How Can I Print Over WiFi From My Device?
406 viewsPrinters
1 Answer
Want to print using WiFi? Here’s how you can get your wireless printer up and running:
Connect Your Printer to WiFi:
  • First things first, turn on your printer and make sure it’s within reach of your WiFi network.
  • Find the wireless settings in the printer’s control panel.
  • Select your WiFi network from the list and pop in the password.
  • Give it a moment to connect. Check the printer’s screen to make sure it’s all good.
Install Printer Drivers:
  • Head over to the manufacturer’s website and grab the latest drivers.
  • Run the installation on your device and follow the simple on-screen prompts.
Get Your Printer Added to Your Device:
  • For Windows: Open up “Settings,” then slide to “Devices,” and hit “Printers & scanners.” Find your printer on the list and follow along.
  • For Mac: Jump into “System Preferences,” select “Printers & Scanners,” and press “Add (+).” Pick your printer from the lineup.
  • For Mobile Gadgets: Use the brand’s app or check built-in features like AirPrint for iPhone or Google Cloud Print for Android. Just follow the instructions.
Time for a Test Print:
  • Pull up a document and hit “Print” from the file menu.
  • Pick your wireless printer and let it do its thing.
Troubleshooting Tips:
  • Make sure your printer and WiFi router are fully updated.
  • Double-check that both the printer and your device are hanging out on the same WiFi network.
  • If the WiFi signal is acting wonky, inspect for interference or any obstacles.
If you’re feeling lost, take a peek at the printer’s user guide or hit up the manufacturer’s support.
Check these out:
  • Setting Up HP Printer on WiFi
  • PCMag: Hooking Your Printer to WiFi
These steps should have you printing wirelessly without a hitch.
