’s dive into how you can recover those deleted images.
Recover from WhatsApp Backup:
  1. Check Backup Settings: Open WhatsApp, head over to Settings > Chats > Chat Backup, and see when your last backup was. If it was before you lost your images, you’re in luck!
  2. Uninstall and Reinstall WhatsApp: Press and hold the WhatsApp icon until the options pop up. Tap “Remove App” > “Delete App”. Then open the Google Play Store, search for WhatsApp, and download it again.
  3. Restore Chat History and Photos: Once reinstalled, open the app, go through the setup, and verify your phone number. WhatsApp will prompt you to restore from the most recent backup. Tap “Restore Chat History,” and you should see your deleted images back where they belong.
Recover from Phone Storage:
  1. Open the Photos App: WhatsApp likes to save your images automatically, so check the Photos app for any strays.
  2. Go to the WhatsApp Album: Tap the “Albums” tab in the Photos app and look for an album named “WhatsApp” or something similar. Your missing pics might be hiding there.
  3. Check the Recently Deleted Folder: If you still can’t find them, they might be in the “Recently Deleted” folder. Scroll down to “Utilities” in the Photos app, peek inside “Recently Deleted,” and recover any WhatsApp media files you see.
  4. Enable Auto-Save for Future Media: Prevent this from happening again by going to WhatsApp, tapping Settings > Chats > “Save to Camera Roll” to make sure your media is always auto-saved.
Recover from Google Drive Backup:
  1. Verify Backup: Go to WhatsApp > Settings > Chats > Chat Backup and check the timing of your last backup.
  2. Uninstall WhatsApp: Remove the app from your device to start fresh.
  3. Reinstall WhatsApp: Get WhatsApp again from the Google Play Store.
  4. Activate the App: Open WhatsApp, enter your phone number, confirm it, and it’ll prompt you to restore from a Google Drive backup. Accept it.
  5. Complete Restoration: After restoring, your previously deleted photos should reappear.
Recover Using Third-Party Applications:
  1. Research Recovery Software: Find reliable recovery tools like Dr.Fone, EaseUS MobiSaver, or DiskDigger that work with your device.
  2. Download and Install: Grab the software from the official site to avoid any nasty malware.
  3. Connect Your Device: Plug your phone into your computer with a USB cable, making sure USB debugging is on (Settings > Developer options > USB debugging).
  4. Run the Recovery Software: Open it and select the option for recovering WhatsApp or media files.
  5. Start Scanning: Let the software do its thing and scan for those lost images.
  6. Preview and Recover: Once done, you can preview and bring back the deleted photos.
Recover from Local Backup:
  1. File Manager Access: Open the file manager and navigate to the WhatsApp folder, usually in internal storage or on your SD card.
  2. Open Database Folder: Look for the “Databases” folder, where files are labeled by date.
  3. Identify Local Backup: Pick the backup from before your photos were deleted.
  4. Rename Backup: Change the file name to “msgstore.db.crypt12” and keep a copy of the original file.
  5. Uninstall and Reinstall WhatsApp: Follow through the setup steps and restore from the local backup.
Request the Sender to Resend:
Don’t be shy to ask the person who sent you the image or anyone else in the chat to resend it. If it’s a group chat, odds are someone else has it saved too.
Recover from Email or Cloud Storage:
If you’ve ever shared or saved your WhatsApp images to email or a cloud service like Google Photos or Dropbox, check there too. Search your email for attachments or navigate your cloud storage’s “WhatsApp” folder. Your images might just be a click away!
In a nutshell, there are plenty of ways to rescue those deleted WhatsApp images. To dodge future headaches, make it a habit to back up your chats and media regularly and enable auto-save in your gallery. This way, if this ever happens again, you won’t break a sweat.
Alright, so if you’ve accidentally deleted images from WhatsApp on your Android, don’t sweat it too much. There are a few nifty ways to get them back, and I’ll walk you through the options.
First up is recovering from your WhatsApp backup. If you’ve turned on the backup feature, it’s pretty straightforward to get your pics back by reinstalling the app. Here’s the lowdown:
Backup Check: Pop open WhatsApp, head to settings, then Chats, and finally, Chat Backup. Have a peek at the date of the last backup—it should be before those pesky images went poof!
Uninstall WhatsApp: Just go to your device settings, find WhatsApp in the apps list, and hit uninstall.
Reinstall WhatsApp: Hop over to the Google Play Store, download, and install WhatsApp again.
Set Up Your Account: Fire up WhatsApp, verify your number, and when it asks, ‘Restore?’, give it the thumbs up to help it recover all your chats and magical pics.
Check for Your Images: Once it’s done doing its thing, dive into your chats to see those images reappear.
This way works great…if you had a backup. Moving on!
Next, you can take a stroll through your phone’s storage because WhatsApp usually tucks away all media files. Here’s what you do:
Open a File Explorer: Grab any file manager app on your Android. Files by Google is a winner if you’re looking for recommendations.
Hunt Down the WhatsApp Media Folder: Navigate to Internal or Phone Storage. Sniff around until you find a folder named WhatsApp, then dig into Media, and finally WhatsApp Images.
Spot the Deleted Pics: Don’t forget to check the Sent and Received folders. Sometimes old copies hang out there even after chats sulk and delete them.
This method shines if you had downloaded the images before they vanished. Now, in case all else fails, there’s a third way!
Try some third-party recovery tools to save the day. If your backup went AWOL, these tools are your best mates:
Pick Your Weapon: Consider options like AnyRecover, DroidKit, or MobileTrans.
Gear Up: Get your chosen recovery tool installed on your computer.
Connect Your Gear: Hook up your Android device to the computer with a USB cord.
Follow the Bouncing Ball: Launch the software, select WhatsApp data recovery, and let it do the deep dive for lost files.
Get Back Your Stuff: Once it spits out the results, preview, select, and hit ‘Recover’ to bring the images back to your device or computer.
These tools are handy even if you’re not a tech whiz—nice and easy!
Lastly, when everything else is out the window, you can go old school. Ask the sender to resend it:
Pin down which buddy sent the image.
Ask if they can send it over again.
If it’s from a group chat, reach out to other peeps in the group and see if they’ve still got it handy.
This one obviously banks on folks being generous and cooperative.
And there you have it. Whether you lean on backups, storage sleuthing, third-party tools, or simply the kindness of others, there’s a path to getting those photos back on your Android device.
Alright, let’s dive into some ways you can get back those lost images from WhatsApp on your Android device.
First up, you gotta check out WhatsApp’s chat backup. You know the drill: hop into WhatsApp, head to Settings, then Chats, and finally Chat Backup. Now, peek at when the last backup was done—if those images were in there, bingo! All you need to do is uninstall and reinstall WhatsApp, and during the setup, it’ll ask if you wanna restore your chat history. Go for it, and those pictures should pop back up!
Next, rummage through your phone’s storage. Fire up the File Manager app and take a little adventure to WhatsApp > Media > WhatsApp Images. Your lost treasures might be chilling in the Sent or WhatsApp Images folder.
Now, if you’re feeling like a digital Indiana Jones, grab a data recovery app. There’s tools like DiskDigger, Dr.Fone, or Tenorshare UltData that can help you sift through the muck and find your gems. Just follow their instructions, and you’re on your way.
Also, do you have Google Photos doing its thing? Because if WhatsApp is set to automatically dump photos there, you might find your lost shots in the Bin section. It keeps them safe for 60 days until they’re gone for good.
If all else fails and you’re still in a pinch, reaching out to WhatsApp Support might be your last resort. Fire up WhatsApp, slide into Settings, tap Help, and then Contact Us. Spill the beans on what’s going down, and they might just lend a hand.
Oh, and heads up: make sure you’re backing up your WhatsApp stuff to Google Drive regularly—you don’t want this kind of hassle again.
So there you have it—hope one of these tricks works to get your pics back!
