What’s the Best Way to Monitor CPU Temp on Windows 10?
237 viewsComputer
Here’s how you can easily keep tabs on your CPU temperature in Windows 10.
First up, you’ve got the Task Manager. While it gives you a peek at CPU usage, it doesn’t show temperature. So, on to better options!
One handy little tool is Core Temp. It’s free and does exactly what it says on the tin—shows the temperature of each CPU core. Just download it from the official site, install, and you’re set.
Another option worth checking out is Open Hardware Monitor. It’s open-source and gives you a full rundown of your PC’s vitals, like CPU temp, fan speeds, and all that good stuff. Download, extract, run it, and voilà—you’ve got live data at your fingertips.
Then there’s HWMonitor, made by CPUID. This trusty tool reads system sensors to hand you detailed info about temperatures, voltages, and fan speeds. A quick install and you’re in business.
If you’re feeling old school, hit up the BIOS or UEFI Firmware. Just reboot and mash the right key during startup (could be F2, F10, DEL, or ESC) to get in. Once there, hunt down the system health section for the numbers you need.
Each of these methods gives you a solid way to keep an eye on your CPU temps. And let’s be real, keeping your system from overheating is always a smart move. Just make sure you snag your software from legit sources—keeps the gremlins away.
Alright, let’s get down to business on how to keep an eye on your CPU temperature if you’re rocking Windows 10.
Why the Fuss About CPU Temps?
Honestly, keeping tabs on your CPU’s heat is crucial. Running too hot can result in some annoying slowdowns and worse, it might cut your hardware’s life short. You don’t want your system going on a surprise break in the middle of something important, right?
Here’s what you need to know about normal temps:
  • When your computer is just chilling (idle), it should be around 30°C–50°C (86°F–122°F).
  • During gaming or heavy multitasking, it might hit 60°C–85°C (140°F–185°F), anything over 90°C (194°F) should raise those red flags!
How to Keep an Eye on Those Temps:
You might find it strange, but Windows 10 doesn’t come with a built-in app for monitoring CPU temps. But don’t worry, there are plenty out there that do the job just fine. Let’s look at a few.
Third-Party Software Picks:
  1. HWMonitor: This app is simple and to the point. Download, install, and check your CPU temps—easy as pie! The downside? It won’t ring the alarm when things get too toasty.
  2. Core Temp: Another goodie to consider. It even warns you if things get too hot, and you can keep logs if you\’re into that kind of data tracking.
  3. NZXT CAM or MSI Afterburner: These are gamer favorites that give you CPU and GPU stats side by side. Perfect if you want the bigger picture.
BIOS/UEFI Method:
If you don’t feel like downloading more stuff onto your system, this one’s for you—though it’ll only show you the temps when your computer is at rest. Restart your rig, press that magic key to enter the BIOS (it could be Delete, F2, or F10 depending on your machine), and look for the hardware monitor section.
Trouble in Temperature Paradise?
Sometimes those temps are stubbornly high or they’re missing altogether on your monitor screen. Here’s what might be going on:
  • Old CPUs might not even have temperature sensors.
  • Chipset drivers might need a quick update.
  • Your antivirus might be playing goalie and stopping the software from checking temps.
Quick Fixes:
Update your drivers from the manufacturer’s website, switch software if yours isn’t working, and try disabling your antivirus temporarily just to test.
If your temperatures are consistently running high, then dust might be the culprit, thermal paste might be old, or your cooling system’s on the fritz. Cleaning your PC, repasting your CPU, and improving airflow could save you from overheating nightmares.
Stay Cool
Keeping your PC properly maintained every few months, investing in some good cooling, and being mindful of your workload could keep you well below the danger zone temperature-wise. If after all this you’re still having issues, it might be time to phone a friend or a technician for some help.
Keeping on top of this lets you worry less and work (or play) more without those pesky interruptions!
Keeping an eye on your CPU temperature in Windows 10 is really important to make sure your PC stays in tip-top shape. Overheating can slow things down or even damage hardware, and since Windows doesn’t offer a built-in way to check temps, most people turn to other tools or some PowerShell magic.
When it comes to temperature-checking apps, you’ve got plenty of choices. Some of the big names include:
  • Core Temp: This one\’s a breeze. It sits quietly in your taskbar and tells you how each core in your CPU is doing—simple and straight to the point.
  • NZXT CAM: Gamers love this one. Not only does it look pretty sleek, but it also has a nifty in-game overlay feature. So, if you’re in the middle of an intense gaming session, you can see those temps without alt-tabbing.
  • HWInfo and SpeedFan: These are like the Swiss Army knives of monitoring tools. Besides CPU temps, they give you details on fan speeds and voltages. Perfect if you’re the kind of person who wants all the info they can get.
  • Open Hardware Monitor: If you’re into open-source software, this is a solid pick. It tells you about clocks, temps, and much more, right from your hardware.
Now, here’s the kicker: You don’t even have to crack open your PC to use these tools. They tap into built-in sensors while your computer is idle, working hard, or gaming away.
Don’t feel like downloading anything new? You can also sneak a peek at your CPU temp via BIOS/UEFI settings, though this usually just gives you the idle temp. For those who love to mess with commands, there\’s a neat trick using PowerShell to grab that data, too. Here’s a snippet for anyone curious:
string = Get-WmiObject MSAcpi_ThermalZoneTemperature -namespace \"root/wmi\" | Select-Object CurrentTemperature    integer = (([int]$string.CurrentTemperature) / 10) - 273.15 Write-Output \"Your System Temperature is: $integer °C\"
That script should do the trick on many systems, but results might vary depending on your hardware.
Choosing the right tool boils down to what you’re after. If you\’re a gamer or running heavy apps regularly, NZXT CAM or HWInfo might be your best bet. PowerShell can be handy if you\’re into scripts and need quick checks. And if transparency matters a lot to you, Open Hardware Monitor\’s open-source nature might win you over.
Keeping your CPU cool is crucial, usually aiming for 40–65°C at idle and under 80°C when it’s working hard. Monitoring can help you spot cooling problems like clogged fans or worn-out thermal paste, which are just a pain and can slow down or shorten the life of your computer.
So, make it a habit to regularly check those temps. Your computer will thank you!
